LinkBack (78) Thread Tools Display Modes
Old 12-27-07, 09:40 PM   11 links from elsewhere to this Post. Click to view. #571 (permalink)
isuzu diesel in 88tlc - exhaust system
Andre and i work in a shop that is in Heber Utah, that's pronounced Heeber. It is a small town with a couple parts shops, a couple auto body shops, and one real muffler shop.
I gave this guy the shot to install the exhaust system. since i got this engine already pulled from the truck, i had no parts but the flange, and the exhaust brake.
he used 2.5 inch exhaust pipe, and a good welded diesel muffler. normal steel. all isolated hangers.
he added the jake brake just before the muffler, I still need the magnetic valve that controls the vacuum to the physical valve. this valve took 3 months of cooking in the sauce before it would bust loose. It works smoothly now , I hope it will last. how cool to have a jake brake on a landcruiser?!
88tlc is offline   Reply With Quote
Old 12-28-07, 01:42 PM   #572 (permalink)
astr's Avatar
Congratulation! Looks like you have done a super job. While some of us talk about doing the swap, you went and did it! You provide inspiration for the rest of us.
Glad to see you installed the exhaust brake - I think you'll love it.
Please post your impressions after you get some miles on it.
Stock FJ62
SOA Samurai Tintop
Ford E-350 4x4 Diesel
M-29 Weasel
astr is offline   Reply With Quote
Old 12-28-07, 02:32 PM   #573 (permalink)
euclid's Avatar
TLCA# 13014
Originally Posted by 88tlc View Post
3. 4wd Hi - Lo shifter - this requires a connection to the trans, I have an idea, but it involves JB Weld! I need to think on that one for a bit yet.
Make the t-case fully manual. Git rid of the vacuum shifter.
See here
Looks great. Very very cool that it's running.
I'd love to see the budget when you are done.
Greg Thompson
89 FJ62, Unstock.
euclid is offline   Reply With Quote
Old 12-29-07, 04:41 PM   #574 (permalink)
RHINO's Avatar
awsome another isuzu powered cruiser on the road,, congrats !!!.
Clay
75 BDJ55- biopig
Old 12-31-07, 07:05 PM   #575 (permalink)
isuzu diesel in 88tlc - intake and vibration
getting the intake worked out.
using the stock fj62 filter, but it has a square receiver. i welded up a square plate to 3 inch pipe, and then will have some hose and pipe from
www.intakehoses.com
to obtain this general shape.
been driving with this mockup intake, and the engine has a good vibration that resonates through the vehicle. make the change rattle in the ashtray sort of vibration.
thoughts?
flywheel out of balance? - there is a pin still in the flywheel from the clutch plate, is the fly wheel balanced with our without the pin?
adapter balance - there was a casting flaw that I noticed on the Isuzu Diesel Swapper. it is near the center, but is this enough to throw it off balance? The adapter centers onto the bearing in the crankshaft when installing, key to get it within .005 " of center.
harmonic dampener. i have read a bit about the diesel spike, from the large power spikes in the diesel engine. most diesels have a harmonic damper, a fluid filled damper that reduces this. does the isuzu have this diesel spike issue?
http://www.dynadroitclutches.com/vibration_damper.html
Engine mounts - the vibration should still be dampened through the mounts, right? i used the ford, fluid filled mounts.
Any thoughts or suggestions on the vibration?
Old 12-31-07, 07:41 PM   #576 (permalink)
What mounts do you have on the other end of the drivetrain?
My vehicle uses 3" round by 1.5" thick industrial rubber isolators for engine mounts and they work very well. They're mounted at 60 deg (30 deg off vertical) which is similar to the geometry Isuzu use in their truck engine mounts.
At idle the engine vibrates about 10mm on it's mounts and doesn't rattle the rest of the vehicle much at all.
I'm not a fan of flat engine mounts. Rubber absorbs vibration best in shear, not the vertical compression/extension that it's put under when mounts are flat like that.
Diesels use a heavier flywheel to smooth out the crank pulses, the front drive pulley on mine (it's JDM spec, 24v and single V belt) appears to be two piece with rubber between in a harmonic damper fashion, but you'd have to cut one apart to know for sure.
But a crankshaft damper won't help the vehicle shaking. My flywheel had two 6mm pins 180 deg apart for clutch location. Is it those you refer to?
Old 12-31-07, 10:21 PM   #577 (permalink)
RHINO's Avatar
i dont know about the vibes,,, mine is really smooth. but i used the stock isuzu motor mounts which are at shear like dougal mentions, maybe it really does help?
does the flywheel have only one pin?? i would pull it out. i dont think the casting flaw is a problem. you might want to check IP timing again.
Clay
75 BDJ55- biopig
Old 01-02-08, 11:30 AM   #578 (permalink)
dieselcruiserhead's Avatar
TLCA# 9439
My thought on it is something driveline related.. The question is whether the vibration happens when the vehicle is in motion. I do not think it is the isolators we used.. It could be a light flywheel out of balance issue too as there is about 20mm of broken off bolt in one hole (that is not used with the auto-flywheel adapter. Or it could (doubtfully) be a adapter machining issue.
My guess is about 90% oriented towards the driveshaft. We have about a 1-2 degree drop from the fornt of the engine to the back. Longer shackles in the rear or gulp, Bill might need to get a CV added to the rear driveshaft...
But that is my thought for now...
Also Bill I was down briefly last night, looks great and nice to see it all dialed up. I was temped to fire it up. I can make it down Fri or Sat for finish up and to get it ready to get it out of there...
- Cummins 4BTswaps.com Forums
- Hazard Assembly Dirtbag Adventuring Community
- Diesel Conversion Website
TLCA# 9439 Since 1999, Wasatch Cruisers
'89 Toyota Pickup V6, OME, 33x10.5's
'69 FJ55 Project on locked FZJ80 Frame, Cummins 4BT, NV5600, Dana 300
dieselcruiserhead is offline   Reply With Quote
Old 01-02-08, 01:43 PM   #579 (permalink)
ThePookieBear's Avatar
So, if one was to make a 4BD1/2T-a440 adaptor would it just need to be a plate machined to allow the tranny to bolt up to the engine. Then you would need the custom torque converter from australia right? What kind of spacing would this require? And if I remember what the tranny guy from australia said it would need the auto flexplate. Is that correct? If I could get accurate measurements for the a440 and the engine housing I have a friend who says his boss wouldn't mind making them for the cost of materials and stuff. I'm not sure if I understand all the intricate details exactly, but basically you need an adaptor like the isuzudieselswapper one, but for the a440 right? I would like to try and move forward a bit on this. His boss said he needs more info, and I told him I would look into it and ask around with some "friends of mine."
1992 FJ80, stock except brush guard , and BF Goodrich AT 33's.
"Don't be too quick to associate vodka with Communism."
Landrovers: "I don't understand why everything is not easy to reach on these as everything needs to be reached fairly often... "
ThePookieBear is offline   Reply With Quote
Old 01-12-08, 12:48 PM   #580 (permalink)
4bd1t engine vibration
thanks for all the replies.
The engine vibrates at idle to like 1500rpm, I am working to get the tach in to check the rpms. I think the idle rpms are low, and could suggest incorrect IP timing.
at power and cruising down the road the vibration is the least noticed.
cruising it can vibrate, kind of coasting.
Dougal - there are in fact two pins 180 degrees from each other. I left them both in the flywheel. I also twisted off a bolt in the flywheel at the clutch attachment, but also added another bolt stud, cut off and a slot to screw it in 180 degrees. so I think the flywheel is balanced. at rpm I would expect a flywheel issue to get worse.
I also agree that the mounts should be in shear, and should do a better job of isolating. trans mount is original fj62 mount.
rhino - I agree with you about the IP, I have not yet checked the IP timing. I have it correct relative to the gear, and cam, but can check that #1 fuel is injected at 13 degrees b4 TDC. It can be 2 or 3 degrees off and make a big difference. You can micro adjust then by loosening the IP mounting bolts and rotate to correct timing. I assumed this was correct, but I now want to check it.
Andre, I dont think the driveline is the issue. it vibrates at idle, or not in gear.
Old 01-12-08, 03:02 PM   #581 (permalink)
They do rock around a lot at the normal idle speed of 650-700rpm, I bumped mine up to maybe 800rpm which smooths it out a lot. Above 1000rpm they're very smooth and sweet for a large 4cyl diesel.
I would definitely check the injection timing.
Old 01-12-08, 07:27 PM   #582 (permalink)
RHINO's Avatar
you wouldnt think a little timing would be much but it sure does. when i got mine together it had a vibe at hiway cruise,,, just a little harmonic type deal. i thought about it and read a bunch on the injection system and decided to check the IP timing. it was only off 1 degree. i re-set it and i swear its as smooth as a 2F now.
you'll get it figured out,,, at least its running and driving, how big a smile do you have behind the wheel? i still have one.
Clay
75 BDJ55- biopig
Old 01-18-08, 08:51 PM   #583 (permalink)
4bd2tc into cj7 w/NV4500/dana300
Well, it looks like I have finally got everything into one pile now, I have gotten most of the parts, and we just finished measuring everything up. I hope to have everything machined and ready to bolt together in the next few weeks.
I have found a way to get around the dual flywheel problem, by using an NV4500 tranny from a Dodge truck, an adapter from JB conversions to adapt the nv 4500 to my Dana 300, and now with a bit of machining I am making a plate to bolt the isuzu 5speed bellhousing to the front of the NV4500. With a replacement for the isuzu pilot bearing ( to match the NV) I think I have a WINNER!!!
I will have to do a bit of machine work on the Isuzu bellhousing to make clearance for the bearing retainer on the NV, but that will not be too big of a deal.
Is anyone else interested in trying this, after I get it all programmed up. I wander if anyone else would want one?
Dieseltim
Dieseltim is offline   Reply With Quote
Old 01-22-08, 10:56 AM   #584 (permalink)
andrew.fletcher's Avatar
Well the engine is finally sitting on my garage floor, it only took me 3 months of trips back and forth to Southern Cal but it's finally done! Now I just need to figure out which tranny to use, 4L60 or 700r4. I was looking through the thread but couldn't find the comments regarding rpm's. Am I remembering correctly the agreed upon rpm the engine likes is around 2100 rpm? My next project is to figure out the best tire/3rd member combination. What am I doing wrong with this formula. ?
mph x final drive ratio x O.D ratio (no O.D is 1) / tire dia x 336 = rpm at the mph.
70 mph x 2.87 (final drive ratio of a 4L60) x .7 (O.D ratio for a 4L60) / 33 (planned tire size) x 336 = 1431 rpm. This is way too low I think. I got the numbers from a tranny specialty site and these numbers apply to a 4.11 gear.
1972 BDJ55-T Resto Mod 4BD2T/4L60
http://forum.ih8mud.com/fj55-iron-pi...resto-mod.html
1989 FJ62 Daily Driver
2006 Chevy Trailblazer-Wife needed more seats than the FJ62
1976 MGB w/ 2.8L Chevy and T-5. Lots o' fun
andrew.fletcher is offline   Reply With Quote
Old 01-22-08, 08:12 PM   #585 (permalink)
isuzu to 4l60
great you have an engine, what kind did you end up with? have you rebuilt it or planning to just drop it in?
the 4L60 I understand to be a stronger Trans, and has an option to get a K case from trucks.
the equation you have there looks wrong, you do not need a final drive ratio and a OD ratio. here is another site, with all the gory details.
Speed versus RPM calculator
at 70 mph, with 4:11 gears, and .7 OD, and 33 inch tires, the engine will run about 2050 rpms. The optimum is around 1800 rpms (about 62 mph).
I recently got my tachometer installed autometer #2888 but do not have it calibrated, and I also have the 33 inch tires! but I am not putting them on, until I tweak the IP timing.
Old 01-22-08, 08:25 PM   #586 (permalink)
4bd1t Injection Pump timing
Oh the smile is there alright! I have now like 100 miles on it, but still I would like to tweak it. It is a lot like ocean sailing it seems, it is easy to get to 80% power, but the last 20% of the power takes a lot of refinement.
I would be curious how you checked your IP timing? I used the description in the manual, but was not able to get a consistent reading? Removed the #1 line, removed the valve holder, replaced without the spring or valve, rotate the crank, and then check when I saw fuel rise up in the #1 valve holder? should rise at -13TDC.
I also then pumped the Lift pump at -13 , -15, -17 and on, and would get fuel to come out of the #1 valve holder. Per the manual the fuel should come out at -13, but not come out at -14 TDC?
My concern with the IP pump that the fuel goes back down, I would think it would have a check valve somewhere. Unfortunately they do not let a whole lot of secrets out on the IP pump mechanics...
Old 01-22-08, 11:53 PM   #587 (permalink)
1995 4BD2T with 4L60
It's a 4BD2T. There's a long story that goes with the engine which I'll put in my thread at some point. The short version is I bought a 1995 16' box truck with the engine in pieces, which it didn't have all of them (missing over $1000 worth). It dropped a piston 4 years ago, machine work was done then never put back together. Over the years, lots of parts got lost as it got moved around. I still need some bolts which I'll have to order from Isuzu.
Along with the transmission (4L60), I need to figure out the rest of the plumbing. I remember reading somebody had a pdf of the FSM but couldn't find the thread. Was I dreaming?
88tlc - I also sent you a PM. I re-read your posts and looked at the photos. Great info that will save me a lot time.
Old 01-23-08, 08:30 AM   #588 (permalink)
rtarh2o's Avatar
That sounds familiar about missing parts and figuring out where they go. I bought a military 6.2 for my swap and it was missing all the accessories and brackets. I bought all new accessories and had a salvage yard send me all the brackets. It was like a jigsaw puzzle! The problem was that the 6.2 was used in so many cars and for so many years it was hard to find pictures of the exact set-up I had. That may be the same problem you encounter. Finally after several days of web searching and head scratching I got them all on. I will say this from my experience, trial fit your engine with all accessories on (mine fit but I had to move the battery position) install the fan w/clutch (if using one) radiator and fan shroud. I should have placed my engine about an inch further back for the fan to clear the radiator. As it sits I am using a flex fan without the clutch (probably a better set-up anyway) and I am having to modify the shroud (the engine sits about 3" more towards the drivers side) All of these would have been much easier before the engine was installed! Keep us posted, the Isuzu was my first choice for my conversion, in fact I thought I bought one but after a couple months I finally realized the guy wasn't going to go through with it, that is when the 6.2 sort of fell into my lap. I would still like to do an Isuzu conversion though.
Good luck
Rusty
rtarh2o is offline   Reply With Quote
Old 01-23-08, 09:05 AM   #589 (permalink)
astr's Avatar
The FSM for the 4BD1T is posted on MattF's site at Master Portal - forums.bauchan.org/Isuzu Manuals Most of the information applies to the 4BD2T as they share the same bottom end (except pistons).
MattF has also posted FSMs for the Isuzu 2000-2003 trucks that cover the 4HE1 and 6HK1 diesel engines.
Stock FJ62
SOA Samurai Tintop
M-29 Weasel
Old 01-23-08, 05:37 PM   #590 (permalink)
Perfect -Thanks a bunch. Now I just need to find the right time of day won't the server isn't overloaded!
Old 01-23-08, 06:12 PM   #591 (permalink)
RHINO's Avatar
cool andrew, one step closer.
88tlc,, i got to talking with a mechanic guy i know,,, he's mostly a big truck guy but does the isuzu fleet for a large landscape company here so i like to pick his brain. he "let me borrow" a timing thing that plugs into the #1 IP line on the bottom of the pump, it also has a deal that attaches to it and can read RPM.
Clay
75 BDJ55- biopig
Old 01-30-08, 08:09 PM   #592 (permalink)
NV4500 to 4bd2tc
I have finally gotten everything bolted together to see how it is all going to fit, and it looks GREAT. I have the anwser for those of you that would like to put a 4bd into most anything now without the having to use two flywheels. I am using the bellhousing from the isuzu 5speed and an NV4500 from a Dodge truck ( has a longer input shaft). Used the isuzu pressure plate and the dodge clutch disk, changed the pilot bearing and bolted in an adapter plate between the bellhousing and the NV4500. For those who said it can't be done I have the pics to prove it. For anyone else that would like to do an NV4500 adapter. I will be taking orders Now. Kits will be ready in the next few weeks, as soon as we can get the CNC programmed to make them.
In the first pic below you can see that the dodge throwout bearing will fit onto the isuzu clutch arm and that it looks stock.
The second pic is of the whole assy bolted together.
Dieseltim
Old 01-30-08, 09:23 PM   #593 (permalink)
You my friend are a genius.
Congrats on both getting it done and making it stupidly easy for those who follow you.
Old 01-31-08, 07:56 AM   #594 (permalink)
astr's Avatar
I have the anwser for those of you that would like to put a 4bd into most anything now without the having to use two flywheels. ...... Kits will be ready in the next few weeks, as soon as we can get the CNC programmed to make them.
Looks great! I am definitely interested. The NV4500 is a great transmission and there are adapters available to the LC t-case.
Let me know how much for the kit and what you plan to include.
How thick is your adapter and how do you insure proper alignment?
Stock FJ62
SOA Samurai Tintop
M-29 Weasel
Old 01-31-08, 03:28 PM   #595 (permalink)
Thumbs up NV4500 adapter
astr,
The first pics show that the throwout bearing tube has been bored out to the size of the bearing retainer for the NV4500, and the next pics shows that installed into the isuzu bellhousing. For the this proto-type we choose to make the plate 3/8" so that the input shaft would be long enough to reach into the pilot bushing. Using the 3/8" plate meant that we also had to relieve the backside of the bellhousing to allow for the NV4500 bearing retainer and the bolts that hold it onto the front of the tranny, to fit into the back of the bellhousing. Now that we have it all together it looks like 1/2" plate will work ok for the shaft length, so that will save the machine work to relieve the backside of the isuzu bellhousing, but the hole will still have to be bored thru where the throwout bearing rides, As this is the only place to get everything lined up.
As for what we are planning to include in the kit.
The adapter plate cost will be determained after we get everything programmed for CNC.
The clutch disk
pilot bearing
Throwout bearing
All the bolts & nuts
You will need to have a bellhousing to send to us for the machine work or have it done locally if you can find someone you trust to work to the 1000th of an inch.
Dieseltim
Old 01-31-08, 03:56 PM   #596 (permalink)
Thumbs up other pics
I have some other pics on another forum, check out
Build-up: Jeep YJ w/ Isuzu diesel - Page 3 - Pirate4x4.Com Bulletin Board
Dieseltim
Old 01-31-08, 05:50 PM   #597 (permalink)
THis is brilliant!! I have a Dodge nv4500 in my cruiser!! I will be very interested in a kit!
71 FJ40 - 351W, SOA
86 FEJ60 - 390 FE, Holley Projection, NV4500, OME Heavy, 4.11s, ARB, 33/12.50/15 Pro Comp M/T's
svo_jon is offline   Reply With Quote
Old 01-31-08, 08:50 PM   #598 (permalink)
Thumbs up kits avaible soon
It looks like it will be 4-6 weeks before we can get this programmed for the CNC to start making them on a production basis. In the mean time, if you want to start a list of first come first serve. E-mail or PM me. I will NOT be taking any Money until they are ready to be shipped. So, while you wait for us to get production rolling, find yourself a flywheel and bellhousing from the isuzu 5speed, and an NV4500 from a dodge truck. Maybe by the time you have all of that together we will have the kit ready.
Dieseltim
Old 01-31-08, 09:44 PM   #599 (permalink)
Dieseltim
If it's okay with you, I'd like to add this info to the Isuzu 4BD1/4BD2 section on www.4btswaps.com
Old 02-01-08, 07:02 AM   #600 (permalink)
Post info
Dougal, I think i already did that, but if I have it in the wrong place then by all means go ahead and add it in.Dieseltim
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/128585-isuzu-4bd1t-swap.html
Posted By For Type Date
isuzu 4BD1T swap?! on (4 Viewing) - Page 10 | BoardReader This thread Refback 10-01-09 05:03 PM
GM Diesel into a CJ - Pirate4x4.Com Bulletin Board This thread Refback 08-27-09 10:48 AM
1996 cummins diesel with frybrid- low power - Forums This thread Refback 07-29-09 09:34 AM
Isuzu Alternator wiring? - Cummins 4BT & Diesel Conversions Forums This thread Refback 07-20-09 03:46 PM
4BD1T enginen weight and max rpm - Cummins 4BT & Diesel Conversions Forums This thread Refback 07-14-09 03:08 PM
isuzu 4BD1T swap?! on (4 Viewing) - Page 3 | BoardReader This thread Refback 07-13-09 03:22 PM
4BD1T 1970's F250 - Cummins 4BT & Diesel Conversions Forums This thread Refback 07-06-09 08:29 PM
Isuzu 4HE1 Swap on (4 Viewing) | BoardReader This thread Refback 06-22-09 12:57 PM
235 CID izuzu diesel questions. - Pirate4x4.Com Bulletin Board This thread Refback 05-07-09 08:01 PM
4BD1A izuzu diesel. - Great Lakes 4x4. The largest offroad forum in the Midwest This thread Refback 05-07-09 04:14 PM
isuzu 4BD1T swaps?! - Page 2 - Cummins 4BT & Diesel Conversions Forums Post #0 Refback 05-02-09 08:23 PM
Diesel Engine Conversion Thread-Japanese Diesels - Page 2 - Binder Planet Forums This thread Refback 04-21-09 02:40 PM
Toyota 4Runner 5 Speed Manual, Toyota 4 Runner, Toyota 4Runner Antenna - Argongas This thread Refback 03-08-09 11:53 AM
Jeep Cj2A Bikini Top, Jeep Cj Exhaust Manifold Gasket Replacement, Jeep Cj5 Exhaust Flange - Polarisdiesel This thread Refback 03-08-09 11:24 AM
1994 Toyota T100 Suspencion System, 1994 Toyota Pickup Truck Starter Motor, 1994 Volkswagen Golf Iii Gl - Prestolitealternator This thread Refback 03-08-09 11:09 AM
Ebay Maxima Headers, Ebay Chevelle Cars, Ebay Motorcycle Classifieds - Husqvarna345E This thread Refback 03-08-09 06:21 AM
Isuzu Land Rover Conversion, Isuzu Incentives, Isuzu Marine Diesel Engines - Belizelifestyle This thread Refback 03-08-09 06:20 AM
1991 Jeep Wrangler Ignition Problems, 1991 Jeep Cherokee Trouble Shhoting Forum, 1991 Kawasaki Ninga Zx11 Repair Manual - Lightningfire This thread Refback 03-08-09 06:11 AM
1986 Lincoln Mark Conversion, 1986 Kawasaki Voyager, 1986 Mercedes 300E Overdrive - Mastercraftavenger This thread Refback 03-08-09 06:10 AM
Isuzu Cgiworld, Isuzu Car Parts, Isuzu Charleston Sc - Lightningrods This thread Refback 03-08-09 05:23 AM
Yamaha V Star Tire Pressure, Yamaha V Star Motorcycle, Yamaha Venture Accessories - Titangenerator This thread Refback 03-08-09 03:26 AM
Mercedes Sl Rocker Panel, Mercedes Sl Gas Fuel Gauge, Mercedes Sl55 - Venetianmirrors This thread Refback 03-08-09 01:16 AM
Motorcycle Rodeo, Motorcycle Rocket Jackets, Motorcycle Routes Arizona - Yamahacanada This thread Refback 03-08-09 12:22 AM
Heavy Duty Truck Parts, Heavy Duty Fuel Parts Injector, Heavy Duty Truck Tire Service In Minnesota - Ktmgirls This thread Refback 03-07-09 01:50 AM
68 Chevy Truck Phantom Billet Grille, 68 Chevrolet C10 Original Rear Suspention, 68 Firebird Parts - Csahb This thread Refback 03-07-09 01:19 AM
Ford Truck Exhaust Manifold Leak, Ford Truck Clutch Kits, Ford Truck Front Fenders My My Messages - Polarisclothing This thread Refback 03-06-09 02:04 AM
Used Cars Carson City Nv, Used Cars Calgary, Used Cars Chicago - Thermostatwikipedia This thread Refback 03-06-09 01:47 AM
Suggestions Please on next vehicle... - Page 3 - Expedition Portal Forum This thread Refback 02-08-09 10:21 AM
Isuzu Clutch Disk Compatibility - Cummins 4BT & Diesel Conversions Forums This thread Refback 01-30-09 01:57 PM
1997 Landcruiser conversion - ToyotaDiesel.com This thread Refback 01-28-09 10:41 PM
Land Rover with Isuzu diesel engine swap - ToyotaDiesel.com This thread Refback 01-13-09 12:36 AM
What about Isuzu 2.8 TD's? - Pirate4x4.Com Bulletin Board This thread Refback 12-10-08 06:25 AM
Land Rover with Isuzu diesel engine swap - ToyotaDiesel.com Forums This thread Refback 10-27-08 08:59 AM
isuzu - internet discussions | BoardReader This thread Refback 08-25-08 07:26 PM
1st post, t100 conversion? - ToyotaDiesel.com Forums This thread Refback 07-28-08 11:43 AM
isuzu 4BD1T swaps?! - Page 3 - Cummins 4BT Forums Post #0 Refback 07-26-08 09:32 PM
New here. Isuzu 4HE1-T conversion - Australian Land Rover Owners This thread Refback 07-07-08 05:16 PM
new old truck... This thread Refback 07-06-08 10:19 AM
new old truck... This thread Refback 07-05-08 06:32 PM
isuzu 4BD1T swap?! on (4 Viewing) | BoardReader This thread Refback 06-20-08 05:44 PM
4bd2tc into cj7 w/NV4500/dana300 without dual flywheels - Cummins 4BT Forums This thread Refback 06-04-08 08:59 AM
Build-up: Jeep YJ w/ Isuzu diesel - Pirate4x4.Com Bulletin Board This thread Refback 05-19-08 09:17 PM
Build-up: Jeep YJ w/ Isuzu diesel - Pirate4x4.Com Bulletin Board This thread Refback 05-15-08 07:22 PM
Cars world :: Isuzu :: BoardReader This thread Refback 05-15-08 06:37 PM
Possible Diesel Combo In 1500 - FSC Forum This thread Refback 04-24-08 04:53 PM
Outer Limits 4x4 Board :: View topic - County engine options This thread Refback 04-22-08 06:02 AM
Swapping a TDI into a Land Rover - TDIClub Forums This thread Refback 04-04-08 09:27 AM
4bd1t/2t vs. 4bt - Cummins 4BT Forums This thread Refback 04-02-08 04:37 AM
1997 Landcruiser conversion - ToyotaDiesel.com Forums This thread Refback 03-30-08 02:38 PM
STICKY: Isuzu 4BD1T/4BD2T Reference - Cummins 4BT Forums This thread Refback 03-25-08 09:13 PM
4bd1t/2t vs. 4bt - Cummins 4BT Forums This thread Refback 03-22-08 05:54 PM
4bd2tc into cj7 w/NV4500/dana300 without dual flywheels - Cummins 4BT Forums This thread Refback 03-22-08 02:14 PM
4BD1T 1970's F250 - Cummins 4BT Forums This thread Refback 03-10-08 06:23 AM
Diesel Engine Conversion Thread-Japanese Diesels - Page 2 - Binder Bulletin Forums This thread Refback 03-09-08 12:09 PM
Other Great Isuzu 4BD1T Sources - Cummins 4BT Forums This thread Refback 03-09-08 11:13 AM
isuzu 4BD1T swaps?! - Cummins 4BT Forums This thread Refback 03-03-08 04:27 PM
Untitled document This thread Refback 02-26-08 05:57 PM
4bd2tc into cj7 w/NV4500/dana300 without dual flywheels - Cummins 4BT Forums This thread Refback 02-10-08 09:24 PM
Diesel Engine Conversion Thread-Japanese Diesels - Page 2 - Binder Bulletin Forums This thread Refback 02-08-08 05:40 AM
4bd2tc into cj7 w/NV4500/dana300 without dual flywheels - Cummins 4BT Forums This thread Refback 02-05-08 09:28 AM
Isuzu 4BD diesels.. New forum... - Expedition Portal Forums This thread Refback 02-01-08 10:17 AM
4bd2tc into cj7 w/NV4500/dana300 without dual flywheels - Cummins 4BT Forums This thread Refback 01-31-08 09:13 PM
4bd2tc into cj7 w/NV4500/dana300 without dual flywheels - Cummins 4BT Forums This thread Refback 01-31-08 05:47 PM
4bd2tc into cj7 w/NV4500/dana300 without dual flywheels - Cummins 4BT Forums This thread Refback 01-31-08 03:44 PM
solenoid isuzu :: BoardReader This thread Refback 01-23-08 04:17 PM
Madcowdungbeetle builds a rover... - Page 3 - Pirate4x4.Com Bulletin Board This thread Refback 01-18-08 12:36 PM
Build-up: Jeep YJ w/ Isuzu diesel - Pirate4x4.Com Bulletin Board This thread Refback 01-15-08 07:35 PM
Build-up: Jeep YJ w/ Isuzu diesel - Pirate4x4.Com Bulletin Board This thread Refback 01-10-08 07:54 AM
Build-up: Jeep YJ w/ Isuzu diesel - Pirate4x4.Com Bulletin Board This thread Refback 01-08-08 08:19 PM
Untitled document This thread Refback 01-06-08 05:57 PM
Untitled document This thread Refback 12-28-07 05:36 AM
Cars world :: Isuzu :: BoardReader This thread Refback 12-24-07 07:18 PM
Swapping a TDI into a Land Rover - TDIClub Forums This thread Refback 12-24-07 03:48 AM
Untitled document This thread Refback 12-22-07 12:21 PM
4BD1T swap in a Tundra?? - Cummins 4BT Forums This thread Refback 12-21-07 02:22 PM
Other Great Isuzu 4BD1T Sources - Cummins 4BT Forums This thread Refback 12-18-07 11:18 AM
isuzu 4BD1T swaps?! - Cummins 4BT Forums This thread Refback 12-16-07 08:53 PM
