Go Back   IH8MUD™ Forums > General Tech Forums > Camping - Gear - Recovery
Old 09-03-04, 12:18 PM   #1
Admin
woody's Avatar
TLCA# 1548
Battery Isolators...
I've got a SurePower installed in the rig right now, but the bloody thing soaks a full volt...14amp at the alternator, 13 once it gets split to the batteries....even with clean connections and good quality fine strand wires...
Who's got a good one out there? (this one was a cheapie...)
Brian 'woody' Swearingen
Lead Driver, Toyota Trail Team (Central)
'07 FJ Cruiser...Revtek, 285 BFG-AT's, ARB/Warn, BudBuilts, 93k miles...
'74 FJ40 'The Raisin'...TBI350, mVB 700r, 4:1 32-spline D300, SOA/ellip 4-link, RoundEyes, 8274-50/WinchLine, 30-Longs, 37" PBR's/TR's...
'95 HZJ75...1HZ, H55F, mine bed, BFG-MT's...
'96 FZJ80 'Gretchen'...OME, E-loks, 285 FCII's, ARB/T-Max10k/WinchLine'd, MetalTech'd, 4x4Lab'd, IPOR'd, Slee'd, UltAir'd, INTI'd...
'03 Chevy 2500HD Dmax, Diamond Eye 4", Diablosport, Bose, 285 Nitto TG's, B&W...
'08 ABU 14,000# 32' gooseneck car hauler...
'?? buggy ??...5.3 Chev, 700r, Atlas, axles?, SAW's, 7075/QA-1's...design phase 1...
Glock 17C - Kahr CW9 - Sig Mosquito - Davis D-32 - Remington 7600 - Marlin 30AS - Ruger 10/22
Old 09-03-04, 08:22 PM   #2
All of the diode based isolaters have pretty much the same voltage drop. The solution is to wire the alternator so that it senses the voltage between the battery and the isolater, otherwise, the batteries do not get the intended charging voltage, as you have discovered.
At the cost of greater complexity, go to one of the relay based systems. For simplicity, use a manual dual battery switch.
Rich is offline   Reply With Quote
Old 09-12-04, 09:11 AM   #3
Waggoner5's Avatar
Manual, less things that can go wrong.
Gary Waggoner
Golden, Co
1989 FJ62 SOA, 502 Mercruiser, ARBs Sold
1987 HJ61 SOA, Cable Locks, 39k miles Sold
1983 FJ40 sitting broke since 89
1965 FZJ45 Pickup on modified 80 chassis
2003 Tacoma, ARB, OME, SC, TRD
TLCA 10689
LSLC 2000
Rising Sun 2007
www.powerplayracing.net
Waggoner5 is offline   Reply With Quote
Old 09-12-04, 03:24 PM   #4
The quick brown fox .....
Beowulf's Avatar
Woody,
I'm considering the Hell Roaring unit. Yomama has been using one for about 3 years and he is very happy with it.
-B-
97 FZJ80 - Wing Nut MAF, locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, M12000, OBA, Outback drawers + other stuff. Transformation in progress...
Old 09-12-04, 07:27 PM   #5
Junk's Avatar
My late friend Mike Schroth had the hell roaring in his 80 and loved it. Damn I miss that guy.
Woody, I have a SurePower in mine now. They are pretty good. I don't know if they have different lines or not if all are of same quality. I thought the most you should see is about .4 amp drop and that's it. If you're running duals though, it should not be a huge deal should it?
Junk is offline   Reply With Quote
Old 09-12-04, 08:38 PM   #6
LandCruiserPhil's Avatar
I agree
Seen several dead dual battery set-ups with those high price isolaters. Plus no voltage loss when you go manual.
Phil
"Knowledge without experience is just information"
Copper State Cruisers #003
LandCruiserPhil is offline   Reply With Quote
Old 09-12-04, 08:41 PM   #7
Admin
woody's Avatar
TLCA# 1548
manuals a good choice...now, tell me how to wire two batteries in so one is exclusive to the winch, the other exclusive to the rest of the rig, and so both get charged....
Old 09-12-04, 08:58 PM   #8
Junk's Avatar
shees Woody, you want them to stop over and do it for you too?
Old 09-12-04, 10:13 PM   #9
Not even a web wheeler
TLCA# 4080
Actually, I'd love to hear the explanation too, that's *exactly* what I want to do with mine, right now I have a dead Mean Green isolator and an unused deep cycle Optima, I want to use a switch and get it over with, tired of fiddling with the isolator and I'm not spending a chunk of cash on one of those solenoid-based systems.
Exiled is offline   Reply With Quote
Old 09-13-04, 09:30 PM   #10
Here is how I would (will, when I get more ambition) do it. Blue Sea marine dual battery switch. Has 4 positions, bat 1, bat 2, both, and off. Run the positive cable from each battery to the switch. Ground both batteries together. Connect all electrical loads to the output from the switch. Now you can choose to run everything off of either battery, or both batteries. When you want, you can switch all power off by turning the switch.
When you winch, if you want to use only one battery, the turn the switch to the battery you want to use. You get to choose either battery or both if necessary.
In order to charge both, you need to have the switch set to both. This is the simplist setup, but requires you to manually combine or isolate the batteries as needed for use or charging.
With the addition of a single solenoid, also from Blue Seas, you can set it up so both batteris are paralleld for charging when the engine is running. With this addition, both batteries get charged when the engine is running, regardless of the main switch setting. If you do this, then you need to wire up a disconnect for the solenoid if you want to be able to winch off of a single battery with the engine running.
Old 09-13-04, 10:56 PM   #11
I also use a constant duty relay to connect the batteries together via 1/0 cable. A 3-position switch to control them. 1st position batteries connect when ignition is turned on. 2nd position batteries are not connected under any condition. 3rd position batteries are connected under all conditions.
Phil
Old 09-15-04, 09:50 AM   #12
ParadiseCruiser's Avatar
I would side with Rich and others in using a solenoid switching system. Christo has a wiring diagram on his site that can be used as is, or modified for your particular application.
The schematic is here.
I have used a variation of this set up for some time, with winch, radios, etc. and it works quite well. Here are the advantages as I see it...
1. Less expensive;
2. Installs in a smaller space;
3. No voltage drop;
4. When discharging, batteries are isolated only when engine is not running...
This last point is significant (to me) because when you have a high current demand with the engine running (winch, lights, radio [in transmit], etc.), you are better served with a pair of batteries in parallel, than just a single one - or the other - depending on how you have wired them.
The major "disadvantage" of potential inrush of current from a charged battery to discharged battery is mostly hype, and can be avoided if you wire the system so the batteries do not "see each other" until after the alternator is actually putting out a charging voltage.
Cheers, R -
Ron
Paradise CA
97 FZJ80 40th 1B2 99K
• OEM > lockers, subtank, manual throttle, aux pusher fan, CDL sw
• ARB fr, Kaymar rr, Warn 12K, OME 850/863, Hanna sliders, dual batt, ham radio
ParadiseCruiser is offline   Reply With Quote
Old 09-16-04, 11:34 PM   #13
IH8MUD Lifer - No Appeal
Mike S's Avatar
Woody - that is WHY you use an isolator. The isolator allows current to flow one way only - from the alternator diode input to each battery. One battery is hooked to the regular engine loads, the other to the winch. They both charge from the same source, but do not share power. IMHO, this way better than a manual switch, since it is always available, and you can't forget to switch it back to regular configuration.
The Hell Roaoring product is very good, and they will help you to design the circuit.
Mike S
'96 FZJ80, locked, Hanna sliders, ARB bumper, Kaymar rear with spare carrier, 45 gallon Longranger aux fuel tank, OBA, Hella 4000's, OME lift, 285/75/R16 Revos & AutoHome Maggiolina rooftop tent, etc.
Custom Cruiser trailer with OverLand tent
www.AutoHomeUS.com
TLCA Member #14874
Mike S is offline   Reply With Quote
Old 09-17-04, 05:22 AM   #14
Admin
woody's Avatar
TLCA# 1548
Been on Hellroarings site, looks like good stuff....guess it's shoppin time!
Old 09-17-04, 10:35 AM   #15
skyshark186's Avatar
Does look like a worthy product. Just curious, besides winches and stereos what are you guys running that requires this kind of power. My 40 is still in the stone age, though its gaining tech fast.
skyshark186 is offline   Reply With Quote
Old 09-17-04, 02:18 PM   #16
Junk's Avatar
Shark186 - I have all my aux stuff running off the 2nd batt. Leaves the main full charged for starting. I've run things off it like the ARB fridge, all the accessories including microwave, toaster oven, weed trimmer, power tools, backed up to the house and ran the fridge off of it while upgrading the service to 200 amp in the house etc. 1 battery is not an option for me.
Old 09-23-04, 07:25 AM   #17
Is is edible?
badkarma's Avatar
speaking of dual battery systems...
I just finished the install on my 69 fj40 using the Painless 250AMP kit. Contrary to what people have said (in this instance) it actually was painless.
I still have the stock alt. putting out 45-55 amps any suggestions/comments on upgrading this? Should I upgrade? How do I test to see what the alt. really is putting out? Yes, I have read the threads with some people still running stock alts. with dual batts. with no problem.
My plan is to add a pair of driving lights, stereo and CB. And of course it's gotta run the laptop for GPS.
badkarma is offline   Reply With Quote
Old 09-25-04, 04:13 PM   #18
mobi-arc's Avatar
Before you go out and purchase a battery isolation device, we've designed a battery isolator that is more efficient than anything we've seen on the market. It's currently being ramped-up for production. Why should you consider our product over other products? Let's quickly look at ways to isolate batteries.
One way is a constant duty solenoid. Easy to use. Cheap. Guaranteed to have diminshing performance over time as the contacts arc every time it's switched.
Second way is a solid state device which commonly uses diodes called Schottkey diodes. There are no moving parts, which is good, but the diodes are fairly expensive and suffer from a substantial voltage drop across the diode. This voltage drop (i.e. resistance) manifests as heat which in turn has to be dissipated. This is why most isolators you see come in the form of a giant 3 pound aluminum extruded heat sink. They may annodize it a cool color, but it's not there 'cause it's pretty. It's there so the damn thing doesn't overheat. And as we all know, heat is what ultimately kills products.
Now, what's different about the isolator that we developed at MOBI-ARC?
For starters, its small (approx 4"x1"x1") which makes it easy to install.
There's no aluminum extruded heat sink....because we don't need one! It dissipates so little heat it's ridiculous.
It's scalable, meaning that you can stack isolator modules together and isolate from 100a to 1000a.
Some isolators are specifically designed to work with a particular alternator's regulator. Why? Because they drop so much voltage through the isolator that the regulator needs to be jumpered to the other side of the isolator for it to function properly. Not ours! The voltage drop is so miniscule that jumping the regulator isn't necessary.
We've simply designed the perverbial better mousetrap and we look forward to bringing it to market. Any comments or questions, feel free to e-mail us at info@mobi-arc.com
'98 Land Cruiser, MOBI-ARC Underhood Welder Equipped, POWER-GATE Dual Battery Isolator, Slee Dual Battery Tray, Long Ranger 180L Aux. Fuel Tank, TJM Nudge-bar, dual Hella HID's, BFG AT 295/75/R16's
www.perfectswitch.com
mobi-arc is offline   Reply With Quote
Old 09-29-04, 08:23 AM   #19
ian
ian's Avatar
mobi-arc:
Nice cheerleading session. Now give us some details on the tech behind your "superior" unit.
'69 FJ40. In pieces.
'94 FZJ80 98K. Stock.
ian is offline   Reply With Quote
Old 09-29-04, 12:32 PM   #20
mobi-arc's Avatar
Nice cheerleading
Originally Posted by ian
mobi-arc:
70 millivolts at 200a. That's dramitically better than any solenoid, any solid-state isolator, any switch on the market. This is with no aluminum extruded fins, no chillers, no moving air; and it can fit in the palm of your hand. The product has a "patent pending" status and we look forward getting it to market. Should it be convenient, we'll be introducing and displaying some pre-production units at the Off-Road Expo in Pomona, CA next week.
Scott
info@mobi-arc.com
Old 09-29-04, 01:05 PM   #21
Admin
woody's Avatar
TLCA# 1548
keep us posted, doing the solenoid switch for now (200amp continuous for $35) but may make a change later.
price guess?
Old 09-29-04, 07:08 PM   #22
mobi-arc's Avatar
Brian,
We're still deciding where to make the performance splits and pricing splits. The assembly is a little more involved so clearly we won't be at the $35 solenoid level. We just got the PCB's back and like any new product, our initial run will be quite small. And like most things, the more the we make, the more the price will come down. In order to be competitive, at the 250a capacity, we'll be shy of the $200 mark. I'll keep you posted.
Old 09-30-04, 12:24 AM   #23
the shed guy's Avatar
Ive been using a pirahna unit which just sh1t itself, which was rated at 150 amp, but I run a silver contact solonoid which gets its power from the winch motor, so if the winch motor is being used, it triggers the solonoid to join the batteries, taking the load away from the piranha unit.
I have the winch hooked to the main battery, because it charges faster, and I run all my acc from the aux battery, inc low beam headlights, so I can work/set up camp in the dark, with the engine off, if need be.
I use the oddysey 1000cca batteries.
I also have a 3rd battery pack, which plugs into the acc plug, so it stops charging when the ign is off, which is a gell cell 42 ah battery, for running the camp lights, the camp chair massager and heater, the invertor for the elec blanket in the swag etc.
Darren M.
"There's a gigantic grey area between good moral behaviour and outright felonious activities. I call that the Weasel Zone and it's where most of life happens." -Scott Adams
02 KZJ95TDI 285 MTRs ARB Secondairs Engel Shower GPS
the shed guy is offline   Reply With Quote
Old 09-30-04, 01:15 PM   #24
mobi-arc's Avatar
These are all really good questions and clearly, in order to make an educated decision, it's important to understand WHY the MOBI-ISOLATOR is different and/or better than Pirahna, Hellroaring, Sure Poower, solenoids, etc... What I suggest is this: call us and ask to speak to the engineering department. Engineering will explain what all those specs on those other websites mean, explain how the MOBI unit will perform, then an informed and educated decision can be made. 858-720-1339
Here's a quick pic of our prototype just so you can get an idea of the scale. The packaging and graphics are still a moving target. www.mobi-arc.com/comp.jpg
Old 09-30-04, 01:23 PM   #25
Admin
woody's Avatar
TLCA# 1548
hey, that blue thing above your unit looks WAY nicer than my rusted POS one....lol
Old 09-30-04, 01:42 PM   #26
Beowulf's Avatar
>> What I suggest is this: <<
And what I respectfully suggest is that you get someone from your engineering department to post answers to our questions here on IH8MUD where you chose to introduce the product.
It makes no sense for each of us that are interested to individually call to get questions answered then each of us would have our interpretation of those answers and each of us would decide what, if anything, we would post back to this forum.
-B-
Old 09-30-04, 02:51 PM   #27
mobi-arc's Avatar
Smile
-B-
Beowulf, the product is not ready for distribution yet. We haven't put together a spec sheet or a brochure....we haven't even finalized the packaging.
However much we'd like to have engineers spending their time on the internet, their time is better spent doing what they do best. Were not trying to be flip, we're trying to run a business and complete new products. When we've got more specs and pics available, we'll post them. We're happy to address questions over the phone.
