Old 11-16-06, 08:15 PM   #1
coldtaco's Avatar
13B-T, where is blook coolant drain?
Wondering where the block coolant drain is located? According to the manuel I have, it says it is in the front left of block, but in the picture it shows it at the rear left of block? How do you identify it? There is what looks like a bolt just back and a little lower of the rear block freeze plug. Left and right is in refrence to looking at the front of the engine from behind, right? So on drivers side for us LHD vehicles? Bought a external coolant heater that needs to be plumbed into the block drain and a heater coolant line. If it's where I think it is, might be easier to just replace the block heater, even though it is a major job. Hmmm
coldtaco is offline   Reply With Quote
Old 11-16-06, 09:47 PM   #2
A lower rad hose heater is easier to install and more effective for heating the engine than a gravity circulator external coolant heater.
Old 11-16-06, 10:59 PM   #3
coldtaco's Avatar
Well, the block heater does get hot to the touch, but you can't hear it "cooking" like you can normally hear them. So, I have decided to give up on the remote located type of heater and install a extra lower rad hose heater. Thanks for the help. Someday, a Webasto
Old 11-17-06, 08:37 AM   #4
Greg_B's Avatar
TLCA# 7091
Sounds like you are going with the lower rad hose heater, however for future reference it is on the left side, just rear of the injection pump. There is a fitting into the block, which has a brass plug screwed into it. Undo the brass plug a little and coolant will start coming out the hole that is on the underside of the fitting.
hth's
gb
Free Advertising | Loans | Bleach Anime Forums | Problem Mortgage | Debt Consolidation
