Go Back   IH8MUD™ Forums > General Tech Forums > Camping - Gear - Recovery
Old 08-24-05, 08:57 PM   #1
TLCA# 15221
Engel vs. Coleman
Searched, but didn't find anything on this: What exactly is the difference in performance between an ARB or Engel fridge and a Coleman plug in cooler, besides a $600 price difference?
Pete483 is offline   Reply With Quote
Old 08-24-05, 09:01 PM   #2
When it is hot one gets cold and the other doesn't.
Rich is offline   Reply With Quote
Old 08-24-05, 09:12 PM   #3
TLCA# 15221
Wait, let me guess which one is which! I really don't need something like the Engel, but is the Coleman really any better than a regular cooler? If I were to put those blue ice pack things in it when I loaded is (with the blue packs cold), would it be worth the extra $40 of just a regular cooler?
Old 08-24-05, 09:28 PM   #4
dd113's Avatar
Nope, coleman just lowers the interior temp below ambient temp by 30' or so while it sucks all the juice out of your system. ARB/Engle/Norcold all have compressors just like your fridge at home. No comparson with coleman.
David Dearborn
www.urbanlandcruisers.com
Foreign Minister for life of the White Trash of the Elwood Chapter.
I collect Hello Kitty
dd113 is offline   Reply With Quote
Old 08-24-05, 10:30 PM   #5
You want to do what...?
e9999's Avatar
check my recent threads on this, with numbers and all....
'97: 88K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!)
'03: 99K, the better half's...
DD
souped up DR650
Old 08-24-05, 11:45 PM   #6
Ih8mud stalker
mabrodis's Avatar
A Coleman cooler is a thermo-electric cooler, which uses energy to move heat. Basically there are electric components attached to 2 aluminum chunks. On one side of these electrical parts it gets cold because heat is being moved from there to the other side, where ofcourse they get hot. When in cool mode the inside gets cooler and the outside gets hotter, when reversed just the opposite happens. The idea is cool and as far as cooling they do ok, but the catch is they use alot of power to move that heat. So let's say a Coleman one draws about 4-amps continously (my wall plug that came with mine is rated to put out 5.25A at 12V, so it must draw less than that). That is 48 watts of power it's using, but alot of that power is being used to move the heat, and in moving the heat, it generates heat, all that heat has to be removed from the heat-sink on the outside of the cooler. The actual watts of cooling power the cooler gets is probably around 15-20 watts (guessing here), so they do not cool fast and will not ever get really cold. They will cool to something like 40 degrees below ambient temperature (since the cooling is based on a temperature differential between the heat-sink on the inside of the cooler and the one on the outside of the cooler, it's just moving heat from one of those to the other).
I have a Coleman and it's ok, I used it alot at first, it would keep things cold enough that they wouldn't go bad, so I was happy. It is not a replacement for a ARB fridge by any stretch...I think mine is broken or something, doesn't really get cold much anymore, so I haven't used it recently. It's neat that it's dry, no ice/water, etc. But it's so slow to get cool that at many times I would have just preferred to buy a $1 bag of ice and call it good for a day or two. I will get an ARB fridge at some point, but a $20 cooler and a few dollars in ice is WAY cheaper than either the Coleman or the ARB, so that's what I think I'll do in the near future...
"The pessimist complains about the wind; the optimist expects it to change; the realist adjusts the sails." -William Arthur Ward
'96 4runner, 3.4L, 5sp, E-locker...
'85 Mini, 2nd owner...add-ons: 31" MTRs, oil & dirt stains...
'00 Echo, 1.5L of FURY!
mabrodis is offline   Reply With Quote
Old 08-25-05, 07:44 AM   #7
expeditionswest's Avatar
TLCA# 14910
I am so sold on the Engels (I own two 45L units) that it is the first modification I do to a vehicle after good tires and sliders. Also, I live in AZ, so a practical way of keeping food and drinks cool is likely more important that other areas.
I have also used the thermo-electric units and the results were very dissapointing over 70 degrees ambient (they can only cool about 40 degrees below ambient)
The build quality and efficiency of the Engel (Engel, ARB, Norcold) units are without peer as well... It is worth forgoing the new aluminum wheels (or winch, etc.) and getting the fridge IMO...
Scott Brady, Tread Lightly Master Trainer
EarthRoamer XV-JP | Toyota Tacoma | Land Rover Discovery I
Expedition's West
Overland Journal- Expedition Magazine
Expedition Portal Community
expeditionswest is offline   Reply With Quote
Old 08-25-05, 07:59 AM   #8
freightdog's Avatar
Living 128 miles from town - we rely on our ARB to keep meat/seafood cold on the way home - nothing beats an ARB/Engel/Norcold unit...
If you don't have the cash for one buy a Coleman 7 day unit and pack it with ice - we used that system for years...
I got my ARB as a bonus at work for scoring a grant for $780,000 for a school district in Texas or I wouldn't have one!
"What ever fuckface, you cant deal with the real world or a real world job, keep hiding out on the rez living off your girl........." = priceless!
as said by Calstyl2
http://www.myspace.com/cruiserhead
freightdog is offline   Reply With Quote
Old 08-25-05, 08:38 AM   #9
wesintl's Avatar
TLCA# 4180
I finally bit the bullet after searching for a while. They are unbelievable, I had my norcold on 2 and I have little bit of ice in my waterbottles. Like EXwest said they really need to be moved up on mod list. forget the colman 12v
1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car
Rising Sun
; Former CLCC
You should be able to delete your own thread. Communists abound
wesintl is offline   Reply With Quote
Old 08-25-05, 10:43 AM   #10
firetruck41's Avatar
TLCA# 14300
Thread with review of Coleman thermoelectric cooler
Comparison of different fridges with actual temperature performance
Ben Silva
IH8MUD Site Supporter since July 2004
1996 Lexus LX 450, 130k, locked, Cooper STT 285s, OME 850/863, CDL/Pin 7, 30qt freezer, 2@aux fuse blocks, aux powerpoint, 850w inverter
1998 Lexus LX 470, 139k Sold
1993 FZJ80 198k miles Sold
firetruck41 is offline   Reply With Quote
Old 08-25-05, 01:58 PM   #11
Coleman Cooler/Freezer
FYI: Coleman now makes a cooler/freezer too. Not a thermoelectric.
Coleman Stirling Power Cooler
Instruction Manual
But it lists for $600!
Haven't seen any reviews on it, but for that $$$ I'd go with a tried and true ARB, Engel, etc...
norcal '99 is offline   Reply With Quote
Old 08-25-05, 02:13 PM   #12
TLCA# 14910
Nice catch norcal'99!
That looks like a Wedco unit a little...
Expedition's West
Old 08-25-05, 02:21 PM   #13
spressomon's Avatar
Instruction Manual
Looks like it is made by Waeco...you can by the Waeco Coolmatic CF51 for about the same price as this smaller Coleman.
Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM
Old 08-25-05, 04:37 PM   #14
What's interesting to me about this Coleman is that they call it the "Stirling Power Cooler".
A Stirling Engine can be used for referigeration. And can theoretically be very efficient without the need for a compressor refergerents, etc.
I'm not sure that the Coleman is really powered by a Stirling Engine, but if it is it could be cool. Efficient, no refrigerents to leak, etc.
The Waeco units look like they are powered by a Danfoss compressor and the ARB/Engel units are powered by the Sawfuji Swing compressors.
If anyone has any details on the Coleman, I'd be interested.
But like I said, the think the ARB/Engels are tried and true.
Old 08-25-05, 05:49 PM   #15
e9999's Avatar
says don't use the Coleman Stirling at more than 12 deg inclination or it may malfunction (?) ... not good for Moab
and 4A - isn't that more than the medium size Engels?
DD
souped up DR650
Old 08-26-05, 04:11 AM   #16
grown up MOD
reffug's Avatar
TLCA# 14549
All I know is ARB had better kick ass. Or I am gonna be a little miffed.
"If it wasn't a Landcruiser and hadn't been built the way it was you do realize you would be DEAD." VA State Police Officer
reffug is offline   Reply With Quote
Old 08-26-05, 06:48 AM   #17
TLCA# 14300
30 degrees farenheit, or more, below freezing kicks ass!
Ben Silva
Old 08-26-05, 07:26 AM   #18
FJ60Cam's Avatar
TLCA# 16341
How long can the ARB-type fridge run with the engine off before it drains the battery to a no-start? Could you let it run overnight, or do you just turn it off and let it coast?
FJ60Cam is offline   Reply With Quote
Old 08-26-05, 07:44 AM   #19
Heffenoche's Avatar
It says it doesn't use refrigerants or CFCs.
94 FZJ80 134k Locked, ARB Front, OME heavy, Warn 12000, TJM Rear. 285 MTRs, LED's & rear cargo light.
85 FJ60 98k, ARB front, 3"lift, 32" BFG AT
Heffenoche is offline   Reply With Quote
Old 08-26-05, 07:47 AM   #20
freightdog's Avatar
I have two yellowtop optima and have never even come close to runningeither battery down - i have a dual battery setup in the 60 so...
When I have kept the ARB in the camper - it never ran the battery down - that is an interstate deep cycle battery - and we have camped three days running the ARB/lights/water pump...it has a low amperage draw so...
as said by Calstyl2
Old 08-26-05, 11:39 AM   #21
grown up MOD
reffug's Avatar
TLCA# 14549
Dats exactly what I'm hoping........................
Old 09-02-05, 09:09 AM   #22
When I bought my ARB (which I consider to be just about the best money I ever spent, a lot of 3-5 day trips in the backcountry) I did a 48 hour test in the garage with a yellow top optima. I had over 11.5v after two days without charging the battery. When camping with other rigs I never turn it off, and have started the rig after two days no problem. When solo I turn it off at night though, cuz I'm a girly man! But it is really insulated and if well chilled will go all night w/o power.
As far as rugged, it's been Rubicon tested many times no problemo.
JonB
JonB ke6gfb
87 bj70, arb'ed, slidered, winched, 4x4llabs bumper.
97 40th fzj80 w/difflocks, cdl switch & pin 7 mod, Hanna sliders, 2.5" ome lift, 1" body lift, rear drawer system on 285/75-16's.
87 sas 4runner- air lockers, dual cases, beadlocked 35" mtr's, waggy & cheby springs, sliders, 8274 winch, etc...
jonb96150 is offline   Reply With Quote
Old 09-02-05, 09:28 AM   #23
tlcwagons.org
FirstToy's Avatar
I've been using it w/ the stock battery-on trips, I never turn it off. It never has any trouble starting cold, overnight, two days... I think the fridge is really low draw and you only need it set at 1.5 for good refridgeration (2 started freezing stuff).
Best money I've spent for camping.
TLCA#14645
BRC#41798
I love cachapas!
my wip
I drink your milkshake!
Old 09-02-05, 09:31 AM   #24
TLCA# 14910
I have had some issues with excessive amp draw in really warm weather (I live in AZ ), as the fridge runs almost constantly. One thing I found to be very helpful was one or two of the coleman gell ice packs. They do take up a little space, but make a big difference in cooling performance in hot weather.
Expedition's West
Old 09-02-05, 10:15 AM   #25
wesintl's Avatar
TLCA# 4180
also remember that a fridge works less when full. I usually keep mine full of water or other drinks then take stuff out to fit what I need as far as food. I have 2 yellow tops and Left the fridge on for 3 days continuous in the garage. I had pleanty of power to turn over the 3b and start. I am considering a solar charger for the batteries on a long trip. Anyone use one with dual batteries and a fridge? I noticed specific mention of not charging the battery with the fridge on. I would think the same thing applies to a solar charger??
Rising Sun
; Former CLCC
Old 09-02-05, 02:15 PM   #26
alia176's Avatar
TLCA# 15941
Our Engel doubles as a garage fridge. Keeps the 86s nice and cold for those long wrenching sessions! If I used the coleman in the same capacity, then I think it'd just run forever and keep going colder and colder (open loop). Frozen pop and beer no good!
TLCA # 15941
KE5LED
Currently working PA
alia176 is online now   Reply With Quote
Old 09-02-05, 06:55 PM   #27
Where's mah cruzah?
polarweasel's Avatar
TLCA# 17558
alia: the Coleman has temperature controls on it... cool 1-3, and freeze 1-2. Check out the owner's manual.
I think it really is a Stirling engine in there, too. Someone hurry up and buy one and take it apart!
84 FJ60, locked and lifted and dismantled with Mercedes diesel
1982 BJ42 loud and slow daily driver on 33s
Horsetooth 4-Wheelers
polarweasel is offline   Reply With Quote
Old 09-02-05, 07:44 PM   #28
Dunbar's Avatar
After our 2 week 3000 vacation my wife has stopped comlaining about the frivolous purchase of my 60qt Norcold. In fact there has been no more talk about ebaying it or even removing it from the truck while in town.
I got my scratch and dent model for $649 with shipping and it rocks. It was brand new but dented up on the compressor louver cover area. I don't care because it works great.
RVexit was the outfit where I got it. They had it drop shipped directly from Norcold. Chech the other thead for the contact info.
Dunbar
Dunbar
TLCA # 14016
1988 FJ62 ~285k miles
H55F Dobinsons suspension
Hot Rod 3FE 8274 ARB
Tomball Texas
