70 series pyro install questions
Hey guys,
I've been procrastinating about installing a pyro in my LJ78, and i figure i'd better get one in there before its too late and i crack another head. I was wondering if anyone had mounted their gauges in the empty DIN slot under a DIN sized aftermarket stereo in their 70 series dash? My prado had a stereo installed when i bought it, and there is a plastic peice covering the extra space where the original stereo was removed. Is it possible to find pyro gauges small enough to fit in there? I'd like to install these as cleanly as i can, and not just slap them up on the top of the dash. Wayne, i noticed in another gauge question post that you had installed one in that location. Do you happen to have any pictures? Did you install any other gauges in their as well as the pyro? |
__________________ 1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car Rising Sun; Former CLCC You should be able to delete your own thread. Communists abound ![]() Real Change is here --> Cato Institute |
ahh, i see....
thank you!! |
#4 | |
cheers __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
I would suggest a mechanical water temp gauge as a must-have for the 2L-TE. The stock gauge is shite - not accurate. The mech gauge gives instant feedback from the engine.
My two bits. |
Mech water temp eh? Ok, what i was thinking was A pyro to watch the EGTs so i have something reliable to watch to make sure i dont cook the engine. Would a Mechanical Water Temp gauge be telling me the same stuff? Would it be redundant? I mean, if the pyro says i'm running hot, wouldnt the water temp just say, "yes i agree, you are running hot"? Is it worth having both?
no the 2 systems are completely independant of each other, you could be running 1600F EGT and the water temp be normal or you could be running 1000F EGT and have an over heated cooling system.
my suggestion is run the pyro, boost and water temp gauges and increase your boost to 14 lbs. this helps drop the EGTs and gives you better performance... __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
Pyrometer gives you quicker and realistic feedback of exhaust temperature and its important when you tune up your engine, dont forget to put air pressure gauge also to your exhaust manifold.
Its also important when you boost up more than stock, and guess what?If you put bigger exhaust pipe than original, your exhaust pressure might rise...
Credit Check | Web Advertising | Loans | Loans | Loans |
