LinkBack (78) Thread Tools Display Modes
Old 11-10-08, 02:11 PM   1 links from elsewhere to this Post. Click to view. #811 (permalink)
euclid's Avatar
TLCA# 13014
Did you keep an acounting of your time and cost? Care to share?
Greg Thompson
89 FJ62, Unstock.
euclid is offline   Reply With Quote
Old 11-10-08, 08:02 PM   #812 (permalink)
83 chif's Avatar
not sure if this is news to anyone but....
this may have been covered before, i'm not sure, but i figured i'd share just incase it's news to anyone else besides me. apparently the 4bd can be/came bolted to ford c6s, which I think was offered as a 4wd trans too, or atleast has the same bellhousing as other ford 4wd transmissions. maybe this particular ford tranny has an industrial bell housing or some other possibility that i'm not aware of, but like i said, just incase this went un noticed before....
eBay Motors: Isuzu 4DB1 Diesel Engine W/ C6 Transmission included (item 270300739565 end time Nov-17-08 05:51:13 PST)
ugly red 89' 4Runner, 5spd, 22re, BFG AT's, some rhino liner, a butt-load of stickers, and a Superwinch EP9
83 chif is offline   Reply With Quote
Old 11-11-08, 12:00 PM   #813 (permalink)
Careful.Only the non-turbo 4bd has a sae#3 pattern.The turbo 4, 4bd1t, has a unique, non sae pattern.That being said, I used this combo in a Ford van.I think if you were conservative you could add a turbo to this e bay engine and have a good candidate for a swap.
coog is offline   Reply With Quote
Old 11-11-08, 09:03 PM   #814 (permalink)
It's not a turbo/non turbo split on the bellhousings.
It's truck sourced engines vs industrial engines. The industrial ones have the SAE housing.
Having said that, the bellhousing in that photo appears to be the truck version and has a big adapter plate bolted to it. Possibly a variation on the Isuzudieselswapper kit.
The engine itself is an industrial unit (note the large side mounted breather, lack of oil supply to the injector pump gear, no acoustic covers and the flat rocker cover).
Old 11-12-08, 07:58 AM   #815 (permalink)
Agreed, although in the States it amounts to the same thing.I just wanted to nip the rumor in the bud before anyone spends money based on it.The SAE to Ford C-6 adaptor is available through Phoenix Castings, should anyone want to use the industrial engine.
Old 11-12-08, 03:43 PM   #816 (permalink)
RHINO's Avatar
i've said it before, i'll say it again. dieselswappers kit is a modified phx casting kit, any vehicle tranny behind any isuzu, sae or not is a phx casting kit. nothing bolts right to the engine except an isuzu tranny.
the ebay item above is made possible via a phx casting kit, you can see the tranny has fords pattern still.
88TLC, its great to have another running driving cruiser with an isuzu on the board !!
Clay
75 BDJ55- biopig
Old 11-12-08, 04:48 PM   #817 (permalink)
Not on this engine.The only tranny that will bolt up without an adapter is a SAE#3 pattern (Allison comes to mind).The adapter is to convert from a SAE to C6.The 4bd1 that I have is a 1980, and I don't think the Isuzu 5 speed arrived until 1986.The Aisin auto appeared a year or two later.
note: I should have said "not on this Flywheel cover", as the engine back pattern is the same.
Old 11-12-08, 06:16 PM   #818 (permalink)
It appears there are four main types of bellhousings.
1. Isuzu truck bellhousing. This is similar size to SAE #3 but has different bolt spacing. The bottom of the
Different markets and years give variants with the 2 or 3 bolt starter.
2. Isuzu industrial bellhousing. This is SAE #3 and noticably longer than the truck bellhousing. It features four bolt mount holes on each side.
3. Isuzu QD100 bellhousing. This is the model name the 4BD1 was originally introduced to NA under. It appears identical length to the truck bellhousing, but has a lip that extends right around underneath and has a drain plug fitted to the bottom.
I expect this is the one Coog has. It could be the one in the ebay ad, but I'd need better photos.
4. Landrover bellhousing. I haven't yet mapped out the pattern for this (though a helpful gentleman has sent me the measurements), it mounts the starter up higher than the Isuzu bellhousings to clear the landrover chassis rail. They bolt up to landrover LT95 or LT85 transmissions. Originally developed for the Australian Army but also sold in civilian landrovers in the late 80's in the pacific region.
Old 11-12-08, 06:39 PM   #819 (permalink)
Bellhousing photo lineup with descriptions are here:
Isuzu 4BD1 Bell-housings. - Cummins 4BT & Diesel Conversions Forums
Old 01-26-09, 08:35 PM   #820 (permalink)
hayes167's Avatar
Progress on 4bd1t in a 91' fj80
I've got the engine sitting in the bay in the place I want it. I thought I'd post pics and show the clearence. Motor mounts should be done in a couple of weeks. It is in position to use stock driveshaft lengths. It seems like the fj60 bay may hold this engine with more room. Some clearence issues: ofset to passenger side 3/4"- puts the oil pan closer to the diff, 2.5-3" oil pan to diff, starter to frame 3/4", front of engine to radiator, without fan 2", top front of engine to hood 2", air intake to firewall 3". I could probably move the engine back 2-5" depending on if I wanted to reroute the air intake on the turbo and/or get the drive shafts cut, read cost in time $ and motivation.I had wanted to install an air air intercooler in the front but not with 2", mabey I'll do a air water intercooler. I think that more lift would be nice. I have 850 OME right now.
'91 FJ80 in the middle of 4BD1T swap, OME lift.
Pain is inescapeable, suffering is optional!
hayes167 is offline   Reply With Quote
Old 01-26-09, 08:37 PM   #821 (permalink)
hayes167's Avatar
fj80 4bd1t
Here are more pics.
Old 01-27-09, 12:08 PM   #822 (permalink)
cool project. If the air-intake tube was removed... could the engine sit further back? But, I guess then it would be hard to get filtered air into the turbo. BUT, you could clearance the firewall at just that point (where the bend comes into the turbo).
Don't be afraid to cut and clearance the oil pan. It isn't hard, and on my 4BT project it made all the difference.
are you running a 700R4 to stock xfer case?
gifu is offline   Reply With Quote
Old 01-27-09, 01:21 PM   #823 (permalink)
jeffsclan's Avatar
TLCA# 16057
That's really going to be a neat rig. Stay with it. It will be so worth it in the long run.
" I'm still pissed about the Lincoln Lamp ! " 1983 FJ60 Weber carb, Aussie locker, H55F, Homemade bumpers and rock rails, winch, headers, OME Dakar springs, Saginaw ps, smog pump AWOL, 33/12.5s, 4.56s, York OBA, Camo,
1993 FZJ80 "Backbone" (wifes)
jeffsclan is offline   Reply With Quote
Old 01-27-09, 02:17 PM   #824 (permalink)
FL cruiser's Avatar
How about mounting the intercooler flat horizontal across the valve cover with the top level with the hood. Then cut an opening in the hood and have a hood scoop. I know the hood scoop sounds hokey, but non US spec Nissan terrano's and Hyundai Galloper's (Montero clones) do it that way.
That's how I plan to do it on my 60. I guess it's easier to hack a hood on an old beater 60 than a nice clean 80 though.
82 FJ60 Trail Rig. topless, Caged, 4BD2T diesel turbo & intercooler, H55, Toybox, SUA, 37" MTR's,
83 JJ60. Daily driver, OME, 33's, 6.2 diesel, NV4500, WVO
http://mysite.verizon.net/sbutman1/LC.html
FL cruiser is offline   Reply With Quote
Old 01-27-09, 02:32 PM   #825 (permalink)
FL cruiser's Avatar
Engine Kits
I'm hoping to get feedback from those of you that used aftermarket engine kits on your Isuzu 4BD**'s.
How have they fared? Quality acceptable?
I'm hoping to get some input before I purchase a kit.
Rudy's kit is mentioned on the Isuzudieselswapper site and sold on Ebay.
Not many other aftermarket Isuzu parts being sold in the US.
Some people over on the 4BT Swap Forums looking for input too. Figured I'd cross post over here.
Old 01-29-09, 06:42 AM   #826 (permalink)
hayes167's Avatar
I got my bearings and gasket set straight from Isuzu. I have heard not to use aftermarket stuff. Dougal had a bad/expensive problem with some.
I think I like where the engine is, not cutting drive shafts, centered in the engine bay, really being ready for the motor mounts to get wielded so I can get on with the project.
There is no room atop the engine for an intercooler, the front of the engine is 1.5" from the hood.
Old 01-29-09, 12:21 PM   #827 (permalink)
I've had issues with aftermarket rings, headgaskets and oil seals. If you can get genuine gasket sets, then do it. The price is excellent and you know everything fits.
I'm currently running aftermarket main & thrust bearings, liners and pistons. I haven't had a problem with any of those and I'm not expecting to.
Old 01-30-09, 12:48 PM   #828 (permalink)
ThePookieBear's Avatar
hayes167- Congratulations on the build! It's actually kind of a downer for me because I had planned on going with the 4HE1 mounted to my A440. It is less than an inch taller, and only an inch wider than the 4BD2T. But... It's fourteen inches longer. Something that I didn't think would be a problem with our long I6's, but I was sadly mistaken. :(. I'll have to do some more research and all that business. Oh well. I don't see how they can shoehorn a 6BT in, and the 4HE1 won't fit. I'll get it, I guess it will be harder now. . Congrats.
1992 FJ80, stock except brush guard , and BF Goodrich AT 33's.
"Don't be too quick to associate vodka with Communism."
Landrovers: "I don't understand why everything is not easy to reach on these as everything needs to be reached fairly often... "
ThePookieBear is offline   Reply With Quote
Old 01-31-09, 03:41 PM   #829 (permalink)
astr's Avatar
Originally Posted by ThePookieBear View Post
... I had planned on going with the 4HE1 mounted to my A440. It is less than an inch taller, and only an inch wider than the 4BD2T. But... It's fourteen inches longer...
I don't understand why you say that the 4HE1 is 14 inches longer than the 4BD2. I just measured the 4HE1 and it is almost exactly 30" from the front of the water pump to the rear surface that the transmission mounts to. The 4BD2 measures within a 1/4" of this measurement. Are you including the length of the rear-mounted starter in your measurement? I agree that the starter poses an interference problem and will need to be relocated somehow.
Stock FJ62
SOA Samurai Tintop
Ford E-350 4x4 Diesel
M-29 Weasel
astr is offline   Reply With Quote
Old 01-31-09, 10:51 PM   #830 (permalink)
Yes I was, but I may still be off. I was getting my measurement from one of the pages somewhere out there on the intraweb... . My bad. Ha ha! So, how is your swap coming along? I noticed the other day on the 4BT sight that you're fitting a probe, or preparing to. Whittling down the to do list ehh? And I'm glad that it is not out of sight long compared to the 4BD2. . I guess I just got bad info. I still foresee some fancy metal work in the pedal area though with that blasted starter sitting oddly. It will probably interfere with the frame.
Old 02-01-09, 10:34 AM   #831 (permalink)
astr's Avatar
The 4HE1 is still in the NPR chassis. I'm going to resolve the transmission/T-case issue first and it is easier to do in the NPR chassis. Once I get a T-case on the AW450/A440F hybrid transmission and verify that it works, I'll pull the 3FE and start fitting the 4HE1 in the FJ62. Still a long way to go especially at the speed that I move
Stock FJ62
SOA Samurai Tintop
M-29 Weasel
Old 02-01-09, 11:10 AM   #832 (permalink)
Ha ha. Too bad you don't live in Kansas, I'd throw down an extra hand whenever you needed it. . You mentioned relocating the starter... How were you thinking on doing that? Like a flywheel out front with custom bracketry or something of that nature?
Old 02-02-09, 07:56 AM   #833 (permalink)
astr's Avatar
Haven't addressed that issue. When I get further along, I'll resurect the 4HE1 thread on this forum.
Stock FJ62
SOA Samurai Tintop
M-29 Weasel
Old 02-02-09, 08:00 AM   #834 (permalink)
Cool deal. Keep us posted.
Old 02-07-09, 07:59 AM   #835 (permalink)
warpdriv's Avatar
Has anyone looked to see if Isuzu offers a crate engine?
Jeff Blumenthal
TLCA# 9883
KE5RST
Austin, Tx
1/71 FJ40 Dulcinea 350/700R4/NP203/TLC3SP/SO/FSR/RSR/RSHR
95 FZJ80 DeFlared, DeRunning Boarded, 33s, more to come
www.lslc.org/austin
warpdriv is offline   Reply With Quote
Old 02-07-09, 09:08 AM   #836 (permalink)
Rookie
Subscribed!
This is exactly what I'd like to do! I killed WAY too much time yesterday reading the whole thread, and am subscribing. Thanks to Dougal, astr, RHINO, DieselCruiserHead, 88tlc, BRam... Hell, all of you for contributing your great knowledge, insight, and ideas!
My wife, however, may be less happy....
Los
1speedlos is offline   Reply With Quote
Old 02-08-09, 09:23 AM   #837 (permalink)
RHINO's Avatar
i think this thread got way bigger than any of us thought it would. as you pointed out it takes a looooong time to read the whole thing, but its practically a one stop shop for isuzu info.
Clay
75 BDJ55- biopig
Old 02-26-09, 07:13 PM   #838 (permalink)
FL cruiser's Avatar
I'm attempting to determine if a single Optima red top would be sufficient for starting a 4BD*. Anyone using a single battery??
Old 02-26-09, 07:57 PM   #839 (permalink)
bj74_guy?
bj70_guy's Avatar
TLCA# 6257
My Dad just finished putting a 4BD1-T into a Chev Tahoe (yes, I tried to get him to put it in an 80 instead...)
His is starting his fine with one of my old red tops.
norm
Coastal Cruisers
'85 BJ70, '89 BJ74, '92 M101cdn
bj70_guy is offline   Reply With Quote
Old 02-27-09, 12:39 PM   #840 (permalink)
RHINO's Avatar
mines going strong for over a year now with a single red top.
Clay
75 BDJ55- biopig
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/128585-isuzu-4bd1t-swap.html
Posted By For Type Date
isuzu 4BD1T swap?! on (4 Viewing) - Page 10 | BoardReader This thread Refback 10-01-09 05:03 PM
GM Diesel into a CJ - Pirate4x4.Com Bulletin Board This thread Refback 08-27-09 10:48 AM
1996 cummins diesel with frybrid- low power - Forums This thread Refback 07-29-09 09:34 AM
Isuzu Alternator wiring? - Cummins 4BT & Diesel Conversions Forums This thread Refback 07-20-09 03:46 PM
4BD1T enginen weight and max rpm - Cummins 4BT & Diesel Conversions Forums This thread Refback 07-14-09 03:08 PM
isuzu 4BD1T swap?! on (4 Viewing) - Page 3 | BoardReader This thread Refback 07-13-09 03:22 PM
4BD1T 1970's F250 - Cummins 4BT & Diesel Conversions Forums This thread Refback 07-06-09 08:29 PM
Isuzu 4HE1 Swap on (4 Viewing) | BoardReader This thread Refback 06-22-09 12:57 PM
235 CID izuzu diesel questions. - Pirate4x4.Com Bulletin Board This thread Refback 05-07-09 08:01 PM
4BD1A izuzu diesel. - Great Lakes 4x4. The largest offroad forum in the Midwest This thread Refback 05-07-09 04:14 PM
isuzu 4BD1T swaps?! - Page 2 - Cummins 4BT & Diesel Conversions Forums Post #0 Refback 05-02-09 08:23 PM
Diesel Engine Conversion Thread-Japanese Diesels - Page 2 - Binder Planet Forums This thread Refback 04-21-09 02:40 PM
Toyota 4Runner 5 Speed Manual, Toyota 4 Runner, Toyota 4Runner Antenna - Argongas This thread Refback 03-08-09 11:53 AM
Jeep Cj2A Bikini Top, Jeep Cj Exhaust Manifold Gasket Replacement, Jeep Cj5 Exhaust Flange - Polarisdiesel This thread Refback 03-08-09 11:24 AM
1994 Toyota T100 Suspencion System, 1994 Toyota Pickup Truck Starter Motor, 1994 Volkswagen Golf Iii Gl - Prestolitealternator This thread Refback 03-08-09 11:09 AM
Ebay Maxima Headers, Ebay Chevelle Cars, Ebay Motorcycle Classifieds - Husqvarna345E This thread Refback 03-08-09 06:21 AM
Isuzu Land Rover Conversion, Isuzu Incentives, Isuzu Marine Diesel Engines - Belizelifestyle This thread Refback 03-08-09 06:20 AM
1991 Jeep Wrangler Ignition Problems, 1991 Jeep Cherokee Trouble Shhoting Forum, 1991 Kawasaki Ninga Zx11 Repair Manual - Lightningfire This thread Refback 03-08-09 06:11 AM
1986 Lincoln Mark Conversion, 1986 Kawasaki Voyager, 1986 Mercedes 300E Overdrive - Mastercraftavenger This thread Refback 03-08-09 06:10 AM
Isuzu Cgiworld, Isuzu Car Parts, Isuzu Charleston Sc - Lightningrods This thread Refback 03-08-09 05:23 AM
Yamaha V Star Tire Pressure, Yamaha V Star Motorcycle, Yamaha Venture Accessories - Titangenerator This thread Refback 03-08-09 03:26 AM
Mercedes Sl Rocker Panel, Mercedes Sl Gas Fuel Gauge, Mercedes Sl55 - Venetianmirrors This thread Refback 03-08-09 01:16 AM
Motorcycle Rodeo, Motorcycle Rocket Jackets, Motorcycle Routes Arizona - Yamahacanada This thread Refback 03-08-09 12:22 AM
Heavy Duty Truck Parts, Heavy Duty Fuel Parts Injector, Heavy Duty Truck Tire Service In Minnesota - Ktmgirls This thread Refback 03-07-09 01:50 AM
68 Chevy Truck Phantom Billet Grille, 68 Chevrolet C10 Original Rear Suspention, 68 Firebird Parts - Csahb This thread Refback 03-07-09 01:19 AM
Ford Truck Exhaust Manifold Leak, Ford Truck Clutch Kits, Ford Truck Front Fenders My My Messages - Polarisclothing This thread Refback 03-06-09 02:04 AM
Used Cars Carson City Nv, Used Cars Calgary, Used Cars Chicago - Thermostatwikipedia This thread Refback 03-06-09 01:47 AM
Suggestions Please on next vehicle... - Page 3 - Expedition Portal Forum This thread Refback 02-08-09 10:21 AM
Isuzu Clutch Disk Compatibility - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-30-09 01:57 PM
1997 Landcruiser conversion - ToyotaDiesel.com This thread Refback 01-28-09 10:41 PM
Land Rover with Isuzu diesel engine swap - ToyotaDiesel.com This thread Refback 01-13-09 12:36 AM
What about Isuzu 2.8 TD's? - Pirate4x4.Com Bulletin Board This thread Refback 12-10-08 06:25 AM
Land Rover with Isuzu diesel engine swap - ToyotaDiesel.com Forums This thread Refback 10-27-08 08:59 AM
isuzu - internet discussions | BoardReader This thread Refback 08-25-08 07:26 PM
1st post, t100 conversion? - ToyotaDiesel.com Forums This thread Refback 07-28-08 11:43 AM
isuzu 4BD1T swaps?! - Page 3 - Cummins 4BT Forums Post #0 Refback 07-26-08 09:32 PM
New here. Isuzu 4HE1-T conversion - Australian Land Rover Owners This thread Refback 07-07-08 05:16 PM
new old truck... This thread Refback 07-06-08 10:19 AM
new old truck... This thread Refback 07-05-08 06:32 PM
isuzu 4BD1T swap?! on (4 Viewing) | BoardReader This thread Refback 06-20-08 05:44 PM
4bd2tc into cj7 w/NV4500/dana300 without dual flywheels - Cummins 4BT Forums This thread Refback 06-04-08 08:59 AM
Build-up: Jeep YJ w/ Isuzu diesel - Pirate4x4.Com Bulletin Board This thread Refback 05-19-08 09:17 PM
Build-up: Jeep YJ w/ Isuzu diesel - Pirate4x4.Com Bulletin Board This thread Refback 05-15-08 07:22 PM
Cars world :: Isuzu :: BoardReader This thread Refback 05-15-08 06:37 PM
Possible Diesel Combo In 1500 - FSC Forum This thread Refback 04-24-08 04:53 PM
Outer Limits 4x4 Board :: View topic - County engine options This thread Refback 04-22-08 06:02 AM
Swapping a TDI into a Land Rover - TDIClub Forums This thread Refback 04-04-08 09:27 AM
4bd1t/2t vs. 4bt - Cummins 4BT Forums This thread Refback 04-02-08 04:37 AM
1997 Landcruiser conversion - ToyotaDiesel.com Forums This thread Refback 03-30-08 02:38 PM
STICKY: Isuzu 4BD1T/4BD2T Reference - Cummins 4BT Forums This thread Refback 03-25-08 09:13 PM
4bd1t/2t vs. 4bt - Cummins 4BT Forums This thread Refback 03-22-08 05:54 PM
4bd2tc into cj7 w/NV4500/dana300 without dual flywheels - Cummins 4BT Forums This thread Refback 03-22-08 02:14 PM
4BD1T 1970's F250 - Cummins 4BT Forums This thread Refback 03-10-08 06:23 AM
Diesel Engine Conversion Thread-Japanese Diesels - Page 2 - Binder Bulletin Forums This thread Refback 03-09-08 12:09 PM
Other Great Isuzu 4BD1T Sources - Cummins 4BT Forums This thread Refback 03-09-08 11:13 AM
isuzu 4BD1T swaps?! - Cummins 4BT Forums This thread Refback 03-03-08 04:27 PM
Untitled document This thread Refback 02-26-08 05:57 PM
4bd2tc into cj7 w/NV4500/dana300 without dual flywheels - Cummins 4BT Forums This thread Refback 02-10-08 09:24 PM
Diesel Engine Conversion Thread-Japanese Diesels - Page 2 - Binder Bulletin Forums This thread Refback 02-08-08 05:40 AM
4bd2tc into cj7 w/NV4500/dana300 without dual flywheels - Cummins 4BT Forums This thread Refback 02-05-08 09:28 AM
Isuzu 4BD diesels.. New forum... - Expedition Portal Forums This thread Refback 02-01-08 10:17 AM
4bd2tc into cj7 w/NV4500/dana300 without dual flywheels - Cummins 4BT Forums This thread Refback 01-31-08 09:13 PM
4bd2tc into cj7 w/NV4500/dana300 without dual flywheels - Cummins 4BT Forums This thread Refback 01-31-08 05:47 PM
4bd2tc into cj7 w/NV4500/dana300 without dual flywheels - Cummins 4BT Forums This thread Refback 01-31-08 03:44 PM
solenoid isuzu :: BoardReader This thread Refback 01-23-08 04:17 PM
Madcowdungbeetle builds a rover... - Page 3 - Pirate4x4.Com Bulletin Board This thread Refback 01-18-08 12:36 PM
Build-up: Jeep YJ w/ Isuzu diesel - Pirate4x4.Com Bulletin Board This thread Refback 01-15-08 07:35 PM
Build-up: Jeep YJ w/ Isuzu diesel - Pirate4x4.Com Bulletin Board This thread Refback 01-10-08 07:54 AM
Build-up: Jeep YJ w/ Isuzu diesel - Pirate4x4.Com Bulletin Board This thread Refback 01-08-08 08:19 PM
Untitled document This thread Refback 01-06-08 05:57 PM
Untitled document This thread Refback 12-28-07 05:36 AM
Cars world :: Isuzu :: BoardReader This thread Refback 12-24-07 07:18 PM
Swapping a TDI into a Land Rover - TDIClub Forums This thread Refback 12-24-07 03:48 AM
Untitled document This thread Refback 12-22-07 12:21 PM
4BD1T swap in a Tundra?? - Cummins 4BT Forums This thread Refback 12-21-07 02:22 PM
Other Great Isuzu 4BD1T Sources - Cummins 4BT Forums This thread Refback 12-18-07 11:18 AM
isuzu 4BD1T swaps?! - Cummins 4BT Forums This thread Refback 12-16-07 08:53 PM
