Home Forum Gallery CruiserFAQ Tech Links Merchandise
IH8MUD Forum
Go Back   IH8MUD Forum > General Tech Forums > Camping and Outdoor Gear
Join IH8MUD on Google+   Follow IH8MUD on Twitter   Visit IH8MUD on Facebook
Camping and Outdoor Gear Camping supplies, clothing choices, survival gear - headlamps to coolers to hiking boots
Thread Tools Display Modes
Old 04-25-04, 08:37 PM   #1
beanz2
Addict
beanz2's Avatar
Plumbing garage for compressed air
I'm thinking of plumbing the garage in a new house for compressed air. I'll have a 220V compressor mounted in a closet in the corner and I'm thinking of running copper air lines within the walls (under sheetrock) except where it has to run along one side which is actually a retaining wall. The lines will run to 2 ceiling- or wall-mounted hose retractors, on each side of the garage. I'd like some suggestions on the air line design please:
1. Is 1/2" copper lines what I want, or do I need larger diameter or smaller?
2. Do I need any drains along the lines for moisture? Thinking I will have a filter/separator on the compressor before it connects to the copper air lines.
3. The compressor will likely be floor mounted (80 gal). Is there need to keep a flexible line between the compressor and the rest of the plumbing? I'm guessing yes, but do I run a short rubber line or what?
4. Is it better not to mount the lines under sheetrock? IOW, do the lines ever need maintenance? Likely I will have a professional plumber install it since it is a new home construction.
5. Are 2 hose retractors enough? In the picture I attached, the red X's mark where they are to be mounted. Should I install more air outlets?
6. There will be a long extension of the lines to a carport off the hallway to the left upper corner (not in the pic) for a beadblaster, etc. Should the line be installed at a slight slope to allow whatever moisture, oil, etc. that got past the filter/separator to run downhill and drain at the other end?
One thing I'm bummed about is that the garage ceiling is only 11 ft tall, and to lift it higher it messes up the rest of the house a bit (e.g. the living room above it will be much higher than the rest of the house). I guess I can live without a 2 post lift
Your comments are welcome,
Dave
edited to make picture smaller
beanz2 is offline   Reply With Quote
Old 04-25-04, 08:43 PM   #2
beanz2
Addict
beanz2's Avatar
I guess I have to post the pic separately.
Sponsor 04-25-04, 09:20 PM
Sponsored Link
advertisement
Old 04-25-04, 09:20 PM   #3
tewlman
tewlman's Avatar
Re:Plumbing garage for compressed air
the copper should work fine, make sure you put some inline drains in. imo put 4 outlets in, one in each corner. and unless you plan on using it a whole lot, why both putting it in a closet, could save a few$$$
tewlman is offline   Reply With Quote
Old 04-25-04, 10:23 PM   #4
beanz2
Addict
beanz2's Avatar
Should the lines be sloped a bit toward the drain points? The compressor will be used a whole lot, just trying to isolate it for noise reasons.
Dave
Old 04-26-04, 10:44 AM   #5
Junk
Lifer
Junk's Avatar
Don't most folks use black pipe for this? I was going to plumb mine out with pipe, but decided to just connect up a bunch of rubber hose instead. Can always just cut it and add in new if needed. - it's just cheap and easy.
Drain points are a good idea, but I would keep all of this external to the wall.
Definitely put in some flex line between the comp and the hard lines.
If you are running this inside the walls, then I'd recommend you use a cooler if you're going to be using it a lot.
There are some home made coolers with drains that are made out of copper pipe.
Here's a few
Junk is offline   Reply With Quote
Old 04-26-04, 11:24 AM   #6
Brentbba
Former Golfer
Brentbba's Avatar
Father-in-law has his entire workshop and carport area plumbed to an air compressor. He just used Sch 40 PVC. It's an indoor and outdoor application in NoCal. Easy and cheaper than copper.
Brentbba is offline   Reply With Quote
Old 04-26-04, 11:37 AM   #7
beanz2
Addict
beanz2's Avatar
Thanks for the replies, guys. Keep them coming. Junk, the pic for the cooler did not show, could you repost it? Just how hot does a compressed air line run? Hotter than, say, hot water plumbing?
Brent, any idea how much pressure Sch40 PVC can take? I will be running up to 120 psi in the lines. Just thinking of the glued-on elbows and ends.
Dave
Old 04-26-04, 11:55 AM   #8
The Dude
Addict
The Dude's Avatar
I just did this (external on the walls though) and used 1" copper pipe. I used two ball valves, one on the drain and one into the air fitting. This way I can turn off the air if I need to replace anything.
I find the bigger the pipe the better, same goes for soft lines. I run 3/4 to everything.
The Dude is offline   Reply With Quote
Old 04-26-04, 12:06 PM   #9
Brentbba
Former Golfer
Brentbba's Avatar
Don't remember offhand what sch 40 can handle. It's printed on the side of it at any home imp. store. If I had to guess from memory, it's either 120 or 200 psi.
Old 04-26-04, 12:18 PM   #10
VTCruiser
Lifer
VTCruiser's Avatar
Garage
beanz, what size compressor ya got? just curious as to what people are running in home shops...
VTCruiser is offline   Reply With Quote
Old 04-26-04, 12:38 PM   #11
haystax
Addict
haystax's Avatar
Check out some autobody sites for suggestions, just about anything will work for running air tools but since you are going at this while building the house, it would be better to not have to go back later. I think that the copper is a good idea, should help with condensation issues. Overhead hose-reels are really handy, one installed in the center of the ceiling would reach everywhere, this would slope your lines towards to tank and help with moisture issues as well.
haystax is offline   Reply With Quote
Old 04-26-04, 02:35 PM   #12
TLCObsession
Don't use PVC for air - it can explode and turn to shrapnel. There is a PVC like material specifically made for airlines, but it is spendy. Copper is your best bet.
Jim
TLCObsession is offline   Reply With Quote
Old 04-26-04, 04:13 PM   #13
beanz2
Addict
beanz2's Avatar
OK, I'll see about using copper then. If it doesn't add too much to the price I'll see about using the 1" lines. The ball valve suggestion is a good one. Does everybody think a regular plumber is knowledgeable enough about compressed air lines? A heck lot more than I know for sure
Gehn, I'm going to get an 80 gal. compressor, or a 120 gal. if I can afford it. I love to beadblast parts and my current 30 gal. just runs out of air after 5 minutes or so.
You guys are #1.
Dave
Old 04-26-04, 07:26 PM   #14
scottm
Addict
scottm's Avatar
I've done some pipefitting, never seen copper used for this, just black or galvanized steel pipe. Most hardware stores sell a small hardware reference book with tons of usefull references and formulas for a couple bucks, everyone should have one. It has formulas for pipe size for different lengths and capacities of air line systems, as well as air requirements for various tools. How loud is your compressor under the living area above? You might want to plan some rubber isolators and sound deadening. The sand blaster sounds like your biggest draw, and it's the farthest from the compressor, that's unfortunate.
scottm is offline   Reply With Quote
Old 04-26-04, 08:17 PM   #15
beanz2
Addict
beanz2's Avatar
[quote author=Scott M. link=board=14;threadid=15339;start=msg145791#msg14 5791 date=1083032765]
[/quote]
I still have plenty of time to move it around. The plans is not yet submitted to the city. The space above the garage is the living room, if I put the compressor in the carport, it will be below the dining room, much closer to the family room. I figure on putting some insulation within the closet walls where the compressor is kept. Should I set it on some rubber padding too? The garage floor will be 4" of concrete.
Is distance from the compressor that a big disadvantage? When I use my current beadblaster, I have the pressure turned down to 80 psi anyway because that is what the beadblaster manufacturer recommends.
Dave
Old 04-27-04, 01:14 PM   #16
Junk
Lifer
Junk's Avatar
I'll post a few pics of what I'm referring to, but you'd be best served by reading Franz's posts in this thread.
http://www.hobartwelders.com/mboard/...ssor+air+drier
Old 04-27-04, 01:15 PM   #17
Junk
Lifer
Junk's Avatar
Old 04-27-04, 04:01 PM   #18
beanz2
Addict
beanz2's Avatar
[quote author=Junk link=board=14;threadid=15339;start=msg146231#msg14 6231 date=1083096893]
[/quote]
Looks like a good board I have to read when I get home. Thanks, Junk!
Dave
Old 04-27-04, 05:50 PM   #19
Junk
Lifer
Junk's Avatar
Yeah, I've learned a lot over there. Some great guys and same as here, for the most part, no such thing as a dumb question, just a dumb person asking a question , well, you know what I mean
Old 04-28-04, 06:09 PM
Sponsored Link
advertisement
Old 04-28-04, 06:09 PM   #20
scottm
Addict
scottm's Avatar
I was setting up a machine at a customers fairly new factory yesterday, and they had all copper air lines, miles of them. Amazing, since this was the company I used to work at putting in steel air lines many years ago. So I guess copper pipe is widely used for air lines after all.
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
vBulletin® ©2000 - 2013, Jelsoft Enterprises Ltd.
Garage Plus, Vendor Tools vBulletin Plugins by Drive Thru Online, Inc.
©2000-2013 - Tie Rod Media, LLC - ALL RIGHTS RESERVED
