Go Back   IH8MUD™ Forums > General Tech Forums > Camping - Gear - Recovery
Old 09-03-05, 06:31 PM   #1
Boston Mangler's Avatar
TLCA# 9060
Running CB Coax Cable Through The Firewall??? 80 Series
Hey Guys
Looking for some suggestions on how to route the CB Coax cable through the firewall on a 80 series. I couldnt find any obvious areas.
Any advice?
Baja Overland
www.bajaoverland.com
2006 XR650L
TLCA #9060
Own a Land Cruiser? Join TLCA Today @ www.tlca.org
Boston Mangler is offline   Reply With Quote
Old 09-03-05, 08:13 PM   #2
ThinkTank Waterboy
landtank's Avatar
there is a rubber grommet with a few nipples avaialble on the PS firewall. I just poked a center hole and then pushed the wire threw, the rubber should form tightly to it and keep the water out.
Rick Bigelow
'96 215k
Groveland MA 01834
landtank is online now   Reply With Quote
Old 09-03-05, 09:15 PM   #3
TLCA# 9060
Got it, that is what i did, came out nice!
Baja Overland
2006 XR650L
TLCA #9060
Old 09-03-05, 10:18 PM   #4
4x4CPOSEADOG's Avatar
What kind of CB antenna are you using? I have a Wilson 1000 that I use and mount in the mid rooftop then route the cable on the driver side. Only use mine on a long distance trip listening to bunch of truckers.
Noel
97 LX450 (lockers retro 50%), CDL, Pin 7, HIRs, Cup Holder, 100 pads, George's LEDs, OEM grab bar, sidemarkers, ARB winch bar, PIAA 520, 295/75R16 NTG, Kaymar Deluxe with tire carrier, Slee speedo gear, ARB fridge, Xantrex 1750 inverter. Awaiting installation: OEM subtank, OME850J/863, slee SS brake lines, 3* blue bushings/caster plates, BIC 95300B dual batts, silicone PHH/FHH, ....
94 4Runner, OEM 4.88 gear, V6 3VZE
04 Taco Ext Cab SR5 V6 TRD RR DIFF LOCK, groucho sliders
4x4CPOSEADOG is offline   Reply With Quote
Old 09-03-05, 10:34 PM   #5
TLCA# 9060
Its a 3ft Wilson "Flex Whip"
Baja Overland
2006 XR650L
TLCA #9060
Mortgages | Personal Loan | Loans | Loans | Mortgage Calculator
