9K2LC
I'm in the process of obtaining parts for a shower system for my 100 and was planning on ordering a classic series shurflo pump.
It was to be mounted inside the vehicle, most likely inside one of the AO drawers side compartment. Although I knew the answer but I asked Shurflo about mounting their pump externally and they said that the pump is not sealed so it cannot get wet and shouldn't be installed near heat sources. I'm now trying to find a similar spec - with pressure cutoff - sealed pump that can be mounted externally, be water proof, etc. That way it would be closer to the water tank and installation and servicing of the pump would be much easier. I looked at flojet pumps but they seem to be similar to shurflo. Does anyone know of a source for such pumps? |
dude iam in kuwait now!!!!!!! waiting to go home
kick ass __________________ - Iam home now from the SUCK !!!!!!! VJ60 700R4 33's 203 doubler, ARB's 4.56, OME and just a awesome truck!!!!!!!!!! - RUBITHON 2008 TESTED GOD ASKED FOR 10 DAYS TO CREATE EARTH, CHUCK NORRIS GAVE HIM 7.. |
#4 | |
Yeah...like a dual filler neck off a 100 over there so I can get along on my aux tank project Ok...back to your thread siglo: I am also looking for same type of pump to mount under the hood. I want high pressure with low volume...tried one of the little Flojets but by the time I started to get the pressure high enough to be able to have low flow at the shower head it cut off. It was only good to 30psi...so now to try it with one of the Shurflo units that will push 65psi...but the form factor is pretty darn big for my 100 engine bay. May have to mount it in the trailer...
__________________ Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM |
9K2LC
45psi is not enough you think? 65psi means you're looking at the shurflo extreme series which is significantly larger that the classic series..
since my air filter is the smaller cyclonic type, I think I might be able to fit a bigger pump in the engine bay.. My second battery is behind the right headlight.. my air compressor and aux fuse box are installed where slee's second battery tray usually goes.. I'd probably relocate the aux fuse block and remove the air compressor all together to fit the pump.. I would still be concerned with the shurflo pump not handling the heat and dust since it is not sealed.. If I can find a pump with the same specs as the extreme series shurflo, sealed and water/dust proof, it would be perfect to mount underneath the vehicle beside the water tank.. I'm still trying to find something like that.. If you manage to find something that works well let me know
Dude! He like live there and shit. All the time.
__________________ 2000 UZJ100 - OME - sold Currently looking for the right FJ60 TLCA #14734 Calamaridog
#7 | |
I couldn't find a water pump that is 100% sealed from the elements. __________________ Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM Last edited by spressomon; 04-13-08 at 11:31 AM. |
Check out Marine (as in boating, not, USMC) go to West Marine: Home Page They might have a sealed pump used for wash down or etc on boats..
__________________ 1984 FJ60, 102k miles, OME med/heavy, BFG/AT 33X10.5 on Stock Wheels, ARB Bullbar W/Warn 8274, Tuffy Console. |
Refinance | Car Finance | McDonalds | Mortgage Calculator | Credit Cards UK |
