#31 |
just another VI Cruiser
Thanks!
I've also found out that the torque converter doesn't lock up in 3rd gear, so there is a lot of slippage when pulling a load at higher RPMs which can cause the tranny to overheat. Downshifting may reduce EGTs but will increase ATF temps. -Steve __________________ '90 HDJ81 for sale soon: '90 Trooper past: '76 FJ55 - more rust than steel; still miss it |
#32 | |
#33 |
I believe that once the load is on the move you shouldn't have much effort to keep it going but, if you plan to haul for an extended period of time, be sure to let that tranny work where it works best that is if you're going uphill downshift to 2n and go so the engine has enough power but it doesn't mean that you should go fast of course this applies for long and steep hills for a short one you shouldn't have any trouble leaving the trans as is. For the record I've never seen those AT/temp lights go on in any land cruiser i saw it once in a Montero but thats another story. Besides is your tranny working properly have you given it proper care?
#34 | |
__________________ Jonathan Colvin Galiano Island, BC 1990 HDJ81 w. OME, 35'', intercooler, safari snorkel, locked all-round, viair 450 onboard air, deer-killer bumpa + train horns, milemarker hydraulic 1991 PZJ-70 factory lockers and winch. |
#35 |
How you do turn off the full-time 4wd? Is there a switch or fuse or something to turn off? I don't have the manuals - I also don't see some obvious switch on the dashboard that says "4WD off" or something on theI have a 1990 HDJ81 VX Limited.
#36 |
There are kits out there to do this, a set of manual hubs and some parts to replace the center diff in the Tcase. The center diff button becomes the front drive button.
__________________ 93 1HD-T powered FZJ80-Extreme valve body-Walbro-ARB- Snork-OME- SOLD! 97 FZJ80 Antique Sage 40th, bone stock. 1HD-FT 5spd conversion starting soon VW A4 Jetta TDI My other diesel is a Locomotive www.gscruiserparts.com |
#37 |
Haven't people who did this said it made no difference in terms of fuel consumption? I suppose it might reduce some wear on the front end.
__________________ 90 VX Ltd, HDJ81 RHD, 1HD-T 4.2l turbodiesel, auto, BFG 285-75-16 AT's, 3" lift, 15mm spacers all round, OME heavy / medium springs, triple locked, JDM tube frt bumper, 3" mandrel bent exhaust, aeroturbine muffler, Safari Snorkel. SOLD - to backroads backpacker... |
#38 |
I can't talk about consumption .. but centanly, les frond diff wear and are by far more faster .!
#39 |
I'm amazed that anyone would want to run an 80 series up to 180 kph. I didn't even know they could go that fast.
#40 | |
I'm happy driving my Cruiser at 120km/h no more .. this is great speed for a 4x4 2 ton rigs .. |
#41 | |
WOW!!!
Pretty Please
__________________ 91HDJ81VX (The Beast), 4B JDM, since Nov 06 83BJ60 (The Old Faithful), Still Running, Gone to a New Home 83BJ60 (Rusty but Trusty), Dec 90 - July 98, Parted Out 76FJ40 (Big Red), April 87 - July 93 |
#42 |
Been wondering about this - i know - search - as most of you are all really familiar with these trucks... who's changed over?
__________________ HDJ81 lifted winched exhausted snorkeled diesel smoker - with a cup holder mod. Glow away. For Sale: http://vancouver.en.craigslist.ca/cto/942095303.html |
#43 |
i've driven 1hz powered buses, they sit on 3000rpm at 100kph thanks to shitty gearing. at 110 it's about 3150 rpm. I've sat on that for hours on end, and the bus weighs abotu 3.5 tonne.
a 1hdt should do it easy. don't underestimate a toyota diesel's ability to rev. also i've heard of someone running two 1hdt's in a boat, at 3500rpm (where max power is) |
#44 | |
max speed 177 KM/H for me. Measured with a GPS. 37' Good Year MT's 4:11 gears. 7' lift. Kind of scary .... ![]() Land Crusher80 __________________ 2003 Gary Fisher Sugar 4+
2003 Yamaha WR250F 1988 BJ74V Locked 13BT SOA sold 1991 HDJ81 Factory Locked 1HD-T sold 1992 HDJ81 1HD-T sold 1994 HDJ81 Factory Locked 1HD-T rolled parts for sale 1992 HDJ81 1HD-T not locked yet 1994 HDJ81V Factory Locked 1HD-T VX Limited Diesel Turbo |
#45 | |
Thanks for your input! Chris __________________ 91HDJ81VX (The Beast), 4B JDM, since Nov 06 83BJ60 (The Old Faithful), Still Running, Gone to a New Home 83BJ60 (Rusty but Trusty), Dec 90 - July 98, Parted Out 76FJ40 (Big Red), April 87 - July 93 |
#46 | |
Cheers, Land Crusher 80 __________________ 2003 Gary Fisher Sugar 4+
Buy PSP | Web Advertising | Loans | Ford Cars | Refinance |
