11-09-07, 06:36 PM
#1 | | 250+ Club
| Trailer license plate location - legal question I recently modified a used/cheap boat trailer and made it into a steel flatbed utility trailer to haul my ATV around. I mounted the license plate onto the back of the right rear fender in existing holes where it was obvious a license plate had been mounted before. There was even a hole drilled on that side for the wire to come through for the light.
My dad, a retired Texas law enforcement officer, says that I mounted it on the wrong side of the trailer. He is the type that is quick to point out anything that I have done wrong, which is probably a good thing.
The light kit that I bought for the trailer has a clear lens at the bottom of the left taillight (for a license plate light), and the right side does not.
I googled for a while and could not find any law/regulation that says the license plate must be on the left side of the trailer. Someone on this site must have some expertise in this area.
Could it be that different States have different regulations regarding this topic, and this trailer could have come from some other State?
Or, did I screw up yet again? |
11-09-07, 06:54 PM
#2 | | 250+ Club
| My opinion carries no weight at all, but I have owned multiple trailers and currently have 5. NO experience with any trailer except a Texas trailers.
I have never seen a plate on the right. Always on the left. I have even mounted one on the left fender sideways on one of my farm trailers and had no problems with LEOs.
Probably has something to do with the officer being able to see the plate easily while behind you as he is on the left side of his vehicle and would have to pull his vehicle to the shoulder in order to see your plate on the right.
Edit: my boat trailer plate is on the left
__________________ '75 FJ-40-In pieces on my garage floor. -Buildup thread here
'76 FJ-40
'72 FJ-40
2002 F-250 Super Duty with 7.3 Powerstroke Politicians and diapers need to be changed frequently for the same reason Quote:
Originally Posted by Atticus Don't mess with Texas. | Quote:
Originally Posted by LAMBCRUSHER .  stupid is as stupid does | |
11-09-07, 07:09 PM
#3 | | I still have 20 demerits.
| Ask Diesel Dog here on the board. He is an LEO in Texas and will give you the answer. It is state to state. Some require none, some require light etc.
__________________ Hugh Heifer |
11-09-07, 09:50 PM
#4 | | Parts Geek, M1 Mechanic
| My boat trailer plate is on the left also.
__________________ Original owner 93 FZJ80,locked,blown,water/methanol injected(like a WWII fighter aircraft),lifted,winched,snorkeled,slidered,Sleeed ,moneypit. Balanced on a pin head. 95 FZJ80 trail truck (hers), 94 FZJ80 320K with a knock. 2009 Dodge Challenger SRT8, 465 horse HEMI, 6 speed manual trans, cop-attracting-red. Kimberly Kamper and some Garands. |
11-09-07, 10:41 PM
#5 | | She idles just fine!
| Quote:
Originally Posted by Rhinoliner I recently modified a used/cheap boat trailer and made it into a steel flatbed utility trailer to haul my ATV around. I mounted the license plate onto the back of the right rear fender in existing holes where it was obvious a license plate had been mounted before. There was even a hole drilled on that side for the wire to come through for the light.
Or, did I screw up yet again? | It's supposed to be mounted on the left-hand side for the practical reason that the law requires that the trailer plate must be lighted and clearly legible at a distance of 50 feet from the rear. If you've got it mounted on the right-rear fender of the trailer, there's a very good chance that from 50 feet back, an officer seated in a left-hand drive patrol unit will NOT be able to read all the characters of the trailer plate. Refer generally to Texas Transportation Code Section 547.322(f).
__________________ Sparkplugs are Irrelevant, mostly. 1986 BJ74; 1987 BJ75; 1988 BJ73; 1993 KZJ70; 1999 FZJ105; 1991 D250 "Fleet Oiler" Quote:
Originally Posted by rrdogma I do pay attention. You just don't make any sense.  | In Search of More Gubs . . . |
11-10-07, 05:09 AM
#6 | | 250+ Club
| Thanks for the info guys!
So, it sounds like I might be OK with where it is mounted because a LEO could easily read the plate from his drivers seat even if his front bumper was touching the back of the trailer and the trailer was fully loaded.
I guess I'll take my chances. |
11-10-07, 09:15 AM
#7 | | problems solved daily...
| ...so...it's a Texas thang...yes?
__________________ a couple pairs of pink panties... Another convert to the Church of Latter Day Swank, a sub-cult of Shahrislam "...Opportunity doesn't knock, you have to kick the fuckin door in and drag the bitch out screamin." -- Ullr "I have more respect for people who change their views after acquiring new information than for those who cling to views they held thirty years ago. The world changes. Ideologues and zealots don't." - Michael Crichton |
11-10-07, 09:46 AM
#8 | | Addict
| Quote:
Originally Posted by NorCalDoug ...so...it's a Texas thang...yes? | Maybe... It varies state by state. Go check out the California Vehicle Code to see if the have something similar.
Have fun! http://www.dmv.ca.gov/pubs/vctop/vc/vc.htm
__________________ '97 LandCruiser (Slee bits with OME418 and SOF4RH springs; Slee step sliders; African Outback full length roof rack; ARB front bumper, Hella 4000s; Kaymar rear bumper, tire carrier, jerry can carrier; BFG AT 315/75/16 on OEM steelies)
'09 WRX STi |
11-10-07, 09:48 AM
#9 | | Addict
| Quote:
Originally Posted by dieseldog Refer generally to Texas Transportation Code Section 547.322(f).  | Here's the actual code to generally refer to. Quote: |
Originally Posted by Texas Transportation Code 547.322 § 547.322. TAILLAMPS REQUIRED. (a) Except as provided by
Subsection (b), a motor vehicle, trailer, semitrailer, pole
trailer, or vehicle that is towed at the end of a combination of
vehicles shall be equipped with at least two taillamps.
(b) A passenger car or truck that was manufactured or
assembled before the model year 1960 shall be equipped with at least
one taillamp.
(c) Taillamps shall be mounted on the rear of the vehicle:
(1) at a height from 15 to 72 inches; and
(2) at the same level and spaced as widely apart as
practicable if a vehicle is equipped with more than one lamp.
(d) A taillamp shall emit a red light plainly visible at a
distance of 1,000 feet from the rear of the vehicle.
(e) If vehicles are traveling in combination, only the
taillamps on the rearmost vehicle are required to emit a light for
the distance specified in Subsection (d).
(f) A taillamp or a separate lamp shall be constructed and
mounted to emit a white light that:
(1) illuminates the rear license plate; and
(2) makes the plate clearly legible at a distance of 50
feet from the rear.
(g) A taillamp, including a separate lamp used to illuminate
a rear license plate, must emit a light when a headlamp or auxiliary
driving lamp is lighted. |
'09 WRX STi |
11-10-07, 05:30 PM
#10 | | She idles just fine!
| Quote:
Originally Posted by NorCalDoug ...so...it's a Texas thang...yes? | I don't know what other states require, Doug; however, there's a good reason why all trailer manufacturers and trailer light manufacturers have their equipment set up to the license on the left-hand side.
