Go Back   IH8MUD™ Forums > General Tech Forums > Camping - Gear - Recovery
Old 09-03-05, 06:31 PM   #1
Boston Mangler's Avatar
TLCA# 9060
Running CB Coax Cable Through The Firewall??? 80 Series
Hey Guys
Looking for some suggestions on how to route the CB Coax cable through the firewall on a 80 series. I couldnt find any obvious areas.
Any advice?
Baja Overland
www.bajaoverland.com
2006 XR650L
TLCA #9060
Own a Land Cruiser? Join TLCA Today @ www.tlca.org
Boston Mangler is offline   Reply With Quote
Old 09-03-05, 08:13 PM   #2
ThinkTank Waterboy
landtank's Avatar
there is a rubber grommet with a few nipples avaialble on the PS firewall. I just poked a center hole and then pushed the wire threw, the rubber should form tightly to it and keep the water out.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 09-03-05, 09:15 PM   #3
TLCA# 9060
Got it, that is what i did, came out nice!
Baja Overland
2006 XR650L
TLCA #9060
Old 09-03-05, 10:18 PM   #4
4x4CPOSEADOG's Avatar
What kind of CB antenna are you using? I have a Wilson 1000 that I use and mount in the mid rooftop then route the cable on the driver side. Only use mine on a long distance trip listening to bunch of truckers.
Noel
97 LX450 (lockers retro 50%), CDL, Pin 7, HIRs, Cup Holder, 100 pads, George's LEDs, OEM grab bar, sidemarkers, ARB winch bar, PIAA 520, 295/75R16 NTG, Kaymar Deluxe with tire carrier, Slee speedo gear, ARB fridge, Xantrex 1750 inverter. Awaiting installation: OEM subtank, OME850J/863, slee SS brake lines, 3* blue bushings/caster plates, BIC 95300B dual batts, silicone PHH/FHH, ....
94 4Runner, OEM 4.88 gear, V6 3VZE
04 Taco Ext Cab SR5 V6 TRD RR DIFF LOCK, groucho sliders
4x4CPOSEADOG is offline   Reply With Quote
Old 09-03-05, 10:34 PM   #5
TLCA# 9060
Its a 3ft Wilson "Flex Whip"
Baja Overland
2006 XR650L
TLCA #9060
Handytest | Mortgages | Loans | Bleach 183 . Bleach 184 | Moneygram
