Old 12-18-06, 01:38 PM   #1 (permalink)
1HDt Turbo oil connections
Does anyone out there have, or have any idea where I can get a replacement part for the oil inlet/outlet gasket and assembly that connects the stock turbo to the engine. I don't have the part #, basically small metal tube from the block into the turbo, and then a metal return line that connects to a rubber tube.
Mine failed a month or so ago, 8 liters of oil on the coquihalla and a near end of engine experience. Had the peice repaired and it is failing again.. Any chance you can help me out, I am really desparate!
1990 VX Limited Cruiser, 4.2 1HDT Diesel, Turbo, centre console stock fridge and icemaker, 285.75.16 and OME 2.5 Heavy lift. Racks all around.
gmalpass is offline   Reply With Quote
Old 12-18-06, 02:16 PM   #2 (permalink)
Try G&S for used stuff or give ATEB a call.
90 VX Ltd, HDJ81 RHD, 1HD-T 4.2l turbodiesel, auto, BFG 285-75-16 AT's, 3" lift, 15mm spacers all round, OME heavy / medium springs, triple locked, JDM tube frt bumper, 3" mandrel bent exhaust, aeroturbine muffler, Safari Snorkel. SOLD - to backroads backpacker...
Martin White is offline   Reply With Quote
Old 12-18-06, 04:59 PM   #3 (permalink)
Mod in Hibernation
brownbear's Avatar
Call GandS... they can either help or direct you to help
-91 FJ80, wife's ride
Old 12-20-06, 02:05 AM   #4 (permalink)
Supporting Vendor
70sguy's Avatar
Garage
If you need one ASAP we can borrow one off an engine we have in the shop and sell it to you.
15407-17010 is the main number, it subs to 15407-17011
Pipe Sub Assy, Turbo oil inlet 9001-9501 1HD-T
gasket is 15471-58010 should be available from your Toyota dealer.
Sheldon
97 FZJ80 Antique Sage 40th 1HD-FT H151F HF1A Converted
Rage big bore 3" exhaust, Walbro FRB-5 pusher, Hallman Boost controller,
ARB winch bar, OME 850/860, Slee Blues, Engel Fridge,
M101 Trailer, Eezi Awn 2200 RTT
VW A4 Jetta TDI
My other diesel is a Locomotive
70sguy is offline   Reply With Quote
