Location: Normandy Park Wa. ........now in San Diego Ca.
internal differances between H55 and H55f
I purchased a BJ-60 with a bad H55 for FJ to BJ transplant. I have a good H55f in the garage. I know the output shafts are different, but how about the internals?
Thx __________________ 1985 HJ-60 (Dk.Gray) Turboed 2H & H55f 5spd, OME 2.5 ... (born a FJ now a HJ) 1980 FJ-40 (Red) w/135k orig and 0 rust 1974 FJ-40 (Green) Restored and sweet ![]() 1987 BMW 325i e30 (Dalphin gray) (my rocket) 1999 Volvo v70-R (Copper) (wifes rocket)
Diesel for blood
The proper name for that gearbox is the H55f regardles of the spline count.
As far as I know there is no H55. Everything inside is the same. __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
everythign is the same between the different H55(F) trannies except the imput shafts for the different applications...
__________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
uh urgent correction.
there are two different H55's, the early open input bearing used to approx 1985-including all bj42's, some bj60's and some bj70's in canada. the later, often using a sealed orange (or black aftermarket) input bearing. the input shafts DO NOT INTERCHANGE, nor do the bearings. pull the figure 8 bearing retainer (front of transmission) and look at the bearings side by side. the late versions are the same internals from 1985+ to 1999- there are bj, hz, 2h& gas inputs that interchange to these models. it's a nightmare to stick a 1983 3B input into a 1989 2H transmission. |
#5 | |
I thought aren't the same H55F for my 2H and for HZ engines .. diferent input shaft again I thought .. |
I have to rethink the process, but the early bearings are 90mm diameter, the later are 92mm. depth to c-clip is also different. A later input could be used with an early bearing and case, but the input would have to be machnined for the c-clip or possibly use a different locking system (twin clips?).
I had this issue with a new input/bearing I supplied to a guy with early transmission in Flagstaff, AZ 4 years ago. machining the case to accept the later bearing is near impossible. ...they don't cross |
#7 | |
![]() Correct , My old 2h shaft on the left with the coarse spline,and a new 1HZ shaft on the right with fine spline also its a bit longer.
I'd need some clarification on this as well.
My 84HJ60 (from central america) had a H55(F?), in bad shape. I purchased a new H55F for a gasser 2F, and stuck it in. did I do something really stupid? It bolted up (with a later HJ60 bell housing)-at least I think it bolted up, and it is running fine (again-I think it is running fine). anyone? or what am I misunderstanding? thanks J __________________ turboed 84HJ60, in San Diego. |
as stated in question these are INTERNAL differences between H55's.
oct 1982-oct 1985 5 speed cast iron transmissions for heavy duty land cruisers (that folks would be a H55, they are all "H55F"'s) uses a front input shaft bearing # 90365-40002 oct 1985-sept 1999 uses # 90363-40035 (subs up in some models to 90363-40037 BUT reverts back to 40035 to end of production of H55) dimensionally these two front bearings are different, therefore the machining in the cast iron case and on the input shaft itself are different dependant on date of production. there is a hard cut off to ease of fit in october 1985 production truck transmissions. spline lengths are irrelevant, we are talking "pre" and "post" oct 1985 ---------------------------------------------------------------------- comments... an april 1985 canadian spec BJ70 input shaft will not willingly fit a common 33030-60450 or -60431 H55 sold new in the US and Canada as of this date, August 21, 2006. If you had a 1984 australian HJ47 troop carrier, you cannot take the input shaft of that transmission and place it into a -60450 or 60431 transmission. A 1987 Canadian spec BJ70 H55 CAN donate it's input shaft to a -60450 or -60431 north american market new H55 for conversion. ENS price on a "1995" HZJ75 H55 transmission is $6,500 cdn. The HZ input shaft in US dollars is $300. The -60450 H55 is $1,550-$1,800 USd. You can take the input shaft out of a -60450 transmission and replace with HZJ input and make the same transmission as the $6,500 cdn unit from ENS. sources: 1981-1987 world J60 parts manual 1988-1992 world J62 parts manual 1984-1990 world J70 parts manual 1990-2004 world J70 parts manual |
#10 | |
__________________ FJ-55 Weatherstripping www.pvcruisers.com FOR SALE: '81 HJ-47 Troopy LHD '07 Vortec Motor, 4L60E Trans, New Steel Body, PPG Paint, Rebuilt from the Ground Up '79 HJ-45 Troopy RHD |
#11 | |
So buy an H55F for HZ input shaft and swap it into 2H H55F is posible with right bearing . ? |
#12 |
no, bearing alone won't make them work.
late transmissions will take HZ input shaft, early transmission cannot (without machine work and then still a ???) october 1985 is cut off date. |
#13 |
![]() ![]() !HZ and 2H bell housings. |
#14 | |
Equity Release | Loans | Per Insurance | Go ACC | Discount Magazine Subscriptions |
