Old 10-24-06, 11:11 AM   #1 (permalink)
warpdriv's Avatar
4BT/700R4 FJ60 Conversion Questions
Hi Everyone,
Has anyone done a 4bt/700R4 conversion in a FJ60? If so, can you please share some of the surprises you ran into? I would also like to share/compare shopping list of "stuff" with you.
Thank you,
Jeff Blumenthal
TLCA# 9883
KE5RST
Austin, Tx
1/71 FJ40 Dulcinea 350/700R4/NP203/TLC3SP/SO/FSR/RSR/RSHR
95 FZJ80 DeFlared, DeRunning Boarded, 33s, more to come
www.lslc.org/austin
warpdriv is offline   Reply With Quote
Old 10-24-06, 05:54 PM   #2 (permalink)
AlaskanHerbs's Avatar
ive got a 4bta and a 700r4 in a 62.
but i didnt do any of the work. ask proffit.
problems i had. (have)
-cooling - the fan isnt drawing enough air,
-alternator gone bad
-bad head gasket, ohh, look at that, the head is bad too...
-tranny not shifting properly.
call and talk to jeramiah.
Eat drink and be merry,
for tomorrow we die.
Cheers
AlaskanHerbs is offline   Reply With Quote
Old 10-24-06, 09:55 PM   #3 (permalink)
warpdriv's Avatar
I have emailed and talked to them. Very nice and helpful folks.
Did anything specific happen that made the head gasket/head go bad, like overheating? I was planning on using my FJ60 radiator with a taurus fan.
Jeff Blumenthal
TLCA# 9883
KE5RST
Austin, Tx
www.lslc.org/austin
Old 10-25-06, 11:22 AM   #4 (permalink)
Tapage's Avatar
Garage
Henry ( Exiled in the foruym ) done 4BT swap with NV4500 into his FJ-62
HJ-60 2H-T Intercooled Tencha
Cruisers on my mind, blood and soul !
Old 10-25-06, 11:41 AM   #5 (permalink)
hard to tell for sure. it was running warmer than any of the others hes done. it probably had a bad head gasket to begin with.
im not sure, but i dont think that the 60s radiator will fit when everything is in there.
cheers,
herb
Cheers
Old 01-01-07, 03:08 PM   #6 (permalink)
Will the 700R4 hold-up to the torque pulses of the 4bt? Can a 700R4 be built to take more power? I am thinking about a 4bt conversion and it must have an auto tranny. I was thinking an FJ60/62 transfer case with rebuilt stock Toyota axles.
1996 FZJ80. Mostly stock. 285 Cooper STTs, Projector Headlights, Diff. Lock Mod., New 40th two-tone leather.
1997 FZJ80 40th
6" Slee Lift, Sliders, 2" Body Lift, 11.00x16 XL's, 4.88, rear Aussie Locker, ARB Snorkel, ARB Bull Bar, 10,500 MM Hydraulic Winch, LightForce XGT's, Laptop/GPS/, Intercooled Turbo, Diff Switch, 3" SS exhaust.
MSGGrunt is offline   Reply With Quote
Old 01-01-07, 03:57 PM   #7 (permalink)
warpdriv's Avatar
I talked to a person at bowtieoverdrives.com and they build 700r4s for diesel applications. They said it was not a problem.
Jeff Blumenthal
TLCA# 9883
KE5RST
Austin, Tx
www.lslc.org/austin
Old 01-01-07, 04:45 PM   #8 (permalink)
So, source either a nice running, low miles 4bt or buy a core and rebuild it. I hear they are pretty simple. Buy a 700R4 from my local wrecking yard ($100.00) and rebuild it with a heavy duty rebuild kit and new torque converter, purchase an adapter kit with the chevy bellhousing bolt pattern. What transfer case to use? Stock FJ40 or a newer split case out of a FJ60/62?
Where is a good place to buy the adapter for the 4bt to 700r4 tranny?
1997 FZJ80 40th
Old 01-02-07, 05:43 PM   #9 (permalink)
orangefj45's Avatar
the th700 will hold up just fine if built properly. i built one for a frined to go behind a 6bt a few years ago......
just make sure you start with the right core (88 thru 92) and have it built by somebody who knows what they're doing. don't skimp on the converter either or you'll live to regret it in no time at all. diesels require an HD converter with a much lower stall.
Doing a knuckle rebuild? I have EVERYTHING you'll need.
looking for Advance Adapters or marlin crawler parts? send me a pm!
bill dorry style ps brackets for sale:
http://forum.ih8mud.com/merchandise-...ml#post4481037
orangefj45 is offline   Reply With Quote
