03-20-07, 06:53 PM
| | Forum Regular
| MV50 Fuses Keep Blowing Has anyone else had problems the the MV50 (also called the M1050 I think) air compressor blowing fuses? I've heard of people running them on continuous duty for upwards of 30 mins, but I went through 2 fuses in less than 15 mins last weekend. Both blew after stopping the compressor to switch tires then trying to turn it back on. Is mine just defective? It's only been used to air up 4 tires 4 times :(.
__________________ '73 baby blue fj40 [sold :(], '96 FZJ80 locked, 285 BFG ATs, CDL w/7pin, custom drawers, SROR sliders, OME med, extra 12V power, IPOR skidplate , 1951 M100 w/RTT, 1994 Camry DD |
03-20-07, 08:57 PM
| | Site Addict
| No problems with mine.
Usually run it for about 15 minutes to air up. |
03-20-07, 09:00 PM
| | 250+ Club
| There was a post within the last year or so with someone that had to replace the relay in one. I don't know if your problem is related to this but maybe this will jog someones memory and can add more.
__________________ 94 FZJ80 134k Locked, ARB Front, OME heavy, Warn 12000, TJM Rear. 285 MTRs, LED's & rear cargo light.
85 FJ60 98k, ARB front, 3"lift, 32" BFG AT |
03-21-07, 10:41 AM
| | Forum Lifer
| I haven't had any issues, I also usually use for ~15 minutes at a time.
__________________ Ben Silva
IH8MUD Site Supporter since July 2004
1996 Lexus LX 450, 144k, locked, Cooper STT 285s, OME 850/863, Slee Blue CC bushings, CDL/Pin 7, LandTank MAF, Powerstop rotors/EBC Green pads/Slee SS brake lines, Slee headlight harness, HIR mod, DIY installed Viper Remote start/alarm system, Mot JDM passenger grab bar, 30qt freezer, 2@aux fuse blocks, aux powerpoint, 850w inverter, Raingler Barrier Net
1998 Lexus LX 470, 139k Sold
1993 FZJ80 198k miles Sold
My writeups: HOW TO: DIY Remote Start/Alarm/Keyless Entry John Deere HIR bulb mod HOW TO: Fix your leaky windshield |
03-21-07, 12:03 PM
| | You want to do what...?
| no problem with mine.
I did see somebody once who used a newish one without having taken the plastic wrapping off the vents, things did get kinda hot apparently.... don't recall anything said about popping the fuse though.
__________________  : '97: 90K, 3xlock, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!). Custom HD roo bar for sale!  : '03: 115K
DDs: Accord, Prius  : souped-up DR650 |
03-22-07, 06:47 PM
| | Site Addict
| A wheeling buddy of mine was using his at Tierra Del Sol a few weeks ago. I happened to glance over at it just in time for smoke to start billowing out of it. The wire had gotten loose just inside the case and was arcing, causing enough heat to melt the cable. You may consider checking this as well. If the power wire intermittently shorted, it would blow fuses.
__________________ Steve
'97 LX 450 with Slee 6", 35" Toyo's, Slee front, 4X4 Labs rear, Hanna sliders, 5.29's, front and rear chromoly axles and the two Dober's: Zeus and Zoey |
