Go Back   IH8MUD™ Forums > General Tech Forums > Camping - Gear - Recovery
Old 01-09-08, 09:18 PM   #1
Anybody using the Tabor 12k (warn value line)?
I have an opportunity to pick up a brand new Tabor 12k for less then half the cost of the M12000. I get that the quality of the Tabor will be lower then that of the M12 but the question is how much?
Have any of you used/seen one in action?
Will it bolt directly to the ARB without any additional mods?
Am I crazy for even considering it?
MomentRider is offline   Reply With Quote
Old 01-10-08, 08:54 PM   #2
98 SNAKE EATER's Avatar
Here's the reply I got from Warn when I requested a performance spec sheet on the Tabor line
Rick
The Tabor is designed to complete with entry level winches coming in from overseas, no performance specs are available
Tom Ewing
Customer Service
I'll be going with an M8K and a few snatch blocks....
98 SNAKE EATER is offline   Reply With Quote
Old 01-10-08, 09:49 PM   #3
mobi-arc's Avatar
No performance specs available....frick'n shady.
'98 Land Cruiser, MOBI-ARC Underhood Welder Equipped, POWER-GATE Dual Battery Isolator, Slee Dual Battery Tray, Long Ranger 180L Aux. Fuel Tank, TJM Nudge-bar, dual Hella HID's, BFG AT 295/75/R16's
www.perfectswitch.com
mobi-arc is offline   Reply With Quote
Old 01-10-08, 09:59 PM   #4
KI6MIE
Cruiserdrew's Avatar
TLCA# 11734
I personally know a Warn technical guy, and asked him about the Tabor winches. They are aimed and designed to compete with the T-Max's, the Costcos and the Milemarkers of the winch world. Which means they will work, but are basically disposable off-shore knockoffs.
I agree that an M8000 is a screaming deal around $500, and the Tabor is a less desirable option at about the same price. I think I'd avoid the Tabor 12000 unless finances are really tight. A used Warn would be better, or just go with a smaller model and a snatch block.
Andrew
1971 FJ-40 Rubicon tested
1976 FJ40 RIP
1989 FJ-62 117k-son's driver for now.
1997 FZJ-80 Factory sub-tank, and other tricks
Old 01-11-08, 04:55 AM   #5
a85toy's Avatar
TLCA# 13718
I have a Tabor 9000, and it was made in the USA. I have only used it a half dozen times with NO problems at all. I don't have the spec sheet but when I bought it I did see a spec sheet. Very same as a Warn M8000.
a85toy is offline   Reply With Quote
Old 01-11-08, 06:20 AM   #6
Originally Posted by Cruiserdrew View Post
I agree that an M8000 is a screaming deal around $500.
Where did you find it for $500?
Lowest I've seen was $555 shipped (winch depot)
Old 01-11-08, 06:42 AM   #7
missipboy's Avatar
i've got the tabor 12000 and have had no problems. only used a few times, though. for what it's worth, i would feel better if i had a real warn sitting there, but this winch fell in my lap.
missipboy is offline   Reply With Quote
Old 01-12-08, 06:26 AM   #8
They were $500 at winch depot a few weeks ago. looks like they raised prices as a couple models i was looking are more money now.
The 9.5xp went up 10% as well.
-2000 UZJ100
-1997 LX450
sprocket3 is online now   Reply With Quote
Old 01-13-08, 06:11 PM   #9
mobi-arc's Avatar
Okay...that's fair, but I'd want to know exactly where compromises were made to shave cost.....and without performance specs, tought to make an educated decision.
Old 01-13-08, 10:58 PM   #10
Anyone know what the difference is between the two M8000's listed on winch depot's site?
WAR26502 ($555.69)
WAR20910 ($718.94)
Other than the fairlead, they look identical, but that's quite a price difference for just a fairlead
Old 01-18-08, 01:40 PM   #11
mkaustin's Avatar
I'll wager that the 20910 has 80' of synthetic rope. That's the typical difference from Warn. 80' w/ hawse fairlead is typically synthetic rope. While 100' roller fairlead is typically wire rope.
Michael R_
89 FJ62 - mostly stock w/ an H42 - ARB Bull Bar, OME shackles and Pins, OEM++ front springs, and a few dents
85 Mini-4x4 - stock - need to do rings
The opinions expressed here aren't even mine.
Don't take life too seriously son, you don't come out of it alive anyway. - Red Skelton
mkaustin is online now   Reply With Quote
Old 01-28-08, 11:27 AM   #12
Yeah, I kinda figured that...
Even though it says "wire rope", having a hawse fairlead it would only make sense to have a synthetic rope...
Anyhoo, the price just went down to $516 shipped @ WD
Now I'm kicking myself cause I just spent my winch money on a new sub amp and custom enclosure
Hopefully the price will stay low (or go even lower) over the next few weeks until I can afford it again
Old 01-28-08, 11:32 AM   #13
You want to do what...?
e9999's Avatar
I did call Warn to ask about the Tabors and I got a non-answer answer...
I would imagine that they are not that different from the regular Warns, simply because it'd be too expensive to make 2 different lines if (if!) they use the same manufacturer for both. Maybe cut down on a bearing or bushing here and there? Conceivably, the difference could be only marketing, less warranty, and less profit on one than on the other.
An inspection and/or some pics may reveal more.
'97: 88K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!)
'03: 99K, the better half's...
DD and souped up DR650
Old 01-28-08, 11:36 AM   #14
KI6MIE
TLCA# 11734
Just curious Eric-have you ever looked at them? They are completely different. The Tabors are on a smaller frame, and do not look like the same winch at all.
Tabor = Warns China line, to compete with the cheap end of the market.
Warn = Made in USA (at least for now). Totally different winch.
Andrew
1976 FJ40 RIP
Old 01-28-08, 01:54 PM   #15
Bad Homburger
FJ40-GARAGE's Avatar
TLCA# 6289
One of the main manufacturers in China is the Goldenwinch Corp
The sell them even in Europe under different names like Horn Winch, Duke Winch or whatever........
Not neccesarily cheap crap but nothing i would like to depend on in a trophy or a hairy situation that requires 100% safety.
You get what you pay......sponsoring labour in china included.
Peter.
www.FJ40-GARAGE.de
If the going gets Rough.....the Tough getīs going.....
TLCA # 6289 1977 / FJ40, 2F, 35x12.5, 3" Lift, Warn 9000i, ARB rear, &&&
EuroCruisers the headquarters for all european TOYOTA 4x4 friends!
FJ40-GARAGE is offline   Reply With Quote
Old 01-28-08, 02:15 PM   #16
e9999's Avatar
No, I haven't looked at them. I should have done that. Somehow I thought they did look similar. My mistake. Well, as I said, my argument only works if it's the same manufacturer. If they are completely different, who knows?
Are we even sure that the regular ones are really fully made in the US? Some of the Warn stuff is not.
Đ2000-2008 by IH8MUD™ - ALL RIGHTS RESERVED
Read Manga Online | Car Credit | Credit Cards | Car Loan | Student Loan Consolidation
