Old 12-21-06, 09:16 PM   #1
junkyard dog
Henry James the 47th's Avatar
TLCA# expired
2H and 12H-T question
Does anyone out there have familiarity with the exhaust maniforlds found on the 2H and 12H-T? are they identical or, as I am thinking, do the manifold on the 12H-T flow better because of the turbocharger?
Henry James the 47th is offline   Reply With Quote
Old 12-22-06, 03:58 PM   #2
Tapage's Avatar
I'm not sure if are identical .. see my turbo setup thread I found a factory adapter that is bolt on in my factory exhaust manifold and bolt on to factory turbo of 12H-T engines ..
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 12-22-06, 04:07 PM   #3
they are not identical.
what do you mean by better flow? what really restricts the flow is the exhaust diameter. if you switch to a 2.5 inch exhaust you'll get much better flow.
j
turboed 84HJ60,
in San Diego.
Jan-78FJ40 is offline   Reply With Quote
Old 12-22-06, 05:44 PM   #4
Talos's Avatar
but a exhaust manifold from a 12H will fit a 2H right?
-1971 Toyota FJ-55 44" 302 etc.
-1993 Toyota Carina E 2,0 GLi
-1987 Toyota HJ-61 38" 12H-T http://forum.ih8mud.com/60-series-wagons/134457-hj-61-project-pics-ahoy.html
Hj-61 intercooler: http://forum.ih8mud.com/diesel-tech-24-volts-systems/181830-hj-61-intercooling-thread.html
Talos is offline   Reply With Quote
Old 12-22-06, 05:47 PM   #5
Yes, I think so. probably the easiest would be to see if the gaskets are the same, then it'll fit.
turboed 84HJ60,
in San Diego.
Old 12-22-06, 06:55 PM   #6
UpsideDown's Avatar
Generally speaking, the flow characteristics of forced inducion manifolds are different than NA manifolds. For forced induction, certain factors are much less important - so they are designed differently and may actually produce worse flow in a NA engine.
On the exhaust side of things, I wouldn't worry too much about the manifolds, they are short and stout. I'd look at the pipes and see if there are restrictions or sharp bends that can be eliminated. A slight increase in diameter when doing upgrades is beneficial as well, but going to massive pipes can actually harm performance.
1978 FJ40 - parts vehicle - PM me
1987 HJ61 VX 5spd - loaded - daily driver
1981 BJ42 - ARBs, Warns, oba, ps, h55f, hws, soa
UpsideDown is offline   Reply With Quote
Old 12-22-06, 07:20 PM   #7
junkyard dog
TLCA# expired
Alright then, where does "slight increase" leave off and "massive" begin? Is 2.5" too much? What are the typical sizes available, from stock, and where does the size begin to harm performance?
on another note, I've got to extract some bolt stubs in my exhaust manifold, and I think I'll go with the left handed drill approach. Anyone got pictures of what the factory heat shield plate looks like?
Old 12-22-06, 07:34 PM   #8
UpsideDown's Avatar
Slight increase would be in the range of 0.5" to 0.75" diameter, massive would be 2"or 3" increase in diameter....
You can get exhaust tubing in many different sizes.... just have a look online. usuallly piping in exhausts is larger towards the engine and slightly smaller towards the tail pipe. Reason being is that hot gases require larger pipes to flow well and as they cool you can use slightly smaller pipes and have the same flow characteristics. Using the same diameter throughout is easier.
Often there are bottle necks in exhaust systems that can be removed to help performance considerably. Have a look at what you've got and try to figure out where they are.
As for removing broken studs, hopefully there is something sticking out. You can try vice grips or welding a nut to the stick-out (allow to cool well before trying to remove when using a welded nut).
If not, then grind the end as flush as possible and centre punch the stud and drill it. You can use an easy-out type extractor in some cases; in others you can drill almost up to the original bolt's diameter, once you get close to the threads in the head, you can try to pick out the offending pieces. Often re-dressing the threads with tap or thread chaser is a very good idea.
Good luck, removing broken studs can be a real test of patience.
Old 12-22-06, 09:00 PM   #9
crushers's Avatar
this statement is true with a gasser, no back pressure
but with a diesel, decent size is 2 1/2" anything bigger will not harm the engine or the performance but is a waste of money.
Wayne in Ontario
Cheap Loan | Ringtone | Property Search | Books | Free All Ebook PDF Download
