Go Back   IH8MUD.com > General Tech Forums > Camping and Outdoor Gear
Old 04-21-08, 07:44 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
jditom's Avatar
Triple bars for a RTT, level?
Getting ready to install a Columbus variant RTT (medium) with 3 Yakima bars. When I put a level on all 3 bars they do not sit even. The front will be lower than the rear and middle.
Is this going to be a problem or should I assume that the Columbus has some flex?
Thanks All
Pics as soon as I install it.
1996 TLC, Cooper D. STT 305/70/16, CDL, 7 PIN, OME steer & 850/863, Bilstein HD, IPA fog. Slee's front bumper, skid plate, CC bushings, SS brake lines x 7, light/aux harness & speedo gear. Warn XD 9000, Hanna sliders. 4X4labs rear bumper. OEM sub tank & overhead console. Projection headlamps, clear lenses, rear tail LED, George's inside LED's. MagnFlow exhaust (cat back). Eclipse Nav.
2005 GX470, KDSS, Revo's, running boards off!
jditom is offline   Reply With Quote
Old 04-22-08, 07:45 AM   #2 (permalink)
no bueno
Skillet's Avatar
TLCA# 16078
Park at a different angle.
Seriously, I would not imagine that it would be such a difference that the tent could not handle it.
How far off is it?
1993 FZJ80
1973 FJ40
oh no you didn't...
Skillet is online now   Reply With Quote
Old 04-22-08, 09:56 AM   #3 (permalink)
jditom's Avatar
How far off is it?
Having the rig on different angles does not change the level of the roof rack.
On the driver side it is minimal at about 1/4 inch. on the passenger side it is about 3/4 inch. This is with putting a level across the 3 bars, the passenger side middle bar sits higher than the 2 ends. I have moved them all around but it's still not level.
I will put the RTT on tonight to see if it will clamp down. If not I may have to go with 2 bars.
Old 04-22-08, 11:34 AM   #4 (permalink)
cstamm81's Avatar
I mounted a Maggiolina on my 80 series w/ three bars, square tube home made jobbies. I had to space the rear most bar between the bar and rain gutter clamp in order to have the tent sit on all three bars. I think I used old thick shock mount washers I had lying around.
94 LC, 110K, FOR 3" lift, Nitto TG 315's
88 Mini truck, SAS'ed
86 LC, 150K, OME Medium, ARB front, custom rear bumper, Warn 8274, BFG 33" Muds - back to shmukster
And a silly little VW TDI Jetta Wagon that does 50mpg
cstamm81 is offline   Reply With Quote
Old 04-22-08, 04:45 PM   #5 (permalink)
jditom's Avatar
That is a nice idea. I have extra mounting plates that I could use as a space to offset the level.
If it's not hailing tonight I will mount
Old 04-22-08, 06:30 PM   #6 (permalink)
IH8MUD Lifer - No Appeal
Mike S's Avatar
The tent will flex a little - but you do not want to mount it that way. What type of Yakima towers are you using gutter mount of rail riders?
I have had several different tents on my 1996 FZJ80 - using three Thule gutter mount tower (300's) and stadard thule cross bars. Level and no bending of the tent platform.
If you need to, you can shim between tent and the cross bar right where the clamp is located. You do not need to shim all the way across the bar. The bottom is plenty strong. You can use an extra mounting plate or a piece of rubber or nylon. Anything that is tough and not abrasive.
Mike S
'96 FZJ80, locked, Hanna sliders, ARB bumper, Kaymar rear with spare carrier, 45 gallon Longranger aux fuel tank, OBA, Hella 4000's, OME lift, 285/75/R16 Revos & AutoHome Maggiolina rooftop tent, etc.
Custom Cruiser trailer with OverLand tent
www.AutoHomeUS.com
TLCA Member #14874
Mike S is offline   Reply With Quote
Old 04-23-08, 06:30 AM   #7 (permalink)
no bueno
Skillet's Avatar
TLCA# 16078
Just so you know...I was kidding. Hence the "".
Sheesh, mr. serious.
1993 FZJ80
1973 FJ40
oh no you didn't...
Old 04-23-08, 09:22 AM   #8 (permalink)
jditom's Avatar
Damn I need to get by head out
Thanks man
Old 04-24-08, 10:33 AM   #9 (permalink)
REZARF's Avatar
TLCA# 13041
If you are using the 1A towers from Yakima, you can "shim" the mount by installing a shim material, aluminum or hard plastic between the tower and the top silver mounting hole. It will require a longer bolt (longer by the thickness of the material used for the spacer) then you could customize the level without much issue.
Think the top of the clamp and the bottom as two pieces you could adjust the height by adding a spacer between the two with a longer bolt. 1/4" would be easy!
Drew
Drew F.
Rising Sun 4x4 Club
Old 04-24-08, 10:38 PM   #10 (permalink)
jditom's Avatar
Had to shim one corner but the rest went fine.
Here are some pics as promised
As you can see having a rear bumper with a ladder is great for the rear entry Columbus!
Old 04-25-08, 07:13 AM   #11 (permalink)
no bueno
Skillet's Avatar
TLCA# 16078
Looks very nice. Good job.
Your bumper is one of Luke's and you can actually re-drill the mounting holes for the ladder to slide it more in line with the tent entrance.
Just an idea.
1993 FZJ80
1973 FJ40
oh no you didn't...
Old 04-25-08, 08:16 AM   #12 (permalink)
Corey's Avatar
Looks great!
Your tent looks just like mine when in the down position.
I like the ladder too, no need to use the included one since that works from the rear.
Corey
'07 FJ Cruiser
ARB bumper, Warn XD9000, to much to list, see my website
My Forum - My Website - My Rigs Build-up - Roof Top Tent - My Penthouse Video - Maggiolinas In Their Natural Habitat
Corey is offline   Reply With Quote
Old 04-25-08, 08:21 AM   #13 (permalink)
jditom's Avatar
Just an idea.
Excellent idea!
Old 04-25-08, 03:48 PM   #14 (permalink)
REZARF's Avatar
TLCA# 13041
Killer! Looks awesome man, gotta love the RTT!
Drew F.
Rising Sun 4x4 Club
LinkBack to this Thread: http://forum.ih8mud.com/camping-outdoor-gear/217504-triple-bars-rtt-level.html
Posted By For Type Date
Volkswagen Jetta 2003 Tail Lights, Sparto Tail Lights, Where Can I Find Custom Tail Lights For Cars - Arawakindians This thread Refback 03-09-09 02:39 AM
New Wheelin Rig - YotaTech Forums This thread Refback 08-25-08 11:58 AM
