05-31-07, 01:57 PM
#31 (permalink)
Originally Posted by LEXUSBEN
I did it quite similar to his except I used nut zerts for the hinge screws instead of just going into the case. I ended up using the old hinge screws and put some washers under them for strength, they also don't look too bad, I'd rather have the strength personally.
Attachment 83197
Are the nut zerts easy to install, special tools needed? Do you need to dismantle the casing to get those in?
Another cleanly done mod.
2000 4Runner Sport Edition PP 1" Lift Coils / 32" Tires / Norcold / RTT / ARB coming soon!
SOLD! 97' FZJ80 "Junior" Black/ARB winch bar/OEM Lockers
05-31-07, 08:22 PM
#32 (permalink)
You don't have to dismantle anything. Just be careful drilling the holes. It's mostly insulation behind the metal.
You do need a special to install the nutzerts. You can probably get one from mcmaster for pretty cheap though.
I think about this mod about every other time I open my fridge and I really like it when I have the baby in one hand and can get something without the lid falling off and the lid stays open
good luck
98 UZJ 100, 175K, "Mall Rated"
66 FJ40 "Basket Case"
05-31-07, 08:35 PM
#33 (permalink)
Supporting Vendor
Great to hear it is still working. I on the other hand never think about this mod, that is just the way I like it
On a side/update note, hinge setup is working great and I have since had to dismantle the entire fridge (leaky condenser, all fixed, great customer service) Even if you slip disastrously and drill right through the fridge, you wont hurt anything.
The body is just foam insulation all the way to the inner plastic of the cooler, then there is the 1/4" gap, then the metal cooling tube surround. To damage the fridge you would somehow have to drill through the outer skin, through the foam, through the inner plastic skin, past the gap and into the metal cooling tube housing, and even then you would have to be lucky enough to actually hit one of the few coolant tubes.
if that makes you feel any better.
Happy drilling
05-13-08, 04:29 PM
#34 (permalink)
I am going to do this to my ARB freezer, anything you'd do different now that you've had it modded for a while?
Thanks, I can't stand my fridge lid (love the fridge  ) and I have to do something about it!
Drew F.
Rising Sun 4x4 Club
05-13-08, 07:20 PM
#35 (permalink)
Supporting Vendor
Still love it enough to try and make it easier on other folks!
05-13-08, 07:31 PM
#36 (permalink)
Nice kit bud. Thanks!
Drew F.
Rising Sun 4x4 Club
05-19-08, 09:52 PM
#37 (permalink)
still solving problems...
Originally Posted by kevinmrowland
I need a couple latches... do you have a good source for them? they're for a 60 qt norcold that's currently latchless...
do you have a good source? would you be willing to share your source or sell just a couple latches?
a couple pairs of pink panties...
Another convert to the Church of Latter Day Swank, a sub-cult of Shahrislam
"...Opportunity doesn't knock, you have to kick the fuckin door in and drag the bitch out screamin." -- Ullr
"I have more respect for people who change their views after acquiring new information than for those who cling to views they held thirty years ago. The world changes. Ideologues and zealots don't." - Michael Crichton
05-20-08, 12:34 AM
#38 (permalink)
Originally Posted by NorCalDoug
I need a couple latches... do you have a good source for them? ...
Check McMaster-Carr. They seem to have a few choices.
97 FZJ80, Milford Cargo Barrier, Slee Sliders, ARB rack, ARB bumper, 285 Revos
05-20-08, 07:39 AM
#39 (permalink)
Supporting Vendor
Yup, Mcmaster-Carr.
I also posted the source info and part numbers back on the first page. The stuff in the kit is a bit different to make it easier, and I have made a template for hole layout, but all the info is there in case anyone wants to put their own stuff together.
05-20-08, 09:58 AM
#40 (permalink)
Will be ordering a kit from you later Kevin.
Thanks for gathering up the parts.
05-20-08, 09:05 PM
#41 (permalink)
Supporting Vendor
Cool, they're here if you want one.
05-21-08, 04:08 PM
#42 (permalink)
Supporting Vendor
Nice kit Kevin, I'll have to keep that in mind when customers ask.
05-31-08, 06:29 AM
#43 (permalink)
Anyone do this to an Engel? I don't see why you couldn't although the lip profile looks to be different.
'97 FZJ80 - 2.5 lift, OME heavies, ARB front, Warn 9.5XP, Slee rear, Slee sliders, dual batteries & Engel
You're a bottle-cap away from pushing me too far
06-02-08, 11:58 AM
#44 (permalink)
Kevin, I just moved my fridge from the rear where it was to the rear left seat area.
I can raise the lid up much higher now and see what is inside, but the lid still hits the ceiling.
When it was on the cargobox though, I could not see inside at all, and I could not raise it up very much.
http://forum.ih8mud.com/fj-cruiser/1...ml#post3362802
Fridge is much easier to get to now though.
With the addition of your kit you put together, I should be able to raise the lid all the way up now.
I will have to test it by taking the lid off and flipping it up from the side as if the new hinges were in place.
Old location
New location
06-02-08, 05:44 PM
#45 (permalink)
Supporting Vendor
The hard parts should be the same between the two, and the part/construction diagrams between the two are the same. There wont be anything in the way as long as the hinge fits over the Engel edge trim.
Yup, that is exactly the kind of situation that got me thinking along these lines, flipping the way your lid hinges will make fridge access much better, and the good thing is that this is a reversible mod if you find you want to change it in the future, just save the old hardware.
06-03-08, 05:32 PM
#46 (permalink)
Supporting Vendor
Just got word from a "genuine" Engel install that the fit is the same as with the ARB.
06-14-08, 02:15 PM
#47 (permalink)
Rookie
and here it is
Okays its not a cruiser, but the concept is the same
The full story here LoadBay V2
Andy
06-15-08, 08:25 AM
#48 (permalink)
Supporting Vendor
That looks great Andy!
Same situation I was in, much more space with it tucked into the corner.
I'm wondering if Engel is gona catch on and start making the new ones hinge like this.
06-15-08, 12:46 PM
#49 (permalink)
Supporting Vendor
Haha!
Looky what I found today.
(photo courtesy of expeditionexchange.com)
06-18-08, 12:06 AM
#50 (permalink)
Supporting Vendor
Haha!
Yup, the new Engel MR040 opens from the side.
09-19-08, 07:49 AM
#51 (permalink)
Kevin, just placed my order for the kit.
Thanks for putting the kit together.
09-25-08, 06:57 PM
#52 (permalink)
12-11-08, 05:44 PM
#53 (permalink)
Great Mod, I'm buying the kit for my Engel, thanks.
Mike
TLCA Member : #18084
"Good people sleep peacefully at night safe in the knowledge that rough men stand ready to do violence on their behalf" - (George Orwell)
"It’s Not An Assault Rifle, It’s a Jihadi Paradise Attainment Facilitator"
12-11-08, 06:31 PM
#54 (permalink)
Not to skew this thread, but am I the only one that thinks ARB logo's things so extensively that they should pay us to use their equipment
Originally Posted by Brian in Oregon
"As an American I am not so shocked that Obama was given the Nobel Peace Prize without any accomplishments to his name, but that America gave him the White House based on the same credentials." - - Newt Gingrich
07 FJC Voodoo Blue - 3" Sway Away - 33" Toyo M/Ts - Custom Skids by Knoll - On Board Air - AllPro Front Bumper/Light Bar - ARB Full Length Roof Rack - Warn M8000/Wireless Remote
Wheel it or Park It!!
Jefferson State Cruisers
12-14-08, 12:30 AM
#55 (permalink)
Good idea ! I have a engal similar to the ARB, will look into undertaking this mod. Thanks
Cheers
Shane
LC 200 4.5 TTD
12-15-08, 08:36 AM
#56 (permalink)
can you still pull out the wire basket? Asking if the hinges go up to full open to pull the basket out?
Erik FJ45, FJ62 TLCA #5303
I'm nervous, my hands are sweating, Legs shaking, totally having a blast !
12-15-08, 08:43 AM
#57 (permalink)
Supporting Vendor
Yup, if you have the room to swing the lid, it will flip all the way open.
With the fridge sitting on the floor of my cruiser I used to have to remove the lid to get the basket out. With the new hinge location I can open the lid far enough to pull the basket without moving anything, much better.
12-16-08, 02:57 AM
#58 (permalink)
12-25-08, 03:50 PM
#59 (permalink)
Charismatic Megafauna
Thanks for the link, looks like those will work with the Engle MR040 that does not come with a basket.
2008 Tacoma Dbl Cab 4x4 Long Bed SR5, 265/75R16 Bridgestone APT, Leer Shell.
*sold* /cry....... 1993 FZJ80, 160k, ARB Bullbar, OME J's, Slee Castor Plates, 285/75R16 BFG AT/KO's, HIR's, Slee Headlight Harness, Belli Horns.
1996 Triumph Tiger
"Nature is not more complex than we thought, it's more complex than we can think"
12-26-08, 07:26 AM
#60 (permalink)
any of you think of not using screws ? someof the same hinges with a good epoxy would probly do just as well and no potential fatal to the fridge screw holes either
