Go Back   IH8MUD Forums > General Tech Forums > Camping - Gear - Recovery
Old 03-29-05, 01:25 PM   #1
80s muncher
2badfjs's Avatar
anyone use harbor frt tube notcher??
good things, bad things. opinions please.......
SOLID ROCK OFF-ROAD
http://www.solidrockoff-road.com/
1991-92 80 series sliders available, WITH CAT PROTECTION!
It's how YOU want it, i'm just here to build it for you.
SLIDERS FOR 40s' 60s' and 80s' plus a little bit more
2badfjs is offline   Reply With Quote
Old 03-29-05, 01:42 PM   #2
Admin
woody's Avatar
TLCA# 1548
believe that's the one I have...$50ish IIRC...it works, but I have bent it more than once....
if you do notch work rarely, go for it...if it's something you plan to use for more than one project, spring for something nicer.
Brian 'woody' Swearingen
1974 FJ40 'The Raisin' - Pitbull Rockers, 30-spline Longfields, SOA - 1/4 ellip
1996 FZJ80 'Gretchen' - MetalTech, ARB, OME, IPOR, 4x4Labs
2003 2500HD Duramax - Edge/Juice/Attitude, 285 Nitto Terra Grapplers, 4" exhaust
'America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.' Abraham Lincoln
Old 03-29-05, 02:56 PM   #3
80s muncher
2badfjs's Avatar
what gets bent
and can it be reinforced for strenght????say weld a gussett to it!
SOLID ROCK OFF-ROAD
Old 03-29-05, 02:58 PM   #4
Admin
woody's Avatar
TLCA# 1548
it's not weldable, but I did reinforce it, and it's worked fine since. it's the main body that bends. Just not a HD design, and not for serious work, but for the rare use....
Old 03-29-05, 05:45 PM   #5
e rock's Avatar
TLCA# 6829
There's a local (but nationally known) buggy/fab shop that uses them. I laughed at first, but he said that they buy a bunch when they're on sale for $30 or so. True, they don't last as long as a more expensive unit, but it actually turned out to be more economical to buy disposable notchers and throw them away than pay for more expensive ones.
YMMV,
Eric
-Eric
64 FJ40, slightly modified.
97 LX450, bone stock.
e rock is offline   Reply With Quote
Old 03-29-05, 05:50 PM   #6
80s muncher
2badfjs's Avatar
thanx for the info
i think i'll go look at em
SOLID ROCK OFF-ROAD
Old 03-30-05, 11:35 AM   #7
I'm really very humble
photogod's Avatar
Grizzley has a simmilar one in the heavier duty for a few bucks less, $59.99 vs. $64.99 from Harbor.. Just ordered one from Griz. Looked to me like the griz model was a bit more stout. Just looked at the both of them and they look identical to me.
photogod is offline   Reply With Quote
Old 03-30-05, 11:56 AM   #8
photogod's Avatar
Just as a side line and not wanting to hijack this thread, I was using my drill press trying to notch the tube I used to fab a roof rack and the blade was chewed to hell trying to cut into the tube. It would cut on the away stroke but broke the teeth on the in stroke at the face of the tube. Does that make any sense?I am assuming that I had the speed of the bit up to high? I was using a metal hole bit. Any pointers on cutting metal like this are are appreciated.
Old 03-30-05, 11:59 AM   #9
80s muncher
2badfjs's Avatar
i have the blue point hole saws
from snap-on,i've broken a tooth also, but it was'nt held down like it should have been. you mentioned grizzley, do they have a web site?
SOLID ROCK OFF-ROAD
Old 03-30-05, 12:03 PM   #10
photogod's Avatar
http://www.grizzly.com/products/item...emnumber=G8686
Old 04-01-05, 02:12 PM   #11
photogod's Avatar
Just got the tube notcher in the mail. Nice unit, seems pretty robust. Time to try it out on the next roof rack build. I had to grind the notches in the tube last time and not all of them came out perfect. Lets see if this helps. 2badfjs, did you order one as well?
Old 04-01-05, 02:53 PM   #12
80s muncher
2badfjs's Avatar
not yet
waitin till payday
SOLID ROCK OFF-ROAD
Old 04-01-05, 09:30 PM   #13
alia176's Avatar
TLCA# 15941
I borrowed the HF unit from a co-worker..worked out great as long as you use a good quality metal hole saw (Home Depot). The fixture was solid and well designed for what I needed it for. The cuts were clean and took about 10 seconds for 1.5" DOM tubing with .120 wall tubing. You need to have a large enough of a drill press to accomotate the entire unit solidly. The bigger the drill press, the better your cut will be due to more stability.
For $50 or so, it'll work just fine for most shade tree mechanic.
TLCA # 15941
KE5LED
Currently working PA
alia176 is offline   Reply With Quote
Loans | Mobile Phones | Love Calculator | Mobile Phones | Credit Card Consolidation
