Old 11-05-06, 09:57 AM   #1
toynut's Avatar
will a 13bt fit directly into a fj62
I have found a decent fj62 , i would consider buying it and driving it while i find a 13bt if one can easily be put into a 62 ? should be the same as a 60 ?
thanks kevin
1984 red Bj60 sold
1984 brown Bj60 sold
1985 gray Bj 60 sold
1988 FJ 62 My current Ride
Wanted Fj 40 project .
toynut is offline   Reply With Quote
Old 11-05-06, 09:59 AM   #2
stevek's Avatar
TLCA# 5372
Stickboy did that swap into a 60 and did an awesome writeup
http://forum.ih8mud.com/showthread.p...eat+glow+timer
1993 FZJ80 lockers and leather
1981 HJ47 2H-T H55f
2002 Lexus Ls430
TLCA 5372
stevek is online now   Reply With Quote
Old 11-05-06, 11:01 AM   #3
Diescipel's Avatar
TLCA# 14854
Should be the same as a 60. The question is are you going to do just an engine swap or engine/tranny combo? I don't know about compatibility between the 13BT and the A442. Somebody else who does will probably chime in....
B
Brendan
1983 BJ42 bioD, lots o' Aqualu, TIC Parabolics/DT8000s, Tuffy, 33x9.5 BFG ATs, SOLD
Diescipel is offline   Reply With Quote
Old 11-05-06, 11:30 AM   #4
A2B in a TLC's Avatar
TLCA# 15095
My 1988 BJ74 with 13BT has an A440 tranny.
Bruce
Bruce, '76 FJ40 (sold long ago), '88 JDM BJ74V (recently sold), '86 HJ60, TLCA #15095, Coastal Cruisers member
"The worst moment for any atheist is when he feels grateful for something and has no-one to thank."
A2B in a TLC is offline   Reply With Quote
Old 11-05-06, 04:52 PM   #5
Diesel for blood
roscoFJ73's Avatar
thanks kevin
You will have to cut and weld some new mounts and get the appropriate radiator and transmission.
It is doable as the 62 is much the same as a 60
If a 12HT could be sourced it would be a little easier and much nicer to drive.
Of course a 12HT i going to cost more
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Volvo 740 GL
Old 11-06-06, 01:20 AM   #6
zander's Avatar
thanks kevin
For what its worth here is my thread on a 12h-t swap. A source on the motor and details about the mounts as well...
http://forum.ih8mud.com/diesel-tech-24-volts-systems/108473-hj60-frame-powertrain-swap-12ht-a440.html
zander is offline   Reply With Quote
Old 11-06-06, 12:28 PM   #7
mac
rust and moth consumables
mac's Avatar
I think the A440 w/ a 13bt will have a different valve body than w/ the 3FE.
-Peter Mac-
1990 HDJ81
1997 40th
1967 Norton Atlas
1986 Yamaha RZ350
1996 Ducati 900SS SP
Ya...it's like crack to me...
www.bestinshowexhibits.com
mac is offline   Reply With Quote
Old 11-06-06, 03:34 PM   #8
Stone's Avatar
TLCA# 13772
should be a different bell housing also...
Stone's Land Cruiser & Flyfishing Pics
Flyfishing British Columbia: www.flyfishbc.com bcfishingreports.com
Stone is offline   Reply With Quote
Old 11-07-06, 11:45 PM   #9
70sguy's Avatar
If you are interested in a 13B-T w/ A440F or a 12H-T w H55F
shoot me a pm. Ciaran at CruiserLand Ent is putting a 13B-T/ H55F into a customers FJ62 right now.
93 1HD-T powered FZJ80-Extreme valve body-Walbro-ARB- Snork-OME- SOLD!
97 FZJ80 Antique Sage 40th, bone stock. 1HD-FT 5spd conversion starting soon
VW A4 Jetta TDI
My other diesel is a Locomotive
www.gscruiserparts.com
70sguy is online now   Reply With Quote
Old 11-08-06, 03:39 PM   #10
Tapage's Avatar
I'm pretty sure matting a 13B-T with a 440 is posible .. but with a 442 more complicated .. coz it never come and the 442 was born in 90 ! not in 80
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Tapage is online now   Reply With Quote
Old 11-08-06, 03:56 PM   #11
crushers's Avatar
different imput shaft in the tranny from the gasser to the diesel...
Wayne in Ontario
crushers is online now   Reply With Quote
Old 11-09-06, 01:11 AM   #12
ylexot's Avatar
Tell me more about the transmission mating.
I am considering using a dead engine FJ62 as a donor for my Bj60. I am a little ambivalent about the transmission so long as it has an overdrive gear, ie something other than my 4spd. The 62 obviously has the A440. So, I'm wondering if I can adapt it to my B3?
I know the HJ60s had the A440 as an option. Can the shift points of a gasser A440 be adjusted to the needs of a diesel? What else is involved?
Timothy
1989 FJ62
1985 BJ60instein (for sale )
1981 BJ60 RIP (engine kindly donated to the '85 )
1984 Mercedes 300SD - biodiesel
ylexot is offline   Reply With Quote
Old 11-09-06, 02:16 AM   #13
70sguy's Avatar
3B onto an A440? Don't go there. A 3B can't afford the loss of power through the tranny... ya ya.. I know, you can turbo the 3B. I would go 13B-T minimum. As Wayne mentioned, different input shaft splines. If you are going to put the 3B in then put the 4 or 5speed in along with it.
1HZ H55F 5speed makes for a nice 60 powerplant. 130 hp, 189ftlbs, about the same numbers as a stock 2F, you can turbo em with great results.
VW A4 Jetta TDI
Old 11-11-06, 12:32 AM   #14
ylexot's Avatar
Hmm... now I'm stuck in a pickle.
Basically, I love the 60 series. But my wife doesn't like riding in it as is, ie she wants more modern amenities. I admit I'd like a quieter interior (carpet would be a big upgrade from the no-mess floor) and comfortable seats myself.
I also love the diesel. I've found my B3 plenty powerful for my needs. Doesn't lag on the highway up hills. Merges with traffic reasonably well, though won't win any drag races. Climbs the mountain just fine.
I can't afford to restore my rig. I can't really afford a good clean donor cruiser. I've seen a couple DOA 4runners I could afford.
Does anyone know if the B3 would shoehorn into a 4runner and what transmission would be a good fit?
Timothy
1989 FJ62
Old 11-13-06, 04:05 PM   #15
Tapage's Avatar
Let me see .. 3B in a 4Runner .. I thought in 3B with tranny and t-case coz you really need input shaft and so .. for sure if you change the 4 runner t-case you must need to change at least the rear axle housing ..
Old 11-15-06, 03:07 AM   #16
also i believe the input shaft differs between the b, h, and f motors
as for a 3b in a 4runner, i've seen a picture of it done in a hilux which is much the same vehicle. all i remember was it was a very tight fit. I think the radiator still squeezed in though.
as for the transmission i would assume he just used a h55f and split transfer.
rove_mcanus is offline   Reply With Quote
Old 11-17-06, 02:56 PM   #17
thanks kevin
If you fold down the back seat, that 13B-T should go in through the rear tail gate pretty easy. I once had two full 3B's in the back of a BJ60. That 13B-T should fit in there easy.
Peter Straub
Peter Straub
The Replacement for Displacement
Is Introduction of Forced Induction before Combustion
Behemoth60 is offline   Reply With Quote
Old 11-17-06, 06:10 PM   #18
crushers's Avatar
ROTFLMAO!!
Peter for the next US president...
Wayne in Ontario
womens-health-supplement.com | Loans | Personal Loans | Mortgages | Discount Computer Speakers
