04-25-07, 12:14 PM
#91 (permalink)
Tank Buster
Originally Posted by browndog
Dieseltim:
I figured you could probably get more power out of it, but the only reason I'm considering the Isuzu fours is fuel economy. I don't want to turn up fuel and boost in exchange for less economy.
There has to be a really strong reason for me to not go with a 1HD-T/FT with this swap.
Hey Browny, how bout CASH! That HDT/FT/FTE is going to cost you 10,000$.
A 4BT will cost you maybe 3,000$. The rest goes into the swap baby.....
2001 VW TDI Bora
1987 Toyota HZTJ-60
I'm a democrat member of the House of Representatives, and I've got what it takes to take what you've got!
04-25-07, 05:15 PM
#92 (permalink)
Tom:
Cash is a really strong reason. I would go with the 4BT but just can't swallow the 4 inches of lift required. I even checked on the newest version of the 4BT (QSB 3.9) but it's even BIGGER! Based on the success the aussies have had with the Chevy 6.5, I'm still leaning in that direction unless I get a SMOKIN deal on a HD-T or the Isuzu 4HE1 works out.
Cheers.
1987 BTJ60 SOLD!
13BT/H55f
1993 FZJ80
04-25-07, 09:19 PM
#93 (permalink)
Rookie
4bd2t Bellhouse Pattern
Anyone know what the factory bellhouse pattern is on the back of the 4bd2t and 4bd1t blocks? Been told that it might be a SAE #3. Anyone know different?
04-26-07, 03:04 PM
#95 (permalink)
we pulled apart the 4BD-1T last night to get ready to have the sleeves pulled. Bill (88tlc - who's engine it is) scored a PDF from someone on this site (thanks again who ever that was) and printed it off.. Says its been invaluable... Anyway, it says you need to remove the whole front cover to get the crank out... But we were luckily able to get it out, just barely, by removing the bearing caps and oil pan only..
anyway I'll post up pics and details of the rebuild as they come along. Bill is saying he can find rebuilds for about $2G in parts alone  Expensive!!!
04-27-07, 01:44 PM
#96 (permalink)
Dre...any chance in the rebuild of that 4BD you could pull the motor plate (what the bellhousing bolts to) off the back of the block and get a tracing of the bolt pattern? Looking to see if back of 4BD block bolt pattern is same/different from 4HE...in other words, can we swap motor plates. TIA...
Steve and Andy (ASTR)
TornadoAlleyCruisers
04-27-07, 08:05 PM
#97 (permalink)
adapters
I talked to this place today and they told me that if you guys will call them, that they can make us a bell housing/ adapter that will allow the use of the 4bd1t / 4bd2tc engines to be used with what ever tranny that we like. They DO NOT have one right now but if enough interest is shown then they would be willing to make them.
So, everyone call them at 877.602.1500 and tell them that the 4bd1t engine is the one that you would like to have an adapter for and maybe we can get our wish.
http://www.novak-adapt.com/
If not then you are going to have to wait for me to get something done , and that maybe some time b4 I can get something designed that can be made inexpensively or be made at home. I would love to be able to make an adapter up that you could all make yourself or get drawings made up that you could take to a machine shop and have it made locally. Until then I am looking for any info I can.
Dieseltim
04-27-07, 11:07 PM
#98 (permalink)
Sure Steve no problem, we'll do that.. The Novak guys are local for us, I have a good friend who's got his shop across the street.. I will definitely call!
04-28-07, 02:33 PM
#99 (permalink)
Pics
Ok, I am going to try to post some of my pics of my 4bd1t. I do have it running in the 2 pics of the sides.
Dieseltim
04-29-07, 06:23 PM
#100 (permalink)
Dieseltim
This is great if we can get them to make something. Do they need to know what we are adapting to? for example a 4bd1t to a A440F?
I will get you a life size tracing of the bolt pattern, of the flywheel housing that bolts to the engine. I had to take that off, to get the oil seal and crankshaft out.
04-29-07, 08:11 PM
#101 (permalink)
Can you post links where their success is documented?
Look up part numbers @ Online Toyota Parts Catalog
TLCA # 15006
1986 4Skinner
Relics: 1991 BTJ80, 1985 BJ70, 1997 FZJ80, 1981 FJ40, 1978 FJ40
04-29-07, 08:16 PM
#102 (permalink)
Arcteryx:
Are you being sarcastic?
If not, you can check out www.marks4wd.com, Brunswick diesels, or Linquip diesels. Landcruisers Northwest is also doing a 6.5 swap right now in Portland. It's a good motor with some minor modification (heat sink, mechanical fuel pump, etc), is readily available, relatively cheap, and good power.
1987 BTJ60 SOLD!
13BT/H55f
1993 FZJ80
04-29-07, 08:20 PM
#103 (permalink)
Arcteryx:
Not at all. I really would like to know more about how they are doing it. Thanks for the info. I know the 6.5 has some shortcomings, but with some mods, it is pretty reliable.
Cheers!
TLCA # 15006
1986 4Skinner
Reason: typo
04-30-07, 02:10 AM
#104 (permalink)
Stand and deliver
Cheers!
From speaking to the aussie companies that do the conversion they use mainly fully rebuilt engines.
They also have a favourite fuel pump that comes with the 6.5.
The best conversions install a custom radiator and do a mod to the auto trans to suit the 6.5 rpms
Lots of owners with 6.5 Landcruisers and Patrols on here if you ask a question http://www.exploroz.com/Forum/Default.asp
Mr Rentokill
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
HJ61 with slidin windas  regrettfully SOLD:(
Holden Commodore V6
Honda XR650L
04-30-07, 06:01 AM
#105 (permalink)
adapter 4 4bd1t
88tlc, Novak is local for you guys. If you can, why don't you take the flywheel/adapter ring in to them so they can see what we need to have made. I would like to have it mated to an sae#3 or a Chevy or Chyl.(Jeep)bellhousing, any of these would be ok with me.
Dieseltim
04-30-07, 12:54 PM
#106 (permalink)
Thing is they don't do custom work, we will have to convince them... Not sure but sort of like convincing Advance Adapters to do custom work...
They are also up in Logan so still a couple hours away. But I hadn't thought about the Novak route, definitely worth pursuing, but I'm still not sure the Isuzu to LC would be a big seller for them, but am unsure. Maybe they will do a couple custom rounds though. Beauty is the 3FE is it's the same as 2F and earlier. So H55F 5 speed, Land Cruiser 4 speed, Land Cruiser automatic, will all bolt to such an adapter...
There are also custom bellhousing builders, there is one up in San Fransisco I talked to, "Bob Weir" not of the dead, but he was interested in the idea years ago before the Isuzu diesel swapper guy...
Anyway, RE novak.. Definitely worth pursuing..
04-30-07, 12:57 PM
#107 (permalink)
seems to me that if Novak made a Chevy bolt pattern motor plate (goes between block and bellhousing), then we could bolt up either a Chevy drivetrain with Chevy bellhousing or a cruiser drivetrain behind an AA or Downey bellhousing. That would open up the 4BD to the widest market, AND get them into cruisers. If 4HE motors share that motor plate bolt pattern, so much the better. Starter mounting concerns would be the issue with this approach, I've been told which way the starter mounts on the two series of motor, but I forget which is which...bellhousing mount (facing rearward) and motor plate mount (facing forward).
this might make this method harder than it looks...you'd probably want a new motor plate to mount the stock starter so it mates with stock Isuzu flywheel, and if the 4HE starter pinion is different diameter/tooth count/etc. then that would make it hard to cover both applications.
anyway, just flapping my gums, here.
Steve
04-30-07, 01:32 PM
#108 (permalink)
Whats tough here is Bill (88tlc) wants to use the land cruiser auto transmission, which is probably less desirable than a Chevy pattern, sales-wise... In the end it might still be cheaper to go with a built 700R4 and the IsuzudieselSwapper.com stuff...
Anyway, just talked to Novak, they are interested in doing it.. Sounds like the costs might be a little high but we would own the design. Again I think the big market for them is for H55F bolting, which I would do personally probably over a NV4500 if it were me, given this motor. We could do a Chevy pattern too, we are going to explore plate and entirely new flywheel housing options I think.. Looks like about ~two weeks before we go up there..
If anyone is interested in one of these let me know!
04-30-07, 08:37 PM
#109 (permalink)
Urban Offroader
seems confusing, good luck getting novak or AA do help you out. From my understanding I am looking for any diesel that fits my needs/wants with an SAE4 bellhousing.
http://www.phxgrp.com/transmission.htm
First item on the page, SAE 4 to GM 5.7L. Now you can throw a 350 in just about anything. So why not take an isuzu or any diesel, cat, cummins, perkins, etc, with a sae 4 housing, throw that adapter on the back of it, so now you have a diesel with the back of a 350, get your respective adapter from novak or AA. Seems logical to me, thats what I was going to do, have I been misslead. That combo will work, you can use mulitiple adapters?
1991 T4R 5sp.
1988 FJ62
1999 Jeep Wrangler
I want an FZJ80 with minimal mall cruiser stuff, and F+R diff locks. Can trade jeep+cash, or just cash. Prefer OBD1.
Please i despertly need to get my 1FZ fix.
Never mind, I got an RX7 to play with this summer.
04-30-07, 10:59 PM
#110 (permalink)
I have two more leads now on machine shops locally that do bellhousing work including Marlin's supplier, who it turns out I actually know as he's a cruiserhead.. Also Kurt from CruiserOutfitters has some connections at the machine shop at the Univ. of Utah in the mechanical engineering school so there is a possibility there as well..
05-01-07, 12:27 AM
#111 (permalink)
Supporting Vendor
Yup, get me some dimensions and I can work with both of said machine shops (and another option I have for you too Andre).
Ideally we have both mating surfaces to take to the U, assuming my old Prof. will be open to trying it out, we can jig it up on the coordinate machine and pull some dimensions. From there we start entering them into Solidworks, after that it can be converted to machine code.
05-01-07, 07:35 AM
#112 (permalink)
Bellhousing/ adapter
Well my vote is for a bellhousing ring that will bolt up the the 4bd1t engine and give me a Chevy bolt pattern. I would think these would be the best selling item. If not a Chevy bolt then the next best would be an SAE, so I could bolt up an NV4500 from a Dodge.
Dieseltim
05-01-07, 09:34 PM
#113 (permalink)
That would be really nice. I have been wanting to convert a fj45lv but have not found a good canidate. 4BT or 6BT would be nice but rather not do a spring over.
05-03-07, 01:35 PM
#114 (permalink)
ok so who wants to help me out with what the three cables are on the injector pump of a 4BD1T?? i know the one that runs to the top of the engine is prolly throttle, but what about the other two?
found this to help with bellhousing IDhttp://www.garbee.net/~cabell/sae.htm
Clay
75 BDJ55- biopig
05-04-07, 01:04 AM
#115 (permalink)
Originally Posted by roscoFJ73
These engines also come in 4wd NPR. THe Isuzu t.case has the front drive shaftto the right like a LC and the rear, from memory,slightly to the right.
Lengthwise its similar to a LC.
Now it might be a pain procuring one in the US but would save some work further down the track
Does anyone know if the automatic would have and OD?
05-04-07, 06:04 AM
#116 (permalink)
control cables
Ok Rhino,
The cable that runs to the back of the engine at the top is the thottle, the one that is closest to the engine is the fuel shutoff (forward is on). The one to the outside I think is for the cruise control. Look at the 2nd pic I have posted above. Oh, thanks for the SAE number chart.
Dieseltim
05-04-07, 08:50 AM
#117 (permalink)
If anyone has a spare connecting rod Im going to need one for my 85 motor. Or if anyone has found any good prices for parts Id appreciate any info. Im sure its going to need much more but the rod bolt/cap broke off and rod is wedged between crank and block now. No apparent crack in block(crossing my fingers) so I hope it will be OK.
05-04-07, 03:26 PM
#118 (permalink)
dieseltim thanks for the info ! thats exactly what i thought. since i dont have the whole truck can you do me another favor, how does the fuel shutoff operate from isuzu? is the cable attached to an electric servo? i will prolly just run a push pull cable under the dash for a poor mans security feature.
Clay
75 BDJ55- biopig
05-06-07, 02:06 PM
#119 (permalink)
Urban Offroader
about the proposed isuzu adapter ring. Wouldent you also need to have some kind of flexplate/flywheel spacer the exact same thickness as the ring. I guess you would have to make it bolt to the crank, and then have your chevy bolts pattern on the other side.
Isint there already one of these rings being made?
A sidenote, if converting to isuzu power, can a stock gasoline fj62 fuel system be modified to work, or would it be better to buy a diesel system and bolt it in?
I have herd some talk about keeping the toyo AC pump and putting it on the isuzu, and thoughts there? What about getting a complete isuzu with alt, ps, ac, and just make some new lines to hook them up. How does the toyo ac pump turn on? Just a wire that hooks up to it?
-nate-
1991 T4R 5sp.
1988 FJ62
1999 Jeep Wrangler
05-06-07, 07:24 PM
#120 (permalink)
yeah the adapter is already out there for GM trannies, i have one and went back and forth with NV4500 but decided on a 700r4 behind my isuzu.
stock carburated gas system doesnt need to be modified, its just a tank and lines, if 62's have in tank pumps then you just need to remove it.
not sure why a toyo ac pump would need to be kept, the isuzu pump is the same style. maybe a different size? PS pump is built into the block and gear driven
based on my tape measure the round bellhousing on the isuzu engines is not any SAE.
Clay
75 BDJ55- biopig
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/128585-isuzu-4bd1t-swap.html
| Posted By |
For |
Type |
Date |
| isuzu 4BD1T swap?! on (4 Viewing) - Page 10 | BoardReader |
This thread |
Refback |
10-01-09 05:03 PM |
| GM Diesel into a CJ - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
08-27-09 10:48 AM |
| 1996 cummins diesel with frybrid- low power - Forums |
This thread |
Refback |
07-29-09 09:34 AM |
| Isuzu Alternator wiring? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
07-20-09 03:46 PM |
| 4BD1T enginen weight and max rpm - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
07-14-09 03:08 PM |
| isuzu 4BD1T swap?! on (4 Viewing) - Page 3 | BoardReader |
This thread |
Refback |
07-13-09 03:22 PM |
| 4BD1T 1970's F250 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
07-06-09 08:29 PM |
| Isuzu 4HE1 Swap on (4 Viewing) | BoardReader |
This thread |
Refback |
06-22-09 12:57 PM |
| 235 CID izuzu diesel questions. - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
05-07-09 08:01 PM |
| 4BD1A izuzu diesel. - Great Lakes 4x4. The largest offroad forum in the Midwest |
This thread |
Refback |
05-07-09 04:14 PM |
| isuzu 4BD1T swaps?! - Page 2 - Cummins 4BT & Diesel Conversions Forums |
Post #0 |
Refback |
05-02-09 08:23 PM |
| Diesel Engine Conversion Thread-Japanese Diesels - Page 2 - Binder Planet Forums |
This thread |
Refback |
04-21-09 02:40 PM |
| Toyota 4Runner 5 Speed Manual, Toyota 4 Runner, Toyota 4Runner Antenna - Argongas |
This thread |
Refback |
03-08-09 11:53 AM |
| Jeep Cj2A Bikini Top, Jeep Cj Exhaust Manifold Gasket Replacement, Jeep Cj5 Exhaust Flange - Polarisdiesel |
This thread |
Refback |
03-08-09 11:24 AM |
| 1994 Toyota T100 Suspencion System, 1994 Toyota Pickup Truck Starter Motor, 1994 Volkswagen Golf Iii Gl - Prestolitealternator |
This thread |
Refback |
03-08-09 11:09 AM |
| Ebay Maxima Headers, Ebay Chevelle Cars, Ebay Motorcycle Classifieds - Husqvarna345E |
This thread |
Refback |
03-08-09 06:21 AM |
| Isuzu Land Rover Conversion, Isuzu Incentives, Isuzu Marine Diesel Engines - Belizelifestyle |
This thread |
Refback |
03-08-09 06:20 AM |
| 1991 Jeep Wrangler Ignition Problems, 1991 Jeep Cherokee Trouble Shhoting Forum, 1991 Kawasaki Ninga Zx11 Repair Manual - Lightningfire |
This thread |
Refback |
03-08-09 06:11 AM |
| 1986 Lincoln Mark Conversion, 1986 Kawasaki Voyager, 1986 Mercedes 300E Overdrive - Mastercraftavenger |
This thread |
Refback |
03-08-09 06:10 AM |
| Isuzu Cgiworld, Isuzu Car Parts, Isuzu Charleston Sc - Lightningrods |
This thread |
Refback |
03-08-09 05:23 AM |
| Yamaha V Star Tire Pressure, Yamaha V Star Motorcycle, Yamaha Venture Accessories - Titangenerator |
This thread |
Refback |
03-08-09 03:26 AM |
| Mercedes Sl Rocker Panel, Mercedes Sl Gas Fuel Gauge, Mercedes Sl55 - Venetianmirrors |
This thread |
Refback |
03-08-09 01:16 AM |
| Motorcycle Rodeo, Motorcycle Rocket Jackets, Motorcycle Routes Arizona - Yamahacanada |
This thread |
Refback |
03-08-09 12:22 AM |
| Heavy Duty Truck Parts, Heavy Duty Fuel Parts Injector, Heavy Duty Truck Tire Service In Minnesota - Ktmgirls |
This thread |
Refback |
03-07-09 01:50 AM |
| 68 Chevy Truck Phantom Billet Grille, 68 Chevrolet C10 Original Rear Suspention, 68 Firebird Parts - Csahb |
This thread |
Refback |
03-07-09 01:19 AM |
| Ford Truck Exhaust Manifold Leak, Ford Truck Clutch Kits, Ford Truck Front Fenders My My Messages - Polarisclothing |
This thread |
Refback |
03-06-09 02:04 AM |
| Used Cars Carson City Nv, Used Cars Calgary, Used Cars Chicago - Thermostatwikipedia |
This thread |
Refback |
03-06-09 01:47 AM |
| Suggestions Please on next vehicle... - Page 3 - Expedition Portal Forum |
This thread |
Refback |
02-08-09 10:21 AM |
| Isuzu Clutch Disk Compatibility - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-30-09 01:57 PM |
| 1997 Landcruiser conversion - ToyotaDiesel.com |
This thread |
Refback |
01-28-09 10:41 PM |
| Land Rover with Isuzu diesel engine swap - ToyotaDiesel.com |
This thread |
Refback |
01-13-09 12:36 AM |
| What about Isuzu 2.8 TD's? - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
12-10-08 06:25 AM |
| Land Rover with Isuzu diesel engine swap - ToyotaDiesel.com Forums |
This thread |
Refback |
10-27-08 08:59 AM |
| isuzu - internet discussions | BoardReader |
This thread |
Refback |
08-25-08 07:26 PM |
| 1st post, t100 conversion? - ToyotaDiesel.com Forums |
This thread |
Refback |
07-28-08 11:43 AM |
| isuzu 4BD1T swaps?! - Page 3 - Cummins 4BT Forums |
Post #0 |
Refback |
07-26-08 09:32 PM |
| New here. Isuzu 4HE1-T conversion - Australian Land Rover Owners |
This thread |
Refback |
07-07-08 05:16 PM |
| new old truck... |
This thread |
Refback |
07-06-08 10:19 AM |
| new old truck... |
This thread |
Refback |
07-05-08 06:32 PM |
| isuzu 4BD1T swap?! on (4 Viewing) | BoardReader |
This thread |
Refback |
06-20-08 05:44 PM |
| 4bd2tc into cj7 w/NV4500/dana300 without dual flywheels - Cummins 4BT Forums |
This thread |
Refback |
06-04-08 08:59 AM |
| Build-up: Jeep YJ w/ Isuzu diesel - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
05-19-08 09:17 PM |
This thread |
Refback |
05-15-08 07:22 PM |
| Cars world :: Isuzu :: BoardReader |
This thread |
Refback |
05-15-08 06:37 PM |
| Possible Diesel Combo In 1500 - FSC Forum |
This thread |
Refback |
04-24-08 04:53 PM |
| Outer Limits 4x4 Board :: View topic - County engine options |
This thread |
Refback |
04-22-08 06:02 AM |
| Swapping a TDI into a Land Rover - TDIClub Forums |
This thread |
Refback |
04-04-08 09:27 AM |
| 4bd1t/2t vs. 4bt - Cummins 4BT Forums |
This thread |
Refback |
04-02-08 04:37 AM |
| 1997 Landcruiser conversion - ToyotaDiesel.com Forums |
This thread |
Refback |
03-30-08 02:38 PM |
| STICKY: Isuzu 4BD1T/4BD2T Reference - Cummins 4BT Forums |
This thread |
Refback |
03-25-08 09:13 PM |
This thread |
Refback |
03-22-08 05:54 PM |
This thread |
Refback |
03-22-08 05:54 PM |
This thread |
Refback |
03-22-08 02:14 PM |
| 4BD1T 1970's F250 - Cummins 4BT Forums |
This thread |
Refback |
03-10-08 06:23 AM |
| Diesel Engine Conversion Thread-Japanese Diesels - Page 2 - Binder Bulletin Forums |
This thread |
Refback |
03-09-08 12:09 PM |
| Other Great Isuzu 4BD1T Sources - Cummins 4BT Forums |
This thread |
Refback |
03-09-08 11:13 AM |
| isuzu 4BD1T swaps?! - Cummins 4BT Forums |
This thread |
Refback |
03-03-08 04:27 PM |
| Untitled document |
This thread |
Refback |
02-26-08 05:57 PM |
This thread |
Refback |
02-10-08 09:24 PM |
This thread |
Refback |
02-08-08 05:40 AM |
This thread |
Refback |
02-05-08 09:28 AM |
| Isuzu 4BD diesels.. New forum... - Expedition Portal Forums |
This thread |
Refback |
02-01-08 10:17 AM |
This thread |
Refback |
01-31-08 09:13 PM |
This thread |
Refback |
01-31-08 05:47 PM |
This thread |
Refback |
01-31-08 03:44 PM |
| solenoid isuzu :: BoardReader |
This thread |
Refback |
01-23-08 04:17 PM |
| Madcowdungbeetle builds a rover... - Page 3 - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
01-18-08 12:36 PM |
This thread |
Refback |
01-15-08 07:35 PM |
This thread |
Refback |
01-10-08 07:54 AM |
This thread |
Refback |
01-08-08 08:19 PM |
| Untitled document |
This thread |
Refback |
01-06-08 05:57 PM |
| Untitled document |
This thread |
Refback |
12-28-07 05:36 AM |
This thread |
Refback |
12-24-07 07:18 PM |
This thread |
Refback |
12-24-07 03:48 AM |
| Untitled document |
This thread |
Refback |
12-22-07 12:21 PM |
| 4BD1T swap in a Tundra?? - Cummins 4BT Forums |
This thread |
Refback |
12-21-07 02:22 PM |
This thread |
Refback |
12-18-07 11:18 AM |
This thread |
Refback |
12-16-07 08:53 PM |
