11-08-07, 10:32 PM
#511 (permalink)
Originally Posted by AJ60
Rhino, thanks for that link came in real handy. I still might need to get the 4bd1t engine manual because my engine is dated 10/85 and the turbo housing is in a different place which is where all my question are coming from. I have to do a little work on this motor because its spent all its life on Kodiak island (cosmetic wise). The good thing is that the motor only has 39K original miles (purres like a kitten) and I got it at a really good price so I guess a little elbow grease will pay off at the end. I think I am leaning more on the Chevy NV4500, its cheaper than the H55 but better than having the H42.
There are 3 different turbos that I know of.
A wastegated IHI-RHB6. My 85 year engine had one of these fitted. Good turbo but hard to get parts for.
A wastegated Garrett T25. Like bigfoot, I've seen blurry photos and individual parts but don't know where to find one.
A freefloating T25 (as per Rhino's engine) which bolts up to a T3 flanged exhaust manifold.
The freefloating T25 is the latest of the three and is the same turbo used on the 4BD2. I'm currently running a wastegated T25 (from a nissan 1.8l petrol engine) on mine with excellent results. Gives me 10psi boost before 1500rpm and delivers 19psi at 2000rpm if needed.
11-09-07, 09:26 AM
#512 (permalink)
Originally Posted by RHINO
i just noticed that were over 500 replies and 23 thousand views, is that some kinda record??
Gotta be a record for the most theoretical thread ever.
Greg Thompson
89 FJ62, Unstock.
11-09-07, 10:14 AM
#513 (permalink)
RHINO has one running!
Stock FJ62
SOA Samurai Tintop
Ford E-350 4x4 Diesel
M-29 Weasel
11-09-07, 12:40 PM
#514 (permalink)
that makes 1
Greg Thompson
89 FJ62, Unstock.
11-09-07, 02:06 PM
#515 (permalink)
ASTR and I looked at that...search for our posts. The backside of the AW450 has the same bolt pattern as the A440F, so the A440F's transfer case adapter would likely bolt up, BUT the A440F's output shaft is different length, diameter and spline count than 2WD AW450. *Maybe* an A440F's output shaft would swap in to the AW450, that's something he was hoping to investigate (he had the AW450, I had the A440F). Used A440F output shafts usually have heavily worn splines, so that's a factor when looking to junkyard this dealio. A440F's are also same bolt pattern on the front side, so you could conceiveably do a bellhousing swap to put the A440F/transfer behind the 4HE1, but not only is the A440F input shaft different, but nobody thinks a stock, used A440F is going to hold up to a 4HE1 even if you ignore the high stall of the A440F's torque converter. And building up an A440F wouldn't be cheap.
And I have no idea how similar an A440F's transfer case is to an HF2AV...
Does seem like it could likely work with a custom AW450 output shaft, to me, if the A440F's output shaft would not swap into the AW450.
If I misspoke at all in any of the above, please holler, as I'm a bear of very little brain.
Steve
Originally Posted by alaskacruiser
Hi everyone- looks like I'm late to the game here, but I just finished reading up on this thread. I've been considering an Isuzu diesel swap for over a year now, but did not have enough info. This thread answered a lot of questions.
Is anyone looking into this config for an FZJ80:
Engine: Isuzu 4HE1
Tranny: AW450
Transfer Case: existing HF2AV (FZJ80)
It seems to me this might be the easiest swap because:
1. it does not require an adapter from engine to tranny (although it may require one for the HF2AV transfer case)
2. for those of us in CA, we must obtain an engine with a build date equal to or newer than the vehicle it is going into for it to be legal, which narrows it down to the 4BD2 or the 4HE1
But has anyone looked into the basics of this config like clearance issues, etc? Has Rodney from Wholesale Automatics in AU responded to the questions about the AW450? Does he offer an extreme tranny rebuild on the AW450?
TornadoAlleyCruisers
11-09-07, 02:21 PM
#516 (permalink)
Originally Posted by theSherpa
ASTR and I looked at that...search for our posts. The backside of the AW450 has the same bolt pattern as the A440F.......
I have both the AW450 and a A440F transmissions in my possession. My intent is to do a side by side comparison of the two with hopes of combining parts from both to come up with a hybrid that will allow a 4HE1 to be mated to the TLC split t-case. I have great intention, just haven't had the time. When I do get to it, I'll post results.
The AW450 was never availble with the 4BD1/2 engines therefore this will be of little help for those looking to swap in a 4BD1/2.
Stock FJ62
SOA Samurai Tintop
M-29 Weasel
11-09-07, 02:24 PM
#517 (permalink)
theSherpa and astr- thanks for the info!
I was looking into the transfer case compatibility issue earlier in terms of A440F w/ an HF2AV and here is what I found:
http://forum.ih8mud.com/80-series-tech/147536-a440f-tranny-w-hf2av-tc.html
So it looks like one tranny option is a hydraulic A442F from Rodney at Wholesale Automatics. I will have to followup with him and find out about A440F compatibility with the HF2AV.
User lagwagon also said he would look into this since he has/had an A440F and HF2AV out to compare so I just PM'd him about it.
Hope this helps!
Ex-'93 LC Owner; Now w/ '97 LX, no lockers. Bought 7/02 stock w/35k mi. Now at 113k mi w/ARB bar, OME 850/860, Revo 285s, 150A Alt, SS brake lines, Silicone PHH, Breather Ext, PCV Catchcan, CDL, ScanGauge2, Aux Fan, landtank-fanclutch-mod, Slee Speedo, Mobil 1. Soon: sliders, TJM locker
11-09-07, 04:11 PM
#518 (permalink)
http://forum.ih8mud.com/showthread.php?t=147536
Hope this helps!
Just looking at pictures in the FSM, it looks like the output shaft configurations on the A440F and the AW450 are very similar so it might be feasible to swap them. I don't have any information on the A442F. Here are the FSM pictures for the A440F and AW450 transmissions:
Stock FJ62
SOA Samurai Tintop
M-29 Weasel
11-09-07, 04:13 PM
#519 (permalink)
Yep, my turbo be the first one IHI-RHB6. Your right about it being pretty hard to find parts for. Dougal, are you running the free floating T25 on your 85' 4bd1 currently? If so, what type of mods did you have to do to use it?
11-11-07, 05:57 PM
#520 (permalink)
I just spent a bunch of time reading this thread, I would like this in a 60 also it should be a nice setup, I have driven a NPR and they go pretty well, I even considered putting one in my chevy box truck in place of the 6.5 (after I blew the second one) but the emmisons and computer would need to work so I passed. but in a 60 it should br great. especially if it didn't need a lift.
pat
79fj40 rebuild and 3B diesel conversion
85 fj60 gasser
00 Chevy 6.5 td 14' van
03 Camry
79 triumph T140
"It's a dogs life" aren't we all just dogs anyway?
11-12-07, 12:26 AM
#521 (permalink)
I'm running a wastegated T25 at the moment. It's originally off a Nissan CA18DET petrol motor. Has 0.49 A/R exhaust housing for very quick spool.
I have some boost at 1200rpm, 10psi by about 1400rpm and 19psi before 2000rpm.
It goes very well.
11-13-07, 06:11 PM
#522 (permalink)
Can someone confirm vehicle weight on a '93 16' Isuzu box truck. I could only find one listing on line which gave it a weight of around 12-16,000 lbs. I'm looking at one that will need to be trailered so I've got to find a truck/trailer combo that can handle it.
11-13-07, 09:24 PM
#523 (permalink)
Cab chassis is about 2500kg for the NPR59. The bodies aren't factory and can vary a lot.
11-14-07, 08:06 AM
#524 (permalink)
I have a 94 NPR 16' diesel box truck with automatic transmission and no lift gate. There is no weight on the title but an empty weight of 8,050 is placarded on the side of the truck. As Dougal pointed out, the weight can vary a lot depending on who made the box and what options there are. However, this shoulld give you a good ball park number. The 12-16,000 lbs is most likely the maximum gross weight.
Stock FJ62
SOA Samurai Tintop
M-29 Weasel
11-17-07, 12:28 AM
#525 (permalink)
Astr and Dougal-
Thanks for the correct weights. I've decided to part it in place and drop the scrap off at a local scrapyard.
Well it's taken me 6 months+ to find one but I finally got my Isuzu diesel. It's a 4BD2T that was torn down for a rebuild then never quite put back together. After sitting out in the elements for 3 years it had to be torn down again, gaskets replaced and should be ready to go in my FJ55 in a couple of weeks. Now I just need a tranny behind it.
This brings up question 1. Can I use this transmission with an adaptor to either the transfer case that's in the 55 or the TC that I have from an '85 FJ60? It's an automatic which is what I'm looking for.
Since I bought the whole truck I'm trying to figure out what all I should take off of it either to use on mine or try and sell. The truck itself is a lost cause. Even though there's no damage and it's only got 67k on it, it sat unregistered for 3+ years so the back fees on it make it un-appealing in one piece.
Parts I think I need that aren't on the engine:
Intercooler
Fuel shut off/enrichment motor/cables
Tranny- see above
Fuel/water separator
Radiator?
If anyone else had one they parted out, what's worth taking off to try and sell?
Cab-no damage
16' box
Power steering box
Brake calipers
What else???? It's about a 6 hour drive to where it's at, so I'm driving down, getting what I need then having the rest towed down the street for the scrap metal.
Drew
11-17-07, 10:50 PM
#526 (permalink)
.... Parts I think I need that aren't on the engine:
Intercooler
Tranny- see above
Radiator?...
Drew
If it came with an exhaust brake (vacuum-activated butterfly valve downstream from the turbo) get that as well as the associated solenoids. Get the vacuum reservoir and get the engine shutdown/enrichment motor assembly. It should be mounted on the right side frame rail and connects to the injection pump with one or two cables. It probably is enclosed in a white plastic bag. Also consider getting all the electrical harness with the connectors intact. It is a lot of work to pull it but you'll be glad you have it when you begin the install into your 55. If the truck came with an automatic transmission and your are considering using it, be sure to get the transmission computer and the associated wiring harness.
My philosophy has been to pull anything that might possibly be useful. If you don't use it, you can always throw it away later. If you need it and have to buy it latter, it will probably cost a bunch.
Seems that the biggest hangup that everyone has encountered with this swap is the lack of suitable engine to transmission abapters or Isuzu transmission to Toy t-case adapters. RHINO has successfully installed a 4BD1 in his 55 using the Isuzuswapper adapter. I don't remember which tranny he used but it is posted somwhere here on MUD.
Good luck and keep us posted as to your progress.
Stock FJ62
SOA Samurai Tintop
M-29 Weasel
11-18-07, 07:31 AM
#528 (permalink)
My original plan was to go with the Isuzuswapper adapter which according to the website can use 200R4, 700R4, 4L60 and 4L60E automatic transmissions. Since I now have the transmission, I'm wondering if it will hold up. The challenge will be to either find an adapter or have one made for the transfer case. I don't plan to wheel it real hard so it may work for me.
You're right Astr, I think I'm gonna pull as much stuff off of it as I can or at least as much as will fit in the garage. I'm quickly running out of space as I keep getting more parts and haven't actually put anything on the truck yet! The biggest challenge for me is figuring out what's what. I never saw the engine in the truck and some parts were in storage, in the cab and in the back. What I really need is some diagrams.
I checked out Rhino's when I was in Phoenix last month, what a great ride! He's running the Isuzu adapter with an R150.
11-18-07, 10:57 AM
#529 (permalink)
andrew, a handfull of us here can prolly identify everything, pop a few pics or something and we can get ya all sorted.
Clay
75 BDJ55- biopig
11-20-07, 12:47 AM
#530 (permalink)
I took a few photos but not nearly enough of the underneath.  Any help much appreciated. Looks like I've got a little bit of time before I head back down there again.
11-20-07, 07:55 AM
#531 (permalink)
Yes, that is the Fuel cutoff/enrichment thang. The motor mounts might still be attached to the motor.
Stock FJ62
SOA Samurai Tintop
M-29 Weasel
11-22-07, 10:24 AM
#532 (permalink)
isuzu to 4l60 to toyota transfer case
got the isuzu diesel, 4BD1T mounted up to a rebuilt 4L60 using the isuzu diesel swappers, then an AA adapter to the toyota transfer case. It all went to together really fast, it is amazing what you can do if you throw some money at it!
got the flywheel drilled by a machinist, so that I could attach the IDS spacer.
4L60 trans is a heavy duty K case transmission, with a custom converter for big torque low stall. the output shaft was replaced with the 2WD shaft, provided by the AA kit, so that it worked with the adapter and split case TC.
install flex plate, and adapter ring, and the 4L60 mounts up cleanly.
11-22-07, 10:30 AM
#533 (permalink)
Diesel Train for the FJ62
another few pictures of the Diesel Train!
4bd1T -IDS - 4L60 - AA - TLC splitcase transfer case.
some details I would love some input on.
11-22-07, 10:37 AM
#534 (permalink)
dieseltrain in the FJ62
we slid the whole thing into the FJ62, and it really fits pretty good.
the rear crossmember looks like it can bolt into the same location saving some removal and remounting, and reusing the existing driveshafts.
the motor mounts will be fabbed up from scratch, using a ford mount shown.
plenty of room in the front of the engine.
good clearance on the starter, turbo is a little close to the brake assy but I think will be okay
the pan to pumpkin clearance is perhaps 3 or 4 inches. I have OME lift that I will install to help some of the clearance, but as it sits now without the engine weight on the frame it seems pretty good.
11-22-07, 10:40 AM
#535 (permalink)
is this assembly also required on the 4bd1T? In another post somewhere you guys mentioned the cable that is on the inside of the injection pump, between IP and the engine, this was the enrichment cable?
how is this controlled or actuated?
11-22-07, 04:04 PM
#536 (permalink)
Congratulation! Looks like you've made great progress
Some engines had only a cable that shuts the engine down (my 4BD2 for example). Others had two cables coming from what the manual calls "Engine shutdown unit". The engine shutdown unit is the thing andrew.fletcher has labled "fuel cutoff/enrichment" a few posts prior. The second cable, according to Dougal, is used for enrichment during starting. Here is a link with pictures: http://www.4btswaps.com/forum/showthread.php?t=1710
I've looked through my FSM's and can't find any reference to the enrichment cable but all contain reference to the shutdown cable. I noticed that the engine shutdown unit depends on some additional contacts within the ignition switch to function. I don't know if an FJ62 ignition switch would have the extra contact (labled P1, P2, and A in the diagram below). It may be easier to replace both cables with simple pull cable like the old style choke cables.
I hope this helps.
Stock FJ62
SOA Samurai Tintop
M-29 Weasel
11-22-07, 04:44 PM
#537 (permalink)
The enrichment cable on my 4BD1T is also controlled from that solenoid pack. The cable from that extends to the top of the fuel pump, there is another short cable which connects that to the cam on the side of the pump near the block.
With key to on, this cable pulls and releases, locking the fuel pump into a part throttle position, that's released as soon as the governer starts working (I'm guessing idle speed).
I haven't seen it in manuals either, I pulled my pump governer apart to see how it worked.
11-25-07, 10:17 PM
#538 (permalink)
88tlc - Thanks for the photos and specifics on your conversion. I think I'm gonna end up with the exact same set-up that you have for my 55.
astr- Thanks for the diagram, that will definately help with what wiring to take off of the Isuzu when I strip it.
Definately feeling like progress finally!!
11-26-07, 02:54 AM
#539 (permalink)
Great thead... and thanks for those contributing to the information...
I am definately interested in the aw450 to the toyota transfer case.. I have 2 80's and this would be a great swap, someone take them apart and see if the output shafts are the same please......If so I will be buying a motor and trans very fast... as this would be the best of both worlds and meet the emissions standards here, Then I can keep my 80's even with 4+ $ gas/diesel here in the Kalifornia....
Ray...
97 FZJ80, OME , 305 MTR's , Lockers, and running boards........(Wifes)...
93 FZJ80 OME, toyo m55's. Lockers. (Mine)...
73 fj40 --- project el cheepo... a collection of parts with help from friends....
11-26-07, 08:32 AM
#540 (permalink)
Very cool. about $1400 in kit cost?
Did you decide on the 4l60, then go find one, or did you use it because you had it? Wondering why you didn't use a 4L
Same crossmemember, same driveshafts! Wow that is exciting.
Room in front for an intercooler?
Is the 62 on stock springs right now?
Great job, thanks for pioneering for us 62 guys.
Greg Thompson
89 FJ62, Unstock.
LinkBack to this Thread: http://forum.ih8mud.com/diesel-tech-24-volts-systems/128585-isuzu-4bd1t-swap.html
| Posted By |
For |
Type |
Date |
| isuzu 4BD1T swap?! on (4 Viewing) - Page 10 | BoardReader |
This thread |
Refback |
10-01-09 05:03 PM |
| GM Diesel into a CJ - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
08-27-09 10:48 AM |
| 1996 cummins diesel with frybrid- low power - Forums |
This thread |
Refback |
07-29-09 09:34 AM |
| Isuzu Alternator wiring? - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
07-20-09 03:46 PM |
| 4BD1T enginen weight and max rpm - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
07-14-09 03:08 PM |
| isuzu 4BD1T swap?! on (4 Viewing) - Page 3 | BoardReader |
This thread |
Refback |
07-13-09 03:22 PM |
| 4BD1T 1970's F250 - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
07-06-09 08:29 PM |
| Isuzu 4HE1 Swap on (4 Viewing) | BoardReader |
This thread |
Refback |
06-22-09 12:57 PM |
| 235 CID izuzu diesel questions. - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
05-07-09 08:01 PM |
| 4BD1A izuzu diesel. - Great Lakes 4x4. The largest offroad forum in the Midwest |
This thread |
Refback |
05-07-09 04:14 PM |
| isuzu 4BD1T swaps?! - Page 2 - Cummins 4BT & Diesel Conversions Forums |
Post #0 |
Refback |
05-02-09 08:23 PM |
| Diesel Engine Conversion Thread-Japanese Diesels - Page 2 - Binder Planet Forums |
This thread |
Refback |
04-21-09 02:40 PM |
| Toyota 4Runner 5 Speed Manual, Toyota 4 Runner, Toyota 4Runner Antenna - Argongas |
This thread |
Refback |
03-08-09 11:53 AM |
| Jeep Cj2A Bikini Top, Jeep Cj Exhaust Manifold Gasket Replacement, Jeep Cj5 Exhaust Flange - Polarisdiesel |
This thread |
Refback |
03-08-09 11:24 AM |
| 1994 Toyota T100 Suspencion System, 1994 Toyota Pickup Truck Starter Motor, 1994 Volkswagen Golf Iii Gl - Prestolitealternator |
This thread |
Refback |
03-08-09 11:09 AM |
| Ebay Maxima Headers, Ebay Chevelle Cars, Ebay Motorcycle Classifieds - Husqvarna345E |
This thread |
Refback |
03-08-09 06:21 AM |
| Isuzu Land Rover Conversion, Isuzu Incentives, Isuzu Marine Diesel Engines - Belizelifestyle |
This thread |
Refback |
03-08-09 06:20 AM |
| 1991 Jeep Wrangler Ignition Problems, 1991 Jeep Cherokee Trouble Shhoting Forum, 1991 Kawasaki Ninga Zx11 Repair Manual - Lightningfire |
This thread |
Refback |
03-08-09 06:11 AM |
| 1986 Lincoln Mark Conversion, 1986 Kawasaki Voyager, 1986 Mercedes 300E Overdrive - Mastercraftavenger |
This thread |
Refback |
03-08-09 06:10 AM |
| Isuzu Cgiworld, Isuzu Car Parts, Isuzu Charleston Sc - Lightningrods |
This thread |
Refback |
03-08-09 05:23 AM |
| Yamaha V Star Tire Pressure, Yamaha V Star Motorcycle, Yamaha Venture Accessories - Titangenerator |
This thread |
Refback |
03-08-09 03:26 AM |
| Mercedes Sl Rocker Panel, Mercedes Sl Gas Fuel Gauge, Mercedes Sl55 - Venetianmirrors |
This thread |
Refback |
03-08-09 01:16 AM |
| Motorcycle Rodeo, Motorcycle Rocket Jackets, Motorcycle Routes Arizona - Yamahacanada |
This thread |
Refback |
03-08-09 12:22 AM |
| Heavy Duty Truck Parts, Heavy Duty Fuel Parts Injector, Heavy Duty Truck Tire Service In Minnesota - Ktmgirls |
This thread |
Refback |
03-07-09 01:50 AM |
| 68 Chevy Truck Phantom Billet Grille, 68 Chevrolet C10 Original Rear Suspention, 68 Firebird Parts - Csahb |
This thread |
Refback |
03-07-09 01:19 AM |
| Ford Truck Exhaust Manifold Leak, Ford Truck Clutch Kits, Ford Truck Front Fenders My My Messages - Polarisclothing |
This thread |
Refback |
03-06-09 02:04 AM |
| Used Cars Carson City Nv, Used Cars Calgary, Used Cars Chicago - Thermostatwikipedia |
This thread |
Refback |
03-06-09 01:47 AM |
| Suggestions Please on next vehicle... - Page 3 - Expedition Portal Forum |
This thread |
Refback |
02-08-09 10:21 AM |
| Isuzu Clutch Disk Compatibility - Cummins 4BT & Diesel Conversions Forums |
This thread |
Refback |
01-30-09 01:57 PM |
| 1997 Landcruiser conversion - ToyotaDiesel.com |
This thread |
Refback |
01-28-09 10:41 PM |
| Land Rover with Isuzu diesel engine swap - ToyotaDiesel.com |
This thread |
Refback |
01-13-09 12:36 AM |
| What about Isuzu 2.8 TD's? - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
12-10-08 06:25 AM |
| Land Rover with Isuzu diesel engine swap - ToyotaDiesel.com Forums |
This thread |
Refback |
10-27-08 08:59 AM |
| isuzu - internet discussions | BoardReader |
This thread |
Refback |
08-25-08 07:26 PM |
| 1st post, t100 conversion? - ToyotaDiesel.com Forums |
This thread |
Refback |
07-28-08 11:43 AM |
| isuzu 4BD1T swaps?! - Page 3 - Cummins 4BT Forums |
Post #0 |
Refback |
07-26-08 09:32 PM |
| New here. Isuzu 4HE1-T conversion - Australian Land Rover Owners |
This thread |
Refback |
07-07-08 05:16 PM |
| new old truck... |
This thread |
Refback |
07-06-08 10:19 AM |
| new old truck... |
This thread |
Refback |
07-05-08 06:32 PM |
| isuzu 4BD1T swap?! on (4 Viewing) | BoardReader |
This thread |
Refback |
06-20-08 05:44 PM |
| 4bd2tc into cj7 w/NV4500/dana300 without dual flywheels - Cummins 4BT Forums |
This thread |
Refback |
06-04-08 08:59 AM |
| Build-up: Jeep YJ w/ Isuzu diesel - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
05-19-08 09:17 PM |
This thread |
Refback |
05-15-08 07:22 PM |
| Cars world :: Isuzu :: BoardReader |
This thread |
Refback |
05-15-08 06:37 PM |
| Possible Diesel Combo In 1500 - FSC Forum |
This thread |
Refback |
04-24-08 04:53 PM |
| Outer Limits 4x4 Board :: View topic - County engine options |
This thread |
Refback |
04-22-08 06:02 AM |
| Swapping a TDI into a Land Rover - TDIClub Forums |
This thread |
Refback |
04-04-08 09:27 AM |
| 4bd1t/2t vs. 4bt - Cummins 4BT Forums |
This thread |
Refback |
04-02-08 04:37 AM |
| 1997 Landcruiser conversion - ToyotaDiesel.com Forums |
This thread |
Refback |
03-30-08 02:38 PM |
| STICKY: Isuzu 4BD1T/4BD2T Reference - Cummins 4BT Forums |
This thread |
Refback |
03-25-08 09:13 PM |
This thread |
Refback |
03-22-08 05:54 PM |
This thread |
Refback |
03-22-08 05:54 PM |
This thread |
Refback |
03-22-08 02:14 PM |
| 4BD1T 1970's F250 - Cummins 4BT Forums |
This thread |
Refback |
03-10-08 06:23 AM |
| Diesel Engine Conversion Thread-Japanese Diesels - Page 2 - Binder Bulletin Forums |
This thread |
Refback |
03-09-08 12:09 PM |
| Other Great Isuzu 4BD1T Sources - Cummins 4BT Forums |
This thread |
Refback |
03-09-08 11:13 AM |
| isuzu 4BD1T swaps?! - Cummins 4BT Forums |
This thread |
Refback |
03-03-08 04:27 PM |
| Untitled document |
This thread |
Refback |
02-26-08 05:57 PM |
This thread |
Refback |
02-10-08 09:24 PM |
This thread |
Refback |
02-08-08 05:40 AM |
This thread |
Refback |
02-05-08 09:28 AM |
| Isuzu 4BD diesels.. New forum... - Expedition Portal Forums |
This thread |
Refback |
02-01-08 10:17 AM |
This thread |
Refback |
01-31-08 09:13 PM |
This thread |
Refback |
01-31-08 05:47 PM |
This thread |
Refback |
01-31-08 03:44 PM |
| solenoid isuzu :: BoardReader |
This thread |
Refback |
01-23-08 04:17 PM |
| Madcowdungbeetle builds a rover... - Page 3 - Pirate4x4.Com Bulletin Board |
This thread |
Refback |
01-18-08 12:36 PM |
This thread |
Refback |
01-15-08 07:35 PM |
This thread |
Refback |
01-10-08 07:54 AM |
This thread |
Refback |
01-08-08 08:19 PM |
| Untitled document |
This thread |
Refback |
01-06-08 05:57 PM |
| Untitled document |
This thread |
Refback |
12-28-07 05:36 AM |
This thread |
Refback |
12-24-07 07:18 PM |
This thread |
Refback |
12-24-07 03:48 AM |
| Untitled document |
This thread |
Refback |
12-22-07 12:21 PM |
| 4BD1T swap in a Tundra?? - Cummins 4BT Forums |
This thread |
Refback |
12-21-07 02:22 PM |
This thread |
Refback |
12-18-07 11:18 AM |
This thread |
Refback |
12-16-07 08:53 PM |
