LinkBack (78) Thread Tools Display Modes
Old 08-06-08, 02:10 PM   4 links from elsewhere to this Post. Click to view. #781 (permalink)
dieselcruiserhead's Avatar
TLCA# 9439
good stuff here guys as always
Excited for that turbo to show up Bill!
- Cummins 4BTswaps.com Forums
- Hazard Assembly Dirtbag Adventuring Community
- Diesel Conversion Website
TLCA# 9439 Since 1999, Wasatch Cruisers
'89 Toyota Pickup V6, OME, 33x10.5's
'69 FJ55 Project on locked FZJ80 Frame, Cummins 4BT, NV5600, Dana 300
dieselcruiserhead is offline   Reply With Quote
Old 08-06-08, 02:18 PM   #782 (permalink)
Dougal... can you remind me what Turbo you are running? And how much did you turn up the fuel? Did you advance the pump timing? I remember you saying something about 1500F EGT before turbo (maybe you posted in C, can't remember).
gifu is offline   Reply With Quote
Old 08-06-08, 03:21 PM   #783 (permalink)
I'm running a garrett T25 with a 0.49 A/R turbine housing. I run EGT's up to 750C pre turbo.
I'm afraid I've lost all reference to what the fuel pump should have been set at. My fuel pump has the boost device (aneroid) on the back which was leaking for a long time. At the last shop rebuild (pushing 10 years ago now) they adjusted the fuel up to deliver the required amount when the aneroid was leaking.
So when I fixed the aneroid leak I got massive amounts of fuel. I've since turned the fuel screw down by around 2 turns and still back off the pedal to keep the EGT's under that 750C limit at altitude and on sustained hills.
I have my aneroid adjusted so there's no black smoke visible when driving it. This does put a damper on the low end response a little, but preventing pollution is worth it IMO.
Old 08-06-08, 06:18 PM   #784 (permalink)
ah... 750C is... 1350F. From what I understand, that's pretty darn hot. Not quite enough to do damage, unless it stays at that level for a long time.
and is that in a Rover? What transmission is behind it? Auto or stick?
I'm really interested to see/feel/drive the difference between a pumped up 4BD1T and a 1HDT or 1HZ(t). Too bad neither really exist around here.
Old 08-07-08, 02:24 AM   #785 (permalink)
Yes it's in a rangerover with the Isuzu truck gearbox behind it (5 speed). Slow shifting box but bullet proof.
There's a big difference in feel between these engines and the toyota 6's. These are thumpers, massive low end which tapers off to not much high end.
The toyotas are mostly the opposite, they'll happily spin up way past the Isuzu's rev limit but don't have the low rpm punch.
Yes 750 is as hot as you ever want to go, but I find that with that much power you don't end up using all of it for very long. The average hill is dispatched in under a couple of minutes. You'd need to be towing or living in the alps to need more in which case 600 or so is a sensible sustained load.
Old 09-12-08, 04:40 PM   #786 (permalink)
88_TLC... any update? Did you get that upgraded Turbo? Success? Or still powerless?
Old 09-29-08, 07:47 PM   #787 (permalink)
Rookie
Sorry it took me so long guys I was formerly AJ60 but couldnt remeber my password and forgot my pasword to my old e-mail address(major brain fart). On top of that I have been knee deep in my conversion and just finished last week. I have a BeCool radiator with a SPAL 14" fan, 86' 4BD1T with 42K orig miles to a (I know you guys are going to hate this but I love it) TH400. It just wants to pull. I love this thing its a monster even dispite the lack of a OD which I have a plan for later on. If you guys are interested in some pics let me know. By the way the engine is sitting on a FJ60 with a 6" suspension lift 33" BFGs, and FOX Shocks all the way around, shackle reversel. I tried to hit the oil pan with the front pumpkin yesterday and couldnt its awesome.
What can I say 'I LOVE THIS THING'.
SUZU60 is offline   Reply With Quote
Old 09-29-08, 11:48 PM   #788 (permalink)
You're making us ask?
Hurry up with the pics.
Old 09-30-08, 09:46 AM   #789 (permalink)
4bd1t turbo upgrade
the turbo upgrade on the 4bd1t is finished and took it up the 'tester hill' . it has much more power, more boost, and runs cooler because of getting more air.
the turbo I used was a T3 built by blaastperformance.com.
t3 t50 turbo
turbine .48a/r, 68 trim.
compressor .42 a/r, 42.5/60.1 50 trim
I had to replumb everything. new hoses and fittings for the coolant, new stainless line for the oil feed, and reused the metal hardline with a new fitting for the oil out, and welded in a new fitment. also had to reweld the cast exhaust-out onto the wastegate flange of the turbo. so all this took a fair bit of headscratching, and build.
And while I had the landcruiser offline, I decided to do a bunch of other needed work
birfield rebuild, new bearings, new calipers.
new brakelines
added a dieseltherm unit into the diesel inlet on the filter, sweet for antigelling and cold weather and helps be able to use biodiesel blends.
added a new fuse box for all power, removing a bunch of leads going straight to the battery.
but the turbo does great. I can hear it whining at idle, i can get 5-8 pounds of boost almost immediately, and wind it out, I get 15-18psi. egts now max out at about 1100, and this is now preturbo!
some images of the mod.
88 FJ62, [ ][ ]=TOYOTA=[ ][ ]
with Isuzu 4BD1t...Its a diesel...
build thread http://forum.ih8mud.com/diesel-tech-...bd1t-swap.html
1997 FJ80, 40TH ANNIVERSARY
cummins diesel, running wvo
88tlc is offline   Reply With Quote
Old 09-30-08, 03:08 PM   #790 (permalink)
Excellent news.
So just to get a benchmark for this turbo, how many rpm until it deliveres say 10psi boost and how much earlier is this than the original?
Do you know your boost and EGT figures at a 100km/h flat road cruise?
Old 09-30-08, 05:23 PM   #791 (permalink)
Rookie
I ll post them on sunday, ill be off island until then.
Old 10-01-08, 04:41 PM   #792 (permalink)
Excellent news.
i have not taken it yet on a road trip. need to get the exhaust pipe put back together, right now it is cut just infront of the muffler. Good metrics to define, i will comment back when I return to the shop, but that will be late OCT. Traveling in asia at the moment.
Old 10-06-08, 01:58 PM   #793 (permalink)
Rookie
Here are some pics of my latest conversion. 4BD1-T into a 85' FJ60.
Old 10-06-08, 11:03 PM   #794 (permalink)
Cool, so that's the mid 80's version with the IHI turbo? What are the other details.
Old 10-07-08, 07:45 PM   #795 (permalink)
Rookie
The conversion consist starting from the front,
1. Spal fan 14"
2. Be Cool radiator 26" x 18"
3. 86' 4BD1-T w/IHI turbo 2 1/2" exaust to a 40series muffler
4. IDS kit w/the steel adapter ring 5/8" thick.
5. 6 bolt TQ converter
6. TH400 with manual shift kit
7. AA to the split kit
8. high angle front shaft
9. rear shaft was shortened by 1 1/2"
10. Kept the original pwr steering resvr
11. used a 87' suzuki samuari throtle cable
12. used a ford explorer tranny cooler for the TH400
13. Autometer 2888 that doesent work bad mag PU
14. alot of metal work and time
The one major problem is I dont have an OD, Major problem.
The guys, at I wont say said they have experienced problems with customers doing this conversion using the T700R4. Something about the tranny not shifting correctly. Assured me that going with the TH400 was the way to go . So their I went topped out at about 53mph. Not very happy. It runs fine and pulls like a loco-motive but doesent have the legs. I will probably go w/35" or 37" tires. Do you know of a company that sells taller gears than the ones I have in it 3.70.
Old 10-07-08, 09:44 PM   #796 (permalink)
rtarh2o's Avatar
I would say you got bad advice about the 700R4. It took me going to a second transmission shop to get mine set up right but it is a great transmission. They are adjustable in several ways to make them work great behind a diesel. My 6.2 runs at 2100 rpm at 70 mph with 285/75/16 (33") tires and 4.11 gearing. I wish I had your 3.70 gearing, that would probably put it closer to 1,800 rpm which is supposed to be the sweet spot for mileage with the 6.2.
Rusty
1994 Mercedes G350DT
94 FZJ80 6.2 diesel (sold)
97 FZJ80 Currently son's vehicle - lifted, BFG MT's and Aussie Lockers
78 FJ40 Restoration project
Many old British cars in various states of repair
rtarh2o is offline   Reply With Quote
Old 10-09-08, 08:11 AM   #797 (permalink)
hayes167's Avatar
Weight of engine
Anyone know a rough estimate of the engine weights of 4bd1t and a 3fe? I'm trying to figure what OME springs to put up front of my 80. I'm thinking 850's.
'91 FJ80 in the middle of 4BD1T swap, OME lift.
Pain is inescapeable, suffering is optional!
hayes167 is offline   Reply With Quote
Old 10-09-08, 08:46 AM   #798 (permalink)
astr's Avatar
Roughly, the weight of a 4BD1T with A/C compressor, starter, alternator, wastegated turbo. Intake & exhaust manifolds, flywheel, PS pump, Injector pump and sump full of engine oil is 785 lbs. (See Post #440 in this thread). I haven't weighed the 3FE yet.
Stock FJ62
SOA Samurai Tintop
Ford E-350 4x4 Diesel
M-29 Weasel
astr is offline   Reply With Quote
Old 10-24-08, 12:18 AM   #799 (permalink)
isuzu diesel turbo fuel heater
While I was working on the turbo charger change I also did some much needed electrical. since the electrical is practically connected to everything, i got to go through the gages, fuel pump, fan, fog lights, and even set up a circuit breaker that split into 9 fuseable circuits.
One key item I added was the Diesel therm heater. ATG Diesel-Therm - Fuel Preheater for Diesel, Biodiesel, SVO/WVO The heater will be a nice added feature this winter, as we get likely 10 days of -20 def F weather, and months under o deg F.
This 12v heater comes from germany, is well designed, but expensive IMO. The control has a switch, and a glow plug style heater machined into a banjo bolt. this banjo bolt replaces the bolt in your fuel filter, for the incoming fuel. then fuel coming into the filter is heated, and gelling does not occur. good piece of mind when its cold and not plugged in. I will try it let everyone know, it is 8degs here already.
The last few winters in park city, I have been burning biodiesel in a Cummins dodge. I blend with diesel in the winter, and in DEC and JAN time of year I burn only diesel. even then I have had the diesel gel up and starve the IP.
Old 10-24-08, 11:26 AM   #800 (permalink)
andrew.fletcher's Avatar
Question on turbo placement so close to the brake reservoir. I'm worried that the heat coming off the turbo is going to cook the reservoir on mine. The way it's currently set up I'm about 2" max separation between the two. 4BD2-T in an FJ55.
1. Spal fan 14"
1972 BDJ55-T Resto Mod 4BD2T/4L60
http://forum.ih8mud.com/fj55-iron-pi...resto-mod.html
1989 FJ62 Daily Driver
2006 Chevy Trailblazer-Wife needed more seats than the FJ62
1976 MGB w/ 2.8L Chevy and T-5. Lots o' fun
andrew.fletcher is offline   Reply With Quote
Old 10-25-08, 04:13 PM   #801 (permalink)
Make a 1 or 2 layer heat sheild if you're worried. 2" is plenty of space to fit that in. Lagging the housing and downpipe will help too.
The surface of the exhaust turbine could reach 600C if there was no cooling air going past.
Old 10-27-08, 10:02 PM   #802 (permalink)
yes fletcher the turbo spacing is more important on the exhaust turbine side that is very hot. avoid getting close to alternator, or any rubber lines, silicone lines. the compressor is always receiving cool air, and so is not nearly as hot. i have a laser temp gage, I will compare the turbine to compressor temp.
Old 10-28-08, 05:59 AM   #803 (permalink)
RHINO's Avatar
havent noticed any heat probs with my brakes.
Clay
75 BDJ55- biopig
Old 11-02-08, 07:50 AM   #804 (permalink)
Thanks guys, I think I'm going to go with the heat shield idea.
Old 11-05-08, 08:07 AM   #805 (permalink)
isuzu diesel in 88tlc - turbo performance report
had a chance to take the fj62 out this last weekend, elk hunting in the Uinta mountains. there are many Forest Service roads to navigate if you want to hunt up high. there were also a few good double track trails that required 4 wheel low, in low, that we drove around on the landcruiser - with the diesel, advance adapters, lifted OME springs and shocks, 33 inch tires, rebuilt birfields, new brake lines, etc, all did fabulous. it was in its element.
with all this type of FR driving, I still managed to get 24 mpg. I think on a road trip, I will get even better, letting it in OD, lock up, and be efficient. hoping for 26-28 mpg, i may be heading to Fruita CO this weekend for another road trip.
there were also some small details that popped up - rattles, a small exhaust leak (but even a small diesel leak stinks), wires that rattled loose (i will never use butt connectors again, its solid state solder from now on), so it was a little more shop time post trip for some quick fixes.
I also got my tachometer calibrated using a RPM sensor from harbor freight. this cheap device seemed pretty consistent and accurate, and so then ripped the dash out, the tach out, the back off, and recalibrated.
some stats, just for dougal.
at 62mph (100 kmh) highway speeds flat and level, wind? this speed is the low end of efficiency it seems for OD, it likes to run a little faster with the OD tall gearing, and the 33 inch tires. slightly overgeared but now the 4bd1t can handle a little lugging no problem.
1800 rpm
900 F egt
7-8 psi of boost.
up 6% grades, shift down to 3rd gear, and still maintain 60mph! i can not tell you guys how great that is!
65 mph
2900 rpm
1150 F egt (max I have seen is 1200 F) awesome! more boost, more air, cooler egt.
15-17 psi of boost
I am not running the radiator fan. it maintains a good engine temp on the open road, only time I manually turn on the fan is going up steep Forest roads, in 3rd, or 2nd. other wise it runs cool.
The new turbo, as many have described, is the heart of good performance, good efficiency, cool running engine. If I could suggest any single mod to the 4bd1t, it would be to make sure you have a great turbo with quick response fast spooling, and capable of 15 psi of boost minimum.
Old 11-05-08, 12:45 PM   #806 (permalink)
Originally Posted by 88tlc View Post
1800 rpm
900 F egt
7-8 psi of boost.
65 mph
2900 rpm
15-17 psi of boost
Thanks for sharing those, looks like your turbo investment has really paid off.
To pull 2.3t up a 6% grade at 60mph means you've got 60kw at the wheels.
Your flat road figures are very close to mine. I run
2000rpm
8-9psi boost
800F EGT's
My cooler EGT's are the result of being a little lower geared (2000rpm vs 1800) and I've probably got a slightly more aerodynamic vehicle with smaller tyres.
Old 11-05-08, 04:02 PM   #807 (permalink)
so... 88TLC guy... what's the final consensus? I mean, are you happy with the power? noise level? MPG? would you do the swap again? How does it compare in get-up-and-go to the 3FE?
Old 11-05-08, 08:22 PM   #808 (permalink)
4bd1t turbo diesel better than 3fe?
short answer is yes. for sure. more power, and fuel economy that is close to double the 3fe.
rattles and vibration- these have been minimized with time and revisions - ASTR showed up in park city and we drove the land cruiser before turbo swap. it still had a low idle rattle, and a high speed vibration. When doing the turbo and inspecting, I noticed the ujoint bolts loose. so this was causing the high speed vibes, and an easy fix. i also recently increased rpms to about 900 idle, and 675 rpm when in drive (auto trans). the turbo has helped idle with positive pressure at idle rpms. I also feel like at cruise it now has more power and runs more smoothly, on a good tarmac surface it is really nice, my mother even approved. I found intake hitting a body heat shield, and air intake pipes touching and vibrating, and corrected these small but annoying issues.
Recommedations - i would be sure to use an angled rubber engine mount, like the isuzu stock style would be my next choice. there are others out there but I like this style over a vertical pattern. I would somehow try to confirm the flywheel, spacer, and plate are balanced. i still think I can back off my injector timing a degree to smooth idle.
power - compared to the 3fe the diesel has more power with the improved turbo (with out turbo, or with weak turbo, it has WAY less power), more instant power with out having to wait for it to spin up to a high rpm. i do not feel that it has an excess amount of power (like driving my 6bt cummins in a dodge pickup), but i am okay with that since I am getting such great mileage, over 500 miles on a tank. in low gears it has Tremendous power, and torque. it climbs easily and the torque is very noticeable, with an instant burst if needed to bump over something, or to get a run at something. In four wheel low, and in low gear, there is a lot of gear advantage here, but it would pull its guts out and blow other stuff apart on my stock rig. i really enjoyed this lowend power with 4 people and a big ole cooler of beer in the back, and it barked up the hill.
Recommendations: I would suggest smaller tires if you want to be powered for highway driving, to reduce rubber gearing. I have not found 3600 rpms yet, have only gotten to 3000, so yet to really feel the full potential? fuel amount seems about right, i would always prefer the leaner more efficient side. i will report my max speed on the flats some day. Install boost, egt, and oil pressure minimum, more sensors the more data you can make more power adjustments with.
ease of swap, and maintenance - this was my first and was not insignificant. i had high expectations perhaps, with altitude, and sustained hills to climb. so it took me awhile. but the electric is easy, the isuzu diesel swapper is easy, even the turbo and the main components are mechanical, and you can work on them. i hate chasing electrical problems down. the space seems perfect. there is room, but it fits well vertically, from firewall to radiator, and oilpan to diff. just got it in there. always starts. even in 20deg weather it starts with glow plugs and hardly smokes. the 6bt is sluggish in the same temps. very reliable starting, glowplugs, block heater, and diesel therm will insure starting in the coldest conditions.
recommendations:i would do the turbo fitting and injection pump, and some of these other major jobs on the engine stand, but it is pretty easy to work on in the vehicle. there are still oil leaks. seems like all diesels always leak? i will continue to chase these down and try to reduce its nasty habit of leaving its mark everywhere.
Old 11-06-08, 04:38 PM   #809 (permalink)
great info. thanks for recapping your thoughts. Couple more... did you ever turn your fuel up? (either before or after the turbo swap)
Is your speedo readings from above, actual speed (ie: compensated for 33" tires) or just what the gauge is reading (which would imply that you're really going about 67MPH up that hill.)
Old 11-06-08, 06:03 PM   #810 (permalink)
injection pump was rebuilt and fuel was turned up from stock, i do not know how much. i have since turned it down 1/4 turn.
actual speeds are reported, and actual mileage is reported, adjusted by 10% for the tires.
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/128585-isuzu-4bd1t-swap.html
Posted By For Type Date
isuzu 4BD1T swap?! on (4 Viewing) - Page 10 | BoardReader This thread Refback 10-01-09 05:03 PM
GM Diesel into a CJ - Pirate4x4.Com Bulletin Board This thread Refback 08-27-09 10:48 AM
1996 cummins diesel with frybrid- low power - Forums This thread Refback 07-29-09 09:34 AM
Isuzu Alternator wiring? - Cummins 4BT & Diesel Conversions Forums This thread Refback 07-20-09 03:46 PM
4BD1T enginen weight and max rpm - Cummins 4BT & Diesel Conversions Forums This thread Refback 07-14-09 03:08 PM
isuzu 4BD1T swap?! on (4 Viewing) - Page 3 | BoardReader This thread Refback 07-13-09 03:22 PM
4BD1T 1970's F250 - Cummins 4BT & Diesel Conversions Forums This thread Refback 07-06-09 08:29 PM
Isuzu 4HE1 Swap on (4 Viewing) | BoardReader This thread Refback 06-22-09 12:57 PM
235 CID izuzu diesel questions. - Pirate4x4.Com Bulletin Board This thread Refback 05-07-09 08:01 PM
4BD1A izuzu diesel. - Great Lakes 4x4. The largest offroad forum in the Midwest This thread Refback 05-07-09 04:14 PM
isuzu 4BD1T swaps?! - Page 2 - Cummins 4BT & Diesel Conversions Forums Post #0 Refback 05-02-09 08:23 PM
Diesel Engine Conversion Thread-Japanese Diesels - Page 2 - Binder Planet Forums This thread Refback 04-21-09 02:40 PM
Toyota 4Runner 5 Speed Manual, Toyota 4 Runner, Toyota 4Runner Antenna - Argongas This thread Refback 03-08-09 11:53 AM
Jeep Cj2A Bikini Top, Jeep Cj Exhaust Manifold Gasket Replacement, Jeep Cj5 Exhaust Flange - Polarisdiesel This thread Refback 03-08-09 11:24 AM
1994 Toyota T100 Suspencion System, 1994 Toyota Pickup Truck Starter Motor, 1994 Volkswagen Golf Iii Gl - Prestolitealternator This thread Refback 03-08-09 11:09 AM
Ebay Maxima Headers, Ebay Chevelle Cars, Ebay Motorcycle Classifieds - Husqvarna345E This thread Refback 03-08-09 06:21 AM
Isuzu Land Rover Conversion, Isuzu Incentives, Isuzu Marine Diesel Engines - Belizelifestyle This thread Refback 03-08-09 06:20 AM
1991 Jeep Wrangler Ignition Problems, 1991 Jeep Cherokee Trouble Shhoting Forum, 1991 Kawasaki Ninga Zx11 Repair Manual - Lightningfire This thread Refback 03-08-09 06:11 AM
1986 Lincoln Mark Conversion, 1986 Kawasaki Voyager, 1986 Mercedes 300E Overdrive - Mastercraftavenger This thread Refback 03-08-09 06:10 AM
Isuzu Cgiworld, Isuzu Car Parts, Isuzu Charleston Sc - Lightningrods This thread Refback 03-08-09 05:23 AM
Yamaha V Star Tire Pressure, Yamaha V Star Motorcycle, Yamaha Venture Accessories - Titangenerator This thread Refback 03-08-09 03:26 AM
Mercedes Sl Rocker Panel, Mercedes Sl Gas Fuel Gauge, Mercedes Sl55 - Venetianmirrors This thread Refback 03-08-09 01:16 AM
Motorcycle Rodeo, Motorcycle Rocket Jackets, Motorcycle Routes Arizona - Yamahacanada This thread Refback 03-08-09 12:22 AM
Heavy Duty Truck Parts, Heavy Duty Fuel Parts Injector, Heavy Duty Truck Tire Service In Minnesota - Ktmgirls This thread Refback 03-07-09 01:50 AM
68 Chevy Truck Phantom Billet Grille, 68 Chevrolet C10 Original Rear Suspention, 68 Firebird Parts - Csahb This thread Refback 03-07-09 01:19 AM
Ford Truck Exhaust Manifold Leak, Ford Truck Clutch Kits, Ford Truck Front Fenders My My Messages - Polarisclothing This thread Refback 03-06-09 02:04 AM
Used Cars Carson City Nv, Used Cars Calgary, Used Cars Chicago - Thermostatwikipedia This thread Refback 03-06-09 01:47 AM
Suggestions Please on next vehicle... - Page 3 - Expedition Portal Forum This thread Refback 02-08-09 10:21 AM
Isuzu Clutch Disk Compatibility - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-30-09 01:57 PM
1997 Landcruiser conversion - ToyotaDiesel.com This thread Refback 01-28-09 10:41 PM
Land Rover with Isuzu diesel engine swap - ToyotaDiesel.com This thread Refback 01-13-09 12:36 AM
What about Isuzu 2.8 TD's? - Pirate4x4.Com Bulletin Board This thread Refback 12-10-08 06:25 AM
Land Rover with Isuzu diesel engine swap - ToyotaDiesel.com Forums This thread Refback 10-27-08 08:59 AM
isuzu - internet discussions | BoardReader This thread Refback 08-25-08 07:26 PM
1st post, t100 conversion? - ToyotaDiesel.com Forums This thread Refback 07-28-08 11:43 AM
isuzu 4BD1T swaps?! - Page 3 - Cummins 4BT Forums Post #0 Refback 07-26-08 09:32 PM
New here. Isuzu 4HE1-T conversion - Australian Land Rover Owners This thread Refback 07-07-08 05:16 PM
new old truck... This thread Refback 07-06-08 10:19 AM
new old truck... This thread Refback 07-05-08 06:32 PM
isuzu 4BD1T swap?! on (4 Viewing) | BoardReader This thread Refback 06-20-08 05:44 PM
4bd2tc into cj7 w/NV4500/dana300 without dual flywheels - Cummins 4BT Forums This thread Refback 06-04-08 08:59 AM
Build-up: Jeep YJ w/ Isuzu diesel - Pirate4x4.Com Bulletin Board This thread Refback 05-19-08 09:17 PM
Build-up: Jeep YJ w/ Isuzu diesel - Pirate4x4.Com Bulletin Board This thread Refback 05-15-08 07:22 PM
Cars world :: Isuzu :: BoardReader This thread Refback 05-15-08 06:37 PM
Possible Diesel Combo In 1500 - FSC Forum This thread Refback 04-24-08 04:53 PM
Outer Limits 4x4 Board :: View topic - County engine options This thread Refback 04-22-08 06:02 AM
Swapping a TDI into a Land Rover - TDIClub Forums This thread Refback 04-04-08 09:27 AM
4bd1t/2t vs. 4bt - Cummins 4BT Forums This thread Refback 04-02-08 04:37 AM
1997 Landcruiser conversion - ToyotaDiesel.com Forums This thread Refback 03-30-08 02:38 PM
STICKY: Isuzu 4BD1T/4BD2T Reference - Cummins 4BT Forums This thread Refback 03-25-08 09:13 PM
4bd1t/2t vs. 4bt - Cummins 4BT Forums This thread Refback 03-22-08 05:54 PM
4bd2tc into cj7 w/NV4500/dana300 without dual flywheels - Cummins 4BT Forums This thread Refback 03-22-08 02:14 PM
4BD1T 1970's F250 - Cummins 4BT Forums This thread Refback 03-10-08 06:23 AM
Diesel Engine Conversion Thread-Japanese Diesels - Page 2 - Binder Bulletin Forums This thread Refback 03-09-08 12:09 PM
Other Great Isuzu 4BD1T Sources - Cummins 4BT Forums This thread Refback 03-09-08 11:13 AM
isuzu 4BD1T swaps?! - Cummins 4BT Forums This thread Refback 03-03-08 04:27 PM
Untitled document This thread Refback 02-26-08 05:57 PM
4bd2tc into cj7 w/NV4500/dana300 without dual flywheels - Cummins 4BT Forums This thread Refback 02-10-08 09:24 PM
Diesel Engine Conversion Thread-Japanese Diesels - Page 2 - Binder Bulletin Forums This thread Refback 02-08-08 05:40 AM
4bd2tc into cj7 w/NV4500/dana300 without dual flywheels - Cummins 4BT Forums This thread Refback 02-05-08 09:28 AM
Isuzu 4BD diesels.. New forum... - Expedition Portal Forums This thread Refback 02-01-08 10:17 AM
4bd2tc into cj7 w/NV4500/dana300 without dual flywheels - Cummins 4BT Forums This thread Refback 01-31-08 09:13 PM
4bd2tc into cj7 w/NV4500/dana300 without dual flywheels - Cummins 4BT Forums This thread Refback 01-31-08 05:47 PM
4bd2tc into cj7 w/NV4500/dana300 without dual flywheels - Cummins 4BT Forums This thread Refback 01-31-08 03:44 PM
solenoid isuzu :: BoardReader This thread Refback 01-23-08 04:17 PM
Madcowdungbeetle builds a rover... - Page 3 - Pirate4x4.Com Bulletin Board This thread Refback 01-18-08 12:36 PM
Build-up: Jeep YJ w/ Isuzu diesel - Pirate4x4.Com Bulletin Board This thread Refback 01-15-08 07:35 PM
Build-up: Jeep YJ w/ Isuzu diesel - Pirate4x4.Com Bulletin Board This thread Refback 01-10-08 07:54 AM
Build-up: Jeep YJ w/ Isuzu diesel - Pirate4x4.Com Bulletin Board This thread Refback 01-08-08 08:19 PM
Untitled document This thread Refback 01-06-08 05:57 PM
Untitled document This thread Refback 12-28-07 05:36 AM
Cars world :: Isuzu :: BoardReader This thread Refback 12-24-07 07:18 PM
Swapping a TDI into a Land Rover - TDIClub Forums This thread Refback 12-24-07 03:48 AM
Untitled document This thread Refback 12-22-07 12:21 PM
4BD1T swap in a Tundra?? - Cummins 4BT Forums This thread Refback 12-21-07 02:22 PM
Other Great Isuzu 4BD1T Sources - Cummins 4BT Forums This thread Refback 12-18-07 11:18 AM
isuzu 4BD1T swaps?! - Cummins 4BT Forums This thread Refback 12-16-07 08:53 PM
