ARB Fridge would be cooler if it opened like this.
Any body done this?
Seems like you could just screw hinges on one side and a latch on the other an be all set. It is essentially a traditional metal sided cooler. I am usually all for drilling holes and modifying stuff........but.................... this is an awfully expensive thing to drill holes in ![]() P.S. Thanks Kurt, fridge arrived just in the nick of time! |
grown up MOD
Glad I have the 60.I thought they all opened like dat...... ![]() __________________ "If it wasn't a Landcruiser and hadn't been built the way it was you do realize you would be DEAD." VA State Police Officer |
Hey,
Could any of you guys with the 60 post a detail shot of the hinge/latch? I am thinking that I could order the hinges and latch for the 60 and then be a little more secure in thinking that the holes would not interfere with anything. The more I think about it the more I want to do this, it would facilitate opening the fridge from the tailgate or the back seat, I could mount it closer to the side and not have to worry about having a slide out for it, therefore loosing less sleeping area.................. |
Hey Kevin, sorry for the delay, been out of town...
I'm honestly not sure if there are any reasons you couldn't add some side hinges... I too have had time I wish mine opened that way (when I have it in the back seat of my ExCab Tacoma. Do it and let us know ![]() ![]() ![]() PS, glad it made it in time , thanks again!__________________ Kurt Williams ***Cruiser Outfitters*** - YOUR LC PARTS SOURCE!!! Old Man Emu - ARB - Advance Adapters - Safari Snorkels U4WDA - Historian TLCA Wasatch Cruisers Mountain Yoats Red Rock 4 Wheelers Tacoma Territory kurt@cruiseroutfitters.com |
I agree, it's a good idea. I would like to add hinges to mine also.I have another bitch point; why don't the transit covers make room for the latching mechanism in these things? :-)
__________________ TLCA # 15941 KE5LED Currently working in Danville, PA until Aug. |
That's one of the reasons I went with the Waeco...
__________________ Modded '99 for on-trail exploring: 315's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, good music for ears, Waeco CF-50, PowerGate with 2nd battery, home brew tube type sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Fox 2"remotes at each corner, 12mm body lift... KE7NCM |
Cool, I'm doin it.
Found an exploded view on the internet that pretty much eased my fears. I have the hinges and the latch sitting on my bench so sometime this week I will post up how it goes. From the looks of things this will be a pretty easy mod, let you know how it goes. Alia, you must be referring to a different transit bag, mine does not seem to interfere with the latch at all. |
The ARB Transit bag should clear the latch just fine?
![]() __________________ Kurt Williams ***Cruiser Outfitters*** - YOUR LC PARTS SOURCE!!! Old Man Emu - ARB - Advance Adapters - Safari Snorkels U4WDA - Historian TLCA Wasatch Cruisers Mountain Yoats Red Rock 4 Wheelers Tacoma Territory kurt@cruiseroutfitters.com |
#10 |
PS, sorry for the huge pic...
#11 |
The Engel transit bag falls on its face in the latch area!
Just about all of the Engel transit bag has this area totally stretched out or just plain messed up!__________________ TLCA # 15941 KE5LED Currently working in Danville, PA until Aug. |
#13 |
Ok, my ARB fridge is now even cooler.
The hinges have a tension adjusting screw so the lid will stay in whatever position you put it and they have just enough room to fit over the welting. The latch is a spring compression one that holds the lid nice and snug. And I cut the transit bag around the new latch for clearance. I like it. Pics: |
#15 |
Very cool, how about a source for the parts?
__________________ Ben Silva IH8MUD Site Supporter since July 2004 1996 Lexus LX 450, 130k, locked, Cooper STT 285s, OME 850/863, CDL/Pin 7, 30qt freezer, 2@aux fuse blocks, aux powerpoint, 850w inverter 1998 Lexus LX 470, 139k Sold 1993 FZJ80 198k miles Sold |
#16 |
Very cool
![]() I assume you ran the bolts all the way through the side of the freezer and used a nut on the inside? Did you re-sew the cover? Looks OE ![]() __________________ Kurt Williams ***Cruiser Outfitters*** - YOUR LC PARTS SOURCE!!! Old Man Emu - ARB - Advance Adapters - Safari Snorkels U4WDA - Historian TLCA Wasatch Cruisers Mountain Yoats Red Rock 4 Wheelers Tacoma Territory kurt@cruiseroutfitters.com |
#17 |
How did I get here?
I would have thought you would make it open the other way and put the compressor forward, so you don't have to reach around it.....or do you need access to that end?
__________________ If you're not part of the solution, you're part of the precipitate. '99 UZJ100 "The Iron Hippo" / '82 FJ40 "Mustard" / '73 FJ40 |
#18 |
Thanks, glad you guys like it.
Mc-Master-Carr Parts Friction Hinge 1791A48 Draw Latch 1794A43 6-32 X 1/4” self tapping screws 98273A155 12-24 x 1/2” self tapping screws 93380A400 Kurt, I decided to just use self tapping metal screws (not self drilling). If they don’t work I will dismantle the fridge and put nuts back there. They seem to hold very tight and I think they will work quite well. I cut the bag and sewed binding on like the other latch opening has. I am not thrilled with the way that turned out, it’s a real bitch to stuff that bag through the sewing machine. But, it looks good from a distance. Yooper, I thought it would be better hinged the other way as well. However, if you look at the way the D pillar angles in you can see that there is not enough room for the lid to open unless it is where it is. As it sits, the lid opens right into the window and clears everything perfectly. It’s a bit further of a reach, but it fits best that way and makes it a bit easier to get at from the back seat. Also, it keeps things from getting stuffed against the cooling fins like would happen if they faced the other way. Everything is a compromise I guess. Amy likes it, so that's all that matters. A close up from the same pic: |
#19 | |
How did I get here?
![]() __________________ If you're not part of the solution, you're part of the precipitate. '99 UZJ100 "The Iron Hippo" / '82 FJ40 "Mustard" / '73 FJ40 |
#23 | |
he said "reach around" __________________ Endeavor to Persevere |
#24 |
Nice work!
__________________ Tad A. 99 LX470 - Slee Sliders & 34" Swampers | 04 Taco DubCab 4x4 TRD | 82 Porsche 911 Upstate Cruisers T-Shirts and Gear Here |
#25 |
I just had a thought...would those hinges have enough power to keep the lid open as the cooler comes from OEM? Just curious!
