Old 11-02-06, 06:26 PM   #1
block heater for 3l jdm engine
hi there would anyone have a part number or size for the knock out for a 3L hilux engine?
winter is coming and no block heater.
thanks
mika
jmika is offline   Reply With Quote
Old 11-02-06, 07:44 PM   #2
crushers's Avatar
lower rad hose heater, should be 1 1/2" (or 1 1/4", buy both and take the one you dont need back)
Wayne in Ontario
crushers is online now   Reply With Quote
Old 11-02-06, 10:08 PM   #3
dieselDaryl's Avatar
I second the lower rad hose heater. they work better than the block heaters (IMO). I find you get heat sooner in the cab sooner than with a block heater as well. I think the ideal heater is aa circulating heater but they are a bit more work to plumb in.. good luck..
Daryl
1987 HJ61VX - "Oreo Speedwagon" - 33"s, 4" Terra lift, PTO, 352,000k
1978 BJ40 - "Babe" - The pretty one. Completely stock but will get a 3B-T in the next year
1991 CDN M101 - "General Jacknife"
dieselDaryl is offline   Reply With Quote
Old 11-03-06, 02:02 PM   #4
You don't want to knock that freeze plug out and find that the block heater you thought would fit doesn't.
The rad hose heater along with an oil pan heater is what I'm doing in my HDJ81.
JDMGoodness is offline   Reply With Quote
Old 11-03-06, 04:32 PM   #5
crushers's Avatar
only downside of the oil pan heater is if you wheel then it can get ripped off or the plug wire get ripped out...
Wayne in Ontario
Old 11-15-06, 11:49 PM   #6
83bj60's Avatar
Question No block heater for the 1HD-T?
Are you guys saying there are NO block heaters that fit the 1HD-T, or is it because it's too much trouble to install?
91HDJ81VX (The Beast), 4B JDM, since Nov 06
83BJ60 (The Old Faithful), Still Running, Gone to a New Home
83BJ60 (Rusty but Trusty), Dec 90 - July 98, Parted Out
76FJ40 (Big Red), April 87 - July 93
83bj60 is offline   Reply With Quote
Old 11-16-06, 01:20 AM   #7
crushers's Avatar
there are none that i know of...
Wayne in Ontario
Old 11-16-06, 08:03 AM   #8
83bj60's Avatar
OK it may sound far-fetched here, but with freeze-plug diameter wouldn't it be possible to source a generic heater? I doubt the space between block and cylinder walls would be so small as to make the installation of a block heater impossible...
I'll check out the freeze plug size later. I like the idea of block heaters much better, if installtion is not too much of a pain, of course... Do you have a source for replacement freeze plugs?
As always thanks for your precious contributions, Wayne!
Chris
Old 11-16-06, 11:27 AM   #9
Mod in Hibernation
brownbear's Avatar
TLCA# 15584
I heard once that unless its really cold stay away from oil pan heaters, as they can burn the oil or cook it a bit. I guess they get really hot. So they should not be used unless its like -20 or more. Anybody else hear that?
I would be careful anyhow.
-91 FJ80, wife's ride
Old 11-16-06, 02:49 PM   #10
crushers's Avatar
i would use one as a last resort...
Wayne in Ontario
Old 11-16-06, 10:35 PM   #11
83bj60's Avatar
I'm going to install a 300W Alaska Pad as soon as I have some free time, but it's going to be on its own 172F thermodisk mechanical thermostat. I'm told high temp engine silicone is a great adhesive, and silicone grease is a great heat conductor.
I've always been really demanding as far as engine warmers are concerned. On my 3B I had a block heater, a rad hose heater and two battery blanket warmers, plus I started a project to build a 4500W electric boiler requiring 240V (working at 1250W on 120V)...
I attribute a lot of my old truck engine's longevity to the good treatment it's always had in winter.
Old 11-17-06, 12:11 AM   #12
Who hear wants to calculate some thermal dynamics.
500W pan heater warming up 10L of oil. Outside temp -15 Celsius.
Timer set for 4 hours.
To remove the heater is just 4 10mm bolts. Takes all of 5 minutes to remove.
Better to be to warm than not start.
Hasn't been that cold yet. Not that I complain about chinooks.
I still wouldn't want to knock out a freeze plug and hope that the block heater fits. Especially on an engine that isn't readily available here.
Loans | Personal Finance | Loans | Internet Advertising | Loans
