Engine RPMs while winching?
Putting a Hand Throttle in my 60 tomorrow. Did a search on RPMs while WINCHING could find no info.
I figure 2000 RPM? 2K would have the stock Alternator worked up pretty good. What's the general rule? __________________ 1984 FJ60, 102k miles, OME med/heavy, BFG/MT 33X9.50 on Stock Wheels, ARB Bullbar W/Warn 8274, Tuffy Console. Last edited by High Desert; 05-07-08 at 11:28 PM. Reason: I CAN SPELL..I JUST DON'T DO IT VERY WELL |
#2 | |
If you're a married man...I don't know if you should be out "wenching" at all. ![]() Main Entry: 1wench Pronunciation: \ˈwench\ Function: noun Date: 14th century 1 a: a young woman : girl b: a female servant 2: a lewd woman : prostitute But... when I am "winching" I set my hand throttle at 1200-1500 rpm. I run a 100 amp. alternator and have dual batteries. So, your needs may vary. 2000 rpm sounds a tad high to me. __________________ Flintknapper: '97 Land Cruiser, Moonglow Pearl Chocolate Lab (Kota), I miss you. ΜOΛΩΝ ΛΑΒΕ (come and take them) |
I hear the average with a wench is about 15 to 20 min. More or less depending on your ability
__________________ Thad Brown/ Rogersville Mo 84 FJ 60 / SROR sides and rear / beauty marks from RR, FN, & LSCR / Free bumper from GCC and Locker from LSCR/ 07 FJ 08 Tundra Rocket ship Green Country Cruisers |
When you use a winch you need to make sure its getting max power. The best way is a good battery and a good gauge to make sure you are putting out the power. I personally find that 12 to 15 hundred work fine with my set up
#5 | |
7 dirty words
What is the current draw? The stock alternator in a 2F puts out 45 Amps, a stock SBC alt puts out around 100Amps. As an example the 12V Warn XD9000 draws 460Amps at max load (9000#) 330Amps at a more realistic 6000# load. The battery is where it's at. Forget the hand throttle and get a good starting battery with the most cold cranking amps you can find. Stay away from deep cycle batteries for winching they are designed for slow deep discharge. __________________ Dan Johnson "Does this stairway go all the way to the top of the tower?" Battle Born Cruisers FJ40, A couple of thingamajigs and a deally bob, fully integrated whatzits, dash board Hula girl (pending spousal approval.) And a pair of Pink Panties, now with a doohicky in the front. Rust never sleeps. .- -.. --... -. .-- |
Oh crap..man I know how to speil winch..can't believe I did that, again
..But note taken about the 15-20 min wenching...If my wife lets me get out...I'm going to edit the first post in this thread..that will fix it for me ![]() ![]() __________________ 1984 FJ60, 102k miles, OME med/heavy, BFG/MT 33X9.50 on Stock Wheels, ARB Bullbar W/Warn 8274, Tuffy Console. |
#7 | |
I don't plan on loading up the winch and running it for any long time spans...not gonna be any body's "winch bitch"..my rigs electrics are stock. Every time I've run the winch up to now I've just shut it down and run off the battery. If a 2min run time over a 10 min time span is gonna kill my battery then so be it. but, if I do get in a situation where I've got to use if for extended time (meaning off and on power for what ever reason, long enough to drain the battery and not re-start the rig) I was asking what to run the RPMs up too to actually do a little good at keeping some juice going into this system.. 1200-1500rpm sounds reasonable.. It's late here in OR and I gotta get back to my wench... HD __________________ 1984 FJ60, 102k miles, OME med/heavy, BFG/MT 33X9.50 on Stock Wheels, ARB Bullbar W/Warn 8274, Tuffy Console. Last edited by High Desert; 05-07-08 at 11:35 PM. Reason: I just can't spell a damn thing... |
I concur with Rusty, forget about the Alt helping out much - I'd recommend a huge battery (or two), heavy duty welding cable for powering up the winch and pay out as much winch cable as possible to make the winch work less.
__________________ TLCA # 15941 KE5LED Currently working in Danville, PA until Aug. |
#9 | |
Okay, that's all been done from the get go. Battery, Snatch Block, new heavy cables made as short as possible to cut down resistance. Not going duel batteries unless/until I start using the rig a whole lot more. Thanks JON __________________ 1984 FJ60, 102k miles, OME med/heavy, BFG/MT 33X9.50 on Stock Wheels, ARB Bullbar W/Warn 8274, Tuffy Console. |
#10 |
7 dirty words
One great thing is batteries are much smaller nowadays. I have a battery with 25% higher CCA than the stock battery and it is lost in my battery tray. From what I've seen most of us will be fine with a stock single battery set up. Unless you get into competition winching.
Or competition wenching. Theres one we probably won't be seeing in the summer Olympics. ![]() __________________ Dan Johnson "Does this stairway go all the way to the top of the tower?" Battle Born Cruisers FJ40, A couple of thingamajigs and a deally bob, fully integrated whatzits, dash board Hula girl (pending spousal approval.) And a pair of Pink Panties, now with a doohicky in the front. Rust never sleeps. .- -.. --... -. .-- |
#11 |
So my wife reads the first couple of Post where I innocently used the word "wench" instead of WINCH. Of course she reads where you guys were oh-so-politely trying to figure out what I was talking about.
She says "So that's what I get for letting you buy all that crap for that damn jeep, you get winches and lifts and boxes, then your asking you "buddies" about whores and how long it'll take you to get one, and what the charge will be! You can start sleeping in that damn thing!" So thanks "Buddies" I'll go tuck my self into my "jeep" now.... __________________ 1984 FJ60, 102k miles, OME med/heavy, BFG/MT 33X9.50 on Stock Wheels, ARB Bullbar W/Warn 8274, Tuffy Console. Last edited by High Desert; 05-08-08 at 08:33 PM. |
#12 |
Any AGM style battery will do as they all have thin high surface area plates. The nice thing about AGM batteries is they can dish out high current loads better than most other cell structures.
__________________ ☢ let sanity = false;; ☣ |
#13 |
Dog is my co-pilot.
Hi All:
I'm a bit confused here. I use a high CCA rated deep cycle battery because I was under the impression that normal lead-acid automotive batteries were not designed for repeated drain-downs and recharges; that this sort of activity would damage the internal plates of the battery, while deep cycle cells are designed for repeated drainings and recharges. Regards, Alan ------------------------------------------------------------------------- |
#14 | |
They don't have quite the long term life expectancy of a true deep cycle battery. On the other hand they can put to shame most battery styles in long term high current output like winching would need.__________________ ☢ let sanity = false;; ☣ |
#15 | |
Dog is my co-pilot.
Hi All:
"Bogo," what does "AGM" mean? Is this like the gel-cell Optima batteries? Thanks! Alan ------------------------------------------------------------------- Quote:
#16 | |
7 dirty words
Deep cycle batteries usually have a lower CCA rating for the same size but a higher RC. The reserve cranking amps are pretty worthless for winching. Optima use to have a nice write up about this on their site but I can't find it now. __________________ Dan Johnson "Does this stairway go all the way to the top of the tower?" Battle Born Cruisers FJ40, A couple of thingamajigs and a deally bob, fully integrated whatzits, dash board Hula girl (pending spousal approval.) And a pair of Pink Panties, now with a doohicky in the front. Rust never sleeps. .- -.. --... -. .-- |
Credit Cards | Credit Cards UK | Free Ringtone | Private School Louisville | Debt Help |
