Go Back   IH8MUD™ Forums > General Tech Forums > Camping - Gear - Recovery
Old 11-14-05, 08:13 PM   #1
northerner
semlin's Avatar
trail tools/repair kit
there is no ideal trail tool/repair kit, but as I struggle to keep it in two tool boxes and three rubber maids, here is mine. I'm looking for suggestions on what I'm missing or what I don't need.
wrenches
8, 10, 12, 14, 17 and 19mm open ended wrenches in stubby and regular (12 pces)
10/12/14/17mm box wrenches
monkey wrench that opens to 32mm
robogrip or similar open mouth wrench that opens to 32 mm
pliers
large/small/open mouth (pipe) vice grips
regular pliers
needlenose
cutters
snap ring
sockets
8, 10, 12 mm 1/4 inch drive sockets short and deep ( 6 pces)
10, 12, 14, 17, 19mm 3/8" inch drive sockets short and deep (10 pces)
14, 17, 19mmm ½"m drive short and deep (6 pces)
21mm deep ½" socket (1 pce)
54mm hub socket (1 pce)
½" 18-24" breaker bar
1/4, 3/8 and ½ ratchets and a 3/8" wobble ratchet
3" and 6" 1/4 and 3/8" extensions
6" ½" extension
½" torque wrench
½" to 3/8" socket adaptor
screwdrivers
4 flatheads in various sizes up to the big 18" model
3 phillips up to the 12" model
1 variable bit driver with a bit set and a long nose
metric allen key set
Heavy Crap
brass mallet
brass drift
claw framing hammer
impact driver and bits
Esoteric
easy outs
hacksaw w/ extra blades
magnet retrieval tool
tie rod end puller
pickle fork
propane torch attachment & sparker
Electrical
cordless drill w/extra battery
maglight w/extra batteries
cobalt drill bit set up to ½"
multimeter
stripper/crimper tool
replacement fuses
10/12/14 gauge wire
10/12/14/16 butt connectors
12/14 spade connectors
dieletric grease
general materials
gasket paper
white lithium grease
shop towels and rags
4 litres engine oil
4 litres premixed coolant/h20
brake fluid
1 litre gear oil
tube of axle grease
1 litre ATF
cutting fluid
penetrating oil/wd40
small propane bottle
blue silicone RTV
bailing wire
duct tape
Parts
birfield
one birf kit from inner axle out
plugs/plug lead set/rotor/cap
one set wheel bearings
a few random nuts and bolts
and.. the FSM
93 fzj80
66 fj40L
m101cdn trailer
91 LS400 sedancruiser
"Diplomacy is the art of having someone else impose your will on you" Lester Pearson
"I have the conch" Piggy
semlin is offline   Reply With Quote
Old 11-14-05, 09:31 PM   #2
I Solve Problems...
NorCalDoug's Avatar
TLCA# yes, I have one
you should include one of those handy tire plug kits.
Cruiserdrew carries one with him -- he's helped me out in the past.
I'll be getting one for myself shortly.
a couple pairs of pink panties...
Another convert to the Church of Latter Day Swank, a sub-cult of Shahrislam
"...Opportunity doesn't knock, you have to kick the fuckin door in and drag the bitch out screamin." -- Ullr
"I have more respect for people who change their views after acquiring new information than for those who cling to views they held thirty years ago. The world changes. Ideologues and zealots don't." - Michael Crichton
Buy TEQ Bottle Openers
NorCalDoug is offline   Reply With Quote
Old 11-14-05, 10:00 PM   #3
IH8MUD No-Lifer
hoser's Avatar
JB Weld?
98 LX470
85 BJ70
hoser is offline   Reply With Quote
Old 11-14-05, 10:40 PM   #4
The quick brown fox .....
Beowulf's Avatar
Throw in an assortment of turnbuckles to go along with that bailing wire. A buddy had an aluminum A/C bracket break on his FJ40. Repair/replacement was not an option as we were deep in the mountains of Colorado and a long way from home. Everyone pondered the problem for a while and they came up with an ingenious fix that not only got him through the remainder of the outing but he drove all the way back to NM with the A/C on.
An assortment of SS hose clamps and various sized hoses. On another trip, the same guy had a leaf spring problem. We fabricated a bushing using some heater hose and someone had a bolt that fit. Finished the day with no problem.
JBWeld "Quick" if it is for a trail repair that can be redone.
I didn't see a diff plug socket (26mm I think.) I'm using 10mm hex head plugs.
3M electrical tape.
-B-
97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress...
Old 11-14-05, 10:45 PM   #5
northerner
semlin's Avatar
ahh thanks b-wulf I was wondering why I had an extra 24 mm socket in my main tool kit. the diff is why.
I will definitely add my hose clamp tupperware container (need to buy a couple of bigger clamps) and some jb weld. turnbuckles is a new one but I guess it is smarter that trying to make a spanish windlass with a bolt.
what's a tire plug kit??
93 fzj80
66 fj40L
m101cdn trailer
Old 11-14-05, 10:56 PM   #6
Beowulf's Avatar
This is a good one. I carry a cheap "Monkey Grip" set that I bought for cheap at a Pep Boys.
-B-
Old 11-15-05, 09:42 AM   #7
DieselROCKS's Avatar
For the Drill, get one of those new cordless impacts
I've used the makita at work, nice nice unit
Geoff
81 BJ60 300k kms hibernating for the winter
DieselROCKS is offline   Reply With Quote
Old 11-18-05, 09:49 AM   #8
alia176's Avatar
TLCA# 15941
Holy cow, that's a lot of stuff. Then I got to looking at my stash and I'm not too far behind I guess. I try to have multiple use tools to save on weight.
- a 2.5 lb hammer with a 10" handle as my only hammer
-a tool set in a low profile molded case that fits in the rear drawer. It has lots of deep and shallow sockets/wrenches/extensions/allen wrenches/1/2",3/8",1/4" drives. This kit is augmented with one 90 deg offset box end wrench 14mm-15mm (perfect for driveshaft removals)
-a set of metriwrench impact sockets from Harbor Freight (good for metric and standard)
-metric ratcheting gear wrench set (box end at both ends).
-one large adj wrench
-2' breaker bar, 1/2" drive
-1.5' pry bar
-one DVM, one IR temp gun
-JB weld, five sticks of 3/32" welding rods (used with modified jumper cables)
-duct tape, gasket maker, bailing wire
-safety devices tire seal kit, tire inflator goo in a can
-one 10' long, 14 gauge wire coiled up with alligator clips at each end, wire stripper, small assortment of butt splicers, spade connectors.
-flashlight - Streamlight rechargeable type, small and bright, mounted inside the glove box permanently
-1/2" impact gun, 3/8" butterfly impact, tool oil in a dropper thing, coiled up air hose, tire deflators, tire press gauge, blow off gun, tire inflation chuck. The 3/8" butterfly doubles as the Margarita blender motor.
- 12vdc powered fluor work lamp (similar to the ones for garage)
-simple green wet towels in a dispenser
-small can of wd40 (for starting fluid, cutting fluid, waterproofing, lubricating, etc)
-small container of brake fluid, one ATF quart, two motor oil quarts, one gal of radiator coolant premixed with distilled h20, one small funnel with a long neck
-one MRE, first aid kit, fire extinguisher
-small butane powered torch with a solder tip. Usually used for starting camp fires more than soldering!
-usual recovery gear (shackles, straps, etc)
-one small plastic box with multiple compartments filled with various metric M8, M10, M8.8 nuts/bolts with 1.25 and 1.00 thread pitch, one lug nut
-last but not least ....one 9MM GLOCK with one clip of hollow points, one clip of FMJs (17 round clips)
TLCA # 15941
KE5LED
Currently working PA
alia176 is offline   Reply With Quote
Old 11-18-05, 10:21 AM   #9
KI6MIE
Cruiserdrew's Avatar
TLCA# 11734
Dang Ali-Every thread in chat, and we're back to gubs! Actually, we frequently have Jeff's 10/22 on board.
I carry tons of stuff and usually enough tools and parts to rebuild half my cruiser (working on the other half). My tool box used to be a small tool box, then a large tool box, now a large tool bag I can barely lift. I know where Land Cruiser lean comes from. Interestingly, I've used most of it, and given away lots of little parts like wheel lugs, caliper bolts, knuckle bits etc. No gubs in the cruiser yet, but I do have a small butane soldering torch with a pistol grip.
If I could add to everyone's suggestions-a 12 inch piece of chain and a long bolt with washers and 2 nuts that fits through the link of the chain. It works great for repairing a broken motor mount, especially if you drive an FJ60.
Andrew
1997 FZJ-80 Driveway queen
Old 11-18-05, 11:55 AM   #10
aamiggia's Avatar
Wow, that's a lot of stuff. I hope your truck never gets broken in to.
I would try to scale back some overlapping tools:
- Do you need to have 1/4", 3/8", and 1/2"? If you're doing trail fixes a set of wrenches and a 3/8" would work. For added toque use a cheater bar or 3/8" breaker bar. Bring along a 3/8" --> 1/2" adapter for special sockets. other wise take 2 of 3 and don't overlap sockets. For 1/4" carry 8, 9, 10, and 12 mm. For 1/2" carry 14, 17, and 19.
- Do you really need a torque wrench for trail fixes?
- A cordless impact driver will not put out more torque than a 1/2" drive and breaker bar.
- A propane torch will never get a nut/bolt hot enough to help
- And easy outs don't work for rusted bolts. They're gear more for general purpose and not automotive. They're designed for over torqued bolts that bust a head. Not for ones that are welded in place due to rust.
Everything else looks good. What about some spare heater hose, coolant hoses, and belts? I would concentrate on the things that would tend to leave me stranded if they went.
'97 LX450
'86 Toyota Sprinter Trueno JDM RHD (aka Corolla GTS, AE86)
Project '87 Samurai LWB TDI
"The REVOLUTION will not be televised!"
aamiggia is offline   Reply With Quote
Old 11-18-05, 04:32 PM   #11
northerner
semlin's Avatar
OK, what is scary is that I keep forgetting stuff I already have. I do carry extra rad hose, fire extinguisher, plus zip ties, plus a funnel, plus a spark plug socket
my list was not originally covering first aid/emergency stuff. I agree with the stuff listed and add a set of triangles and flares.
Alia, your list may be heavier than mine.
Andrew, the chain seems like a good idea. I don't suppose 20 zip ties will hold a motor mount
Aamigia
I have given up trying to second guess where only a 1/4, 3/8 or ½ drive will work with only a short or deep socket. I just bring all of'em.
the cordless drill is for drilling out bolts or holes and always seems to find another use. not as an impact tool. it is prolly expendable.
the solid shaft easy outs are not too shabby. i agree the other ones are junk i disagree on the propane torch. it is not useless on rusted bolts and I can also use it to solder in a pinch. Oh yeah, i forgot solder!
torque wrench is prolly expendable. I bring it in case I have to swap a birf but there is no way the trail fix will be left alone when i return anyway..
93 fzj80
66 fj40L
m101cdn trailer
Old 11-18-05, 07:35 PM   #12
alia176's Avatar
TLCA# 15941
Yeah, no kidding...surprisingly, all of this stuff minus the oil bottles, fire extinguisher, coolant jug fit inside the rear drawer And my drawer height is shallower than most!
Ali
TLCA # 15941
KE5LED
Old 11-22-05, 06:27 AM   #13
aamiggia's Avatar
Semlin, I agree it's better to be prepared. If you have the room take everything.
I never thought about breaking a bolt and using the cordless drill to get it out. Do you drill out the treads and then tap it? Or do the easy out actually get the broken part out? I have a few snapped bolts that I have to fix, eventually.
'97 LX450
Old 11-22-05, 03:27 PM   #14
Infidel for hire
Biff's Avatar
TLCA# 14778
My moto is be over prepared, because you never know whats going to happen. Semilin, I like this thread going to put it in the FAQ if you don't mind.
Victor
08 FJ TT edition
71 fj40 project rig
Biff is offline   Reply With Quote
Old 05-24-06, 11:33 AM   #15
tech_dog's Avatar
My favorite: Snake bite kit
If you're in the southwest, you'll be a hero when you finally whip it out for someone.
1994 FZJ80 - Original Owner, dual battery, 2.5" OME Heavy/Medium, 295/75/16 Terra Grapplers, Slee front and rear bumpers, dimmable Lightforce 170s, Hanna Sliders, Slee transfer case skid plate, Warn 9.5XP, LED interior lights, Slee interior spare tire carrier, yellow box, orange dot mod
2006 LX470 - Original Owner, Daily Drive, no mods
tech_dog is offline   Reply With Quote
Old 05-24-06, 09:23 PM   #16
Pretty good equipment list
Front Seat Area
Glove Box
Advil, small dispencer
Book, survival/medical
Maintenance log
Gear Shift Deck
Cell phone charger
Center Top Elbow Compartment
Lighter
Mints/gum
Note pad
Pencils
Pens
Sharpe
Center Bottom Elbow Compartment
Most of the time the glock and two clips (no clip in gun)
LED tac light (2)
Tums, small dispencer
Driver Door Compartment
Hands free kit for cell
Thermometer/compass small combo tool
Walking stick next to seat
Passenger Door Compartment
Multi-tool
Mag light 4d
Tire deflaters
Tire pressure guage
Wine key
Driver Seat Back Net
Cards
Knot book
Back Seat Area
Passenger Seat Back Net
Small kids games
Diapers (behind baby seat)
Wipes (behind baby seat)
Back Seat Driver Side
Fire extinguisher
Cargo Area
Cargo Bulkhead Driver Side Compartment
Jack, small with accessories
Jumper cables
Tool Bag
Breaker bar, (cheater bar), fits over all sockets and wrenches
Hacksaw
Hammer, medium, claw
Hex wrench, angle (allen) metric and standard
Pliers, needle nose, med regular, snap ring,
Ratchets, 3/8 and ½ socket
Screwdrivers, short and long, cross head and flat
Sockets, adaptors,1/4m" to 1/2f", 1/2m" to 3/8f", 3/8m" to 1/2f"
Sockets, 10, 12, 14, 17, 19mm 3/8" inch drive sockets short and deep (10 pces)
Sockets, 21mm deep ½" socket (1 pce)
Sockets, 3" and 6" 1/4 and 3/8" extensions
Sockets, 54mm hub socket (1 pce)
Sockets, 8, 10, 12 mm 1/4 inch drive sockets short and deep ( 6 pces)
Vice grips, large and small
Wrenches, 7-27mm, stubby and regular (no need for 15,18,23,25)
Wrenches, adjustable (cresent) small, med and large
Wrenches, metric ratcheting gear set (box end at both ends)
Electrical Box
14 guage wire (25 ft)
Wires with alligator clips
Multimeter
Splices, butt (inline wire connector)
Spade connectors (pickel fork shaped)
Stripper/crimper tool
Map/Documents Bag
NM Topo/road map
Compass
Lexus maintenance guide
Mechanical Pencil
Pen
Topo quad UTM grid overlays
Maps for individual trips
Random Big Tools
Axe
Bungee cords
Ratchet straps
Come along
Main Box, grey plastic
In order to more easily inventory this box, an IOU log is used to track what consumables are removed.
Clean Box (Hygine/First Aid Items)
Baby wipes
Conditioner (small)
Cotton Balls
Dental floss
Feminine hygiene supplies
Fingernail clippers
Insect repellent
Lip stuff
Lotion
Mirror small (signaling)
Mouthwash
Organic/biodegradable soap
Q-tips
Shampoo (small)
Sun screen
Toothbrushes
Toothpaste
TP
Unisex deodorant
Medical Bag (Red Hip Pack inside clean box)
Cleansing/Sanitation
A & D ointment
Alcohol pads
Neosporin
Pain/antibacterial spray
Tea tree oil
Medication
Advil
Aspirin with codeine
Benadril
Diarrhea medicine
Electrolyte replacement powder
Laxative
Pepto Bismal chewable
Tums
Tylenol
Misc.
Cold pack
Cotton balls
Eye drops
Gloves, rubber (4 sets)
Hot pack (chem hand warmers work)
Moleskin
Plant irritant cream/wipes (oak, ivy)
Q-tips
Tools
First aid book
Scissors, medical
Snake bite kit
Thermometer
Tweezers
Wound Dressing
Band-Aids (good assortment)
Gauze (2-inch sterile(5) 4-inch sterile (5))
Liquid band aid (or super glue)
Tape, medical
Wound cleaner, foaming
Hardware
Hardware box
Fix a flat
Motor oil,Quart
ATF
Brake parts cleaner (small)
Brake fluid
Coolant
Fire starter solid fuel (trioxane tabs)
Fire tender (trioxane,starter tabs,used dryer lint in film canister)
Gasket maker
Grease, white lithium
JB Weld
Sterno, one can
Super glue
WD-40 (Cleaning, starting , cutting , waterproofing, lubricating)
Batteries (4)D, (4)AA, (4)AAA, (1)9v
Bailing wire
Candle
Candle refills (2) in plastic bag
Chem. lights
Chemical hand warmers
Duct tape
Electrical tape
Nuts n bolts: M8, M10, M8.8 nuts/bolts with 1.25 and 1.00 thread pitch
Parachute cord (50ft)
Paper shop towels
Spark plug wire, one, long
Spark plugs, 2
Trash bags
Zip lock bags
Zip ties
12vdc/120vac converter
Can opener (P38)
Eyeglasses, spare (in a case)
Funnel, long neck
Hose clamps various sizes
Lighters
Magnifying glass
Saw, Folding, wood
Sharpening stone
Stakes
Torch, small butane
Tubing, clear plastic, 5 ft
Mini tackle box
Fishing line (wraped around bolt to save spool space)
Hooks
Bait (non-perishable)
Weights (assorted sizes)
Bobbers (two small)
Sewing kit
Buttons (assorted sizes)
Needles (assorted sizes)
Safety Pins
Thread, military
Scissors (small high quality)
Recovery Box
D-Ring shackles
Hi-lift bumper adapter
Hitch and pin
Tow Strap (2)
Soft Bag (small green duffel)
Bandanas (4)
Blanket (2, fleece)
Foil blanket
Gloves, leather mechanics (on top of bag under bungie)
Kite
Light warm gloves (2adult,2kid)
Pants (2adult,2kid)
Ponchos (2adult, 2kid)
Socks (2adult,2kids)
Towel (2, as per HGTTG)
Underwear (2adult,2kid
Warm hats (2adult,2kid)
Warm long sleeve shirt (2 adult, 2kid)
Web belt and clasp
Emergency Food/Water Bag
Water treatment pills
Water (8qt 2qt/day/person)
Food (5000 cal 1200cal/day/person)
Hard candy (small bag)
Power bars (4)
Soup cans (2)
Outside on rack
High lift
Shovel
GoOutSideAndPlay is offline   Reply With Quote
Old 05-24-06, 09:26 PM   #17
Heres the header for the list above. It wouldnt fit! LOL
Truck Gear List
The general philosophy of the well stocked truck is three fold. One, the truck should hold most of the everyday quick convenience things that you might need most anytime. Second, getting stranded. If the truck gets stranded with four people, it should hold everything they would need to survive one day in a wilderness environment. Once a year on Jan 1, food and water should be rotated out. Third, repair. The truck should be self sufficient in any environment and hold necessary tools and hardware to repair most breakdowns (and help others less prepared).
Old 05-25-06, 09:27 AM   #18
Dan Dare!
rusty_tlc's Avatar
TLCA# 15069
I didn't see a rachet strap on anybodys list. These work great to stop a wheel from drooping when you jack your rig to work on a broken birf. Also useful for broken motor mounts.
Which reminds me I need to replace mine, I gave it away last wekend to a stranger who had lost one of his ATV tie downs.
Dan Johnson
Originally Posted by DSRTRDR View Post
maybe your life took a vacation without you and that's why you are going crazy........
Battle Born Cruisers
FJ40, A couple of thingamajigs and a deally bob, fully integrated whatzits, dash board Hula girl (pending spousal approval.)
And a pair of Pink Panties, now with a doohicky in the front.
Rust never sleeps.
rusty_tlc is online now   Reply With Quote
Old 05-25-06, 10:04 AM   #19
wesintl's Avatar
TLCA# 4180
a spill kit...
http://www.bluedevilproducts.com/Hom...20Frameset.htm
1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car
Rising Sun
; Former CLCC
You should be able to delete your own thread. Communists abound
wesintl is online now   Reply With Quote
Old 05-25-06, 12:04 PM   #20
JohnnyC's Avatar
TLCA# 2231
that is way too much stuff....all ya need is an OEM Tool Kit....
come on now !
it takes so much less room than all that stuff.
JohnnyC is offline   Reply With Quote
Old 05-25-06, 12:29 PM   #21
