Old 11-30-06, 08:56 PM   #1
rutbeer's Avatar
1hz dry start
I'm trying to test run a 1hz and can't get it to fire over.
Glow plugs run manually for 30secs, new fuel, fuel cut engaged, and starter over for 30 sec at a time.....nothing.
I know the fuel lines were completely dry, but what am I missing?
I know the 13BT has a primer pump, but the 1hz does not.
Would too much air in the lines keep it from firing at all?
How would I go about bleeding that out on this one?
No...I don't have a manual, but I have a good understanding of the electrical as is.
78FJ40 w/13BT diesel (BIESEL),66FJ45(MARMUT), 13BT install thread
www.importpurist.com
"Much like a cat or hot buttered toast, the correct side will always try to land down. If the bezel is on upside down, then the force of it trying to right itself may cause you to roll your cruiser unexpectedly."
rutbeer is offline   Reply With Quote
Old 11-30-06, 11:42 PM   #2
crushers's Avatar
crank it over longer, you can crack the injectors to get out the air but i suspect you are just not cranking long enough...
Wayne in Ontario
Old 12-01-06, 12:41 AM   #3
Diesel for blood
roscoFJ73's Avatar
Take the glow plugs out ,remove at least 3 injector lines( 6 is better) from the injectors.
Spin engine on the starter until fuel comes through.(it will spin oh so fast )
Replace the injector lines and glow plugs
The 1 HZ should have a pump on the fuel filter(like some 3B) and use that to pump the fuel to the fuel pump 1st
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
roscoFJ73 is online now   Reply With Quote
Old 12-01-06, 09:51 AM   #4
rutbeer's Avatar
There is no fuel filter on this.....other than the one I put on the end of the fuel line and put that in the fuel can. I think I might try hooking up a temporary electric fuel pump just to force feed the fuel up. Though cracking the lines to the injectors and actually witnessing the fuel at that point, is a good idea. Diesels are kind of odd in that you can't smell the fuel like you can on a carb'd engine to know if it's there or not.
Thanks for the info!
Old 12-01-06, 05:58 PM   #5
Diesel for blood
roscoFJ73's Avatar
I think it mandatory. God knows how long it will take to squeeze all the air through the injectors
Taking the glow plugs out is what really helps as the engine will turn over like its idling .
The way I explained it is from the FSM with some poetic lic but it got my rebuilt 1HZ started within 20 seconds once all the lines and plugs were reattached.
Instead oF connecing an electric fuel pump you could could fill the fuel hose via a funnel and keep the fuel can higher than the fuel pump.
I got another 1HZ running this way in the back of a 6x4 trailer
33 in BFG A/T
Volvo 740 GL
Old 12-01-06, 08:08 PM   #6
crushers's Avatar
i love that idea, thanks...
Wayne in Ontario
Old 12-30-06, 04:46 PM   #7
rutbeer's Avatar
Worked like a champ.
Glow plugs out, injector pipes open, electric fuel pump for just a few seconds.
Buttoned it back up and it fired the first time, no throttle, no glow....perfect.
Sweet motor...gotta love the sound of these things.
Thanks!
Property in Spain | Credit Cards | Gas Suppliers | St. Pete Tropicana Field Tickets | Mobile Phones
