it's a wooly worm
What is the correct operating temperature?
does the correct operating temperature of a diesel engine, equal the thermostat opening temperature?
#2 | |
Diesel for blood
Different thermos open at between 88-92 (I think) depending on the climate. __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
TLCA# 16387
Simon, I used to block off the rad in the winter with cardboard to keep the temps up. The Canadian BJ60's and others had a radiator blind from the factory (mine was removed so I could get the A/C to fit).
__________________ '82 BJ60 H55 tranny, AXT turbo 3B diesel, high nickel alloy head, A/C, BDS lift, factory PTO, Aussie rear locker, OEM LSD front, 4:11's, 32's, PERFECT frame! '76 FJ55, 3B turbo, alloy head, H41 tranny, 3 sp. transfer, 33's, A/C, PTO winch, long range tank! '67 FJ45LV shop project c/w 3B turbo diesel transplant & H41 4 speed, 3 speed transfer, PTO! www.wirrell.com |
diesels run inheriantly colder than a gasser and a winter wind block is a good idea.
the thermostate for CDM models is 88C and that is what these engines run at, as Rosco says + or - a bit... __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
[quote=crushers;1595292]diesels run inheriantly colder than a gasser and a winter wind block is a good idea.
quote] Do you block the whole front of the rad or just partially? If partially how much of it do you block off? Last edited by Haggs; 11-28-06 at 10:48 AM. Reason: poor spelling |
what i do is run 2 pieces of cardboard just over half the width of the rad opening. this way i could block off the whole rad if i wanted or i could slide one piece over the other for an opening up to 1/2 the rad...
it seems to work well... __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
it's a wooly worm
yep using the radiator blind. i now see the advantage of the webasto/espar heating systems for the colder parts of Canada, to bring those diesels upto operating temp.
it's -25c at the moment.
Diesel for blood
Its proven to be kinder to your engine also. All that expansion from those low temps to operating temp every day must cause a lot of wear.
Free Advertising | Mortgages | Problem Mortgage | Advertising | Credit Card |
