Old 11-25-06, 01:27 PM   #1
toynut's Avatar
Heavy's or medium's for front of a diesel 60 ?
I am biting the bullet and putting in the ome dakar full kit in my 85 bj 60 i am wondering as most of the info i find is for fj's , would i be better served with the medium or heavy springs up front and what about the rears heavy's i asume , stock 3b no plans for long range tank or winch .
1984 red Bj60 sold
1984 brown Bj60 sold
1985 gray Bj 60 sold
1988 FJ 62 My current Ride
Wanted Fj 40 project .
toynut is offline   Reply With Quote
Old 11-25-06, 01:33 PM   #2
lshobie's Avatar
Depends on what you are carrying on the front and back. If you never really carry a load in the back then go medium or you will end up with a hard ride. If you have bullbar and winch then go heavy on front, if not go medium as well.
Louis
Check out my youtube videos at: www.youtube.com/lshobie
Join the True North Toyota Land Cruiser Club in Ottawa http://landcruisers.ca/
lshobie is offline   Reply With Quote
Old 11-25-06, 01:40 PM   #3
toynut's Avatar
the dakar rear heavy's are a dual rate spring for 0 thru gvw rating so i would use them i see no need to go with a medium rear being they would offer no better ride unloaded and a poor ride loaded , the front is my main concern .
1984 red Bj60 sold
Old 11-25-06, 04:48 PM   #4
Diesel for blood
roscoFJ73's Avatar
Get the heavy's all round . If you are not going to be carrying a heavy load,remove a leaf from each pack.
When the springs get old you can put the leaf back in.
There is little weight difference between the BJ/FJ/HJ.
I dont think the dual rate spring will articulate quite as well as a normal leaf pack
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
Old 11-25-06, 05:14 PM   #5
cruiser_guy's Avatar
TLCA# 16387
I do not think that the 3B is any heavier than the boat anchor known as a 2F. Those 2F engines are HEAVY and 2 holes bigger than the 3B!!
www.wirrell.com
Old 11-25-06, 05:28 PM   #6
lshobie's Avatar
Good call Rosco.
Louis
Old 11-25-06, 06:51 PM   #7
On my BJ62 I put light on front and rear, original OME, 2 1/2 years ago...she still is sitting level( little high in the rear) and smooth as the day I put them on...actually no sag whatsoever. The improvment over the original setup was incredible. I carried about 1000 lb combined on the top and in the back this summer and no bottoming at all...still rode smoothly.
HTH'S, Daryl
74 fj/bj40
88 fj/bj62 , full OME lift kit , home brew turbo , 4 runner brakes .
fjbj40 is online now   Reply With Quote
Old 11-25-06, 07:44 PM   #8
Toy nut im in oz and ive got a fj60 and a hj61sahara,12ht motor,just had to drop that in,anyway the fj has a great set of springs on it,i think there opposite lock comfort springs,they must be about ten years old and have hardly sagged at all,shackles still sit nearly vertical,about 2-2.5 lift,im selling the fj si i thought I might change the springs over before hand,I pulled all the springs off the fj then put the fronts on the hj61,lowered it to the ground and they just flattened out,it was sitting at about stock sagged height,I was surprised,so I had to put the bloody things back on the fj,I changed bullbars over to prior to this so you cant blame anything but the difference mainly in motor weight,just a word of warning to ya about the diff between petrol and diesel ones.
cheers goldchaser
goldchaser is offline   Reply With Quote
Old 11-25-06, 07:54 PM   #9
Diesel for blood
roscoFJ73's Avatar
cheers goldchaser
I did a swap from a 3F to a 1HZ and the uspension didnt change at all in height or ride .My standard duty springs springs were about 3 yo
Maybe your 10 yo springs were borderline.
As far as I know all the aussie spring companies make one spring for all engines
33 in BFG A/T
Volvo 740 GL
Old 11-25-06, 10:33 PM   #10
Yeah I know what ya saying rosco and to some extent you maybe right,how heavy is a 12ht?I know how heavy a 3f is so I thought it should have been ok,fj had duel batts too,hj hasn't yet,I reckon a little bit of both,little bit of extra weight and spring age,couldn't leave them on there though.
goldchaser
Old 11-26-06, 02:00 AM   #11
Diesel for blood
roscoFJ73's Avatar
goldchaser
The 12HT is probably the heaviest diesel they made,but the difference couldnt be more than 75 kg,so if you sat on the front of your FJ they should flatten out like you got a 12HT in there
If it was really a lot heavier Toyota would have given them a different spring pack.
33 in BFG A/T
Volvo 740 GL
Old 11-26-06, 07:36 PM   #12
Geez roscoe im not that overweight!
goldchaser
Old 11-26-06, 07:59 PM   #13
it's a wooly worm
Gold Boy's Avatar
heavy - so what if you get a bad ride
BJ74 & TUFT & U-AFPT
Gold Boy is offline   Reply With Quote
Old 11-27-06, 01:21 PM   #14
sandcruiser's Avatar
your best bet: call ARB and ask. They've got great tech support.
If you have a bullbar &/or winch &/or 2nd battery you will probably find that the heavy springs work better for you.
After about 5 years on our heavy fronts, I'm about to add another leaf before I re-install my winch. As-is with the bullbar it is fine, but could be a tad taller. With the winch, I think it'll prefer the exta umph.
But it also depends on how heavy you load your rig- remember that when you drive downhill and brake, it shift a lot of the weight from the rear forward, compressing the front springs. Over 5 years or so, that adds up.
91 fj80 w/ 93 1HD-T. OME 850/860 w/ 1" front spacer, LEDs, HIRs, Hankook MT's 31x10.50r15, Tuffy center, ARB rear locker (in progress), in garage: lightforce lights, full rack, superwinch X9, maggiolina tent, hella horns. WTB: Tan DS mirror & housing
'88 HJ60, "Louie" For Sale in Costa Rica.
sandcruiser is offline   Reply With Quote
Old 11-27-06, 02:54 PM   #15
crushers's Avatar
i would say order heavy and remove leaves till you get the ride you want...
this way you can add a leaf back in should your needs change...
Wayne in Ontario
Old 11-27-06, 03:12 PM   #16
Tapage's Avatar
go heavyes all around ..
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 11-27-06, 06:48 PM   #17
yes, heavy all around. I put Dakar heavies on the HJ60, and it rides great.
j
turboed 84HJ60,
in San Diego.
Jan-78FJ40 is offline   Reply With Quote
Loans | Loans | Cheap Loan | Internet Advertising | Car Finance
