Anybody have any experience with tent heaters? Currently looking at the smaller Mr. Heater and the Coleman Procat . I probably won't run it all night, just before bed before getting out of the sleeping bag in the morning. Tent is around a 10 x 10, maybe a little bigger.
__________________ Cameron Mosley '85 FJ60 - Daily Driver UNDER THE BRIDGE TOUR 2008 Last edited by werd; 08-20-08 at 11:08 AM. Reason: Sorry my gammar isn't that good... |
Mr Heater work great
used it in 10 x10 canvas tent hook it up to big silinder you dont want to put bottle on at 4am |
CottonLand Cruisers
Used my Big Buddy Mr. Heater out at Katemcy TX during the LSLC Round-up recently. I have found that if it's too cold the heater won't work on Med or High. Works great on low. It even has a blower on it. It was 21 degrees one night and it would only work on low. We had 3 heaters among everyone camping with us and all had the same problem. We are checking with the company on this problem. Seems funny to me that the heater wouldn't work because it was too cold?????
Later, __________________ Jeff CottonLand Cruisers Whitetrash of the Elwood Chapter 78 FJ40 TLCA #3164 USAF - POL 1987 - ? http://www.youtube.com/watch?v=lxVEqVDUuJE "What da ya say there Hoss Fly? We done messed around and got drunk down here!" |
Could be drawing propane from the tank to quickly. As the temperature gets low propane is less willing to vaporize. Try it with a 20lbs tank. You'll need a converter hose to hook them up together.
__________________ Sanity is for wimps. |
Were you using just a single small tank? I'd seen reviews where they ice up on the higher settings when using one small tank, which ends up shutting it down.
#6 | |
What you talkin bout?
We used a Coleman Powercat last spring. The forced air heated our 10X10 tent up in a couple of minutes.
I wouldn't run any propane heater all night inside a tent. Just for a few minutes to take the chill off while you get in/out of bed. The Zodi is the exception to this. It's combustion chamber is outside the tent. A heat exchanger heats the air and blower circulates it in and out of the tent. The bad news is if the battery goes dead they self destruct. With no air flow the heat exchanger melts down. __________________ Dan Johnson Quote:
FJ40, A couple of thingamajigs and a deally bob, fully integrated whatzits, dash board Hula girl (pending spousal approval.) And a pair of Pink Panties, now with a doohicky in the front. Rust never sleeps. .- -.. --... -. .-- |
The mr buddy portable is fine in a tent. It has a low oxygen sensor on it. It advertised that it works in a car or house. The tent is not air tight enough to cause a problem.
__________________ Thad Brown/ Rogersville Mo 84 FJ 60 / SROR sides and rear / beauty marks from RR, FN, & LSCR / Free bumper from GCC and Locker from LSCR/ 07 FJ 08 Tundra Rocket ship Green Country Cruisers Flat Nasty Event info Flat Nasty on-line registration-click here
As far as the Round-up went, that was beach weather. Why did you need it on high?
![]() __________________ Thad Brown/ Rogersville Mo 84 FJ 60 / SROR sides and rear / beauty marks from RR, FN, & LSCR / Free bumper from GCC and Locker from LSCR/ 07 FJ 08 Tundra Rocket ship Green Country Cruisers Flat Nasty Event info Flat Nasty on-line registration-click here
Rekut your such a man's man ;-)) . My nuts were cold. (my thermometer said 17 degrees.....) I have the Mr. Heater and it was awesome and NEVER went out...except until the propane went out. I was so impressed with it I wrote the company just last week. I highly recommend the Mr. Heater.
airlaird |
#10 |
Just curious how you vent them? or is it not as big of a deal with the lower BTU?
Thanks __________________ Enjoy Brian Passey KE7TGH wasatchcruisers 71 FJ40 Stinky 94 FZJ80 Ryoku Ryu Cruiser ring's anyone Stuff I've done... My 40 work in progress |
#11 |
wal-mart has the coleman eventcat tent heater on clearance for $20
__________________ Georgia Cruisers Upstate Cruisers http://www.upstatecruisers.net/ TLCA 6149 86 FJ60 - first and RIP 95 FZJ 80 - second RIP 97 LX 450 - Current locked, ARB, 850J's Front and 863's rear, slee drop blocks, 315's, and M12000, Devo sliders, Iron Pig rear bumper, skid on garge floor 98 LX 470 - wifes |
#12 |
Thanks everyone, looks like I'm leaning toward the small Mr. Heater. Seems like the best compromise on size/weight and heat output. We'll see how it works.
#13 |
Keeping it Weird
Info, was that at your local Wallyworld or online as well?
__________________ David Gonzalez ------------------- "Penny" Bronze 2000 100-series 33" BFG A/T's, storage drawers, OME Heavy Lift Austin, TX david.gonzalez@gmail.com Lone Star Land Cruisers |
#14 |
It was at my local.
#15 |
Keeping it Weird
Nevermind....seems to get poor reviews. I'll probably look at the Mr. Buddy heater.
#16 |
check them for the mr.buddy also....they had them but they were gone before I had a chance to snag one.
#17 |
The Mr Heater "Buddy" heaters do not require venting. They are part of this latest generation of "safe" heaters that have a built in oxygen depletion sensor. It shuts off when it senses low O2 levels (or is it high CO levels?).
I have used one of these for camping both in my tent at Cruise Moab and in my FJ45 Wagon. Worked great in my tent. I have run them on both the large cylinders (put outside with extension hose leading in) and the 1lb er's. I have a 4lber that I will use in the tent after using a Hazmat leak detector. I am not as concerned about venting fumes in the tent. In the Cruiser they heat so well on the low setting in the small space that I wake up in the middle of the night and shut it off, then wake later and turn it back on. More concern about the sensor working right in the Cruiser. Only issues I see are that it (mine) does not have a tip over shutoff switch. I worry that due to wind or other factors it may tip over and I wil be so tired from wheelin that I may not wake up in time.. I always secure it on top of a non flammable, metal container. Other issue is that it is designed to work directly off a cylinder without a regulator. It has a small orifice to limit the amount of fuel it can take. This can also clog, they make filters available to put inline, I suggest anyone using one of these heaters to get one. ![]() Hope this helps! ![]() Eric |
#18 | |
Thanks! ![]() __________________ Enjoy Brian Passey KE7TGH wasatchcruisers 71 FJ40 Stinky 94 FZJ80 Ryoku Ryu Cruiser ring's anyone Stuff I've done... My 40 work in progress |
#19 |
another vote for the Mr Heater portable buddy
__________________ '75 FJ-40-In pieces on my garage floor. -Buildup thread here '07 Titanium FJC- wife's ride My statement to my wife: "All of the accumulated crap in my shop will be really useful if I find a use for it." "You may all go to Hell and I will go to Texas"- Davy Crockett |
#20 |
I just looked into this 3 weeks ago for Roundup. It was COLD. I bought the Procat. I was looking at teh Buddy to. The first night, it got really cold- airlaird said 17. The heater did help a little, but not much. The second night got to 35 and it worked fine. We have good sleeping bags too.
Once I got back from Roundup, I decided to return it. I am going to replace it with the Buddy. __________________ Treasurer of Austin Lone Star Land Cruisers TLCA # 15006 Looking for a Cruiser..... Relics: 1991 BTJ80, 1985 BJ70, 1997 FZJ80, 1981 FJ40, 1978 FJ40 |
#21 |
The mr heater (buddy) is right on.
I used it for the first time in the cruiser and it was great. The only problem was dealing with the other guys that were cold all nite ![]() ken __________________ 97 with thingy's and dodads ![]() Now with added geek KI6JEO
#22 |
I ruin surprises.
They're on sale at the Amazon link at the top for $59.99 (Regular price $79.99 and List $129.95).
That sounds like a pretty sweet deal. __________________ JDM ToysNEW!!! R/C FJ40 OEM foglights and HID's JDM LC60/62 Goodies LC70 Goodies JDM LC80 Goodies JDM LC100 Goodies |
#23 |
UC VP & Cook
I have a big buddy and love that thing. I wouldn't reccomend it for a small tent. It goes throught little cylinders really fast. Bought a 4lb with hose and it is great. The little fan works great.
__________________ Marshall UC VP & Token Club Cook Greenville, SC Big Gay 2f Build The Great Cruiser Part Links Thread Buying a Land Cruiser Guide "On second thought, let's go to Chat. It is a great place." 73 Fj55 Big Ugly 76 FJ40 ROTW 75 FJ55 My Build 93 FZJ80 stock everything and staying that way. |
