Go Back   IH8MUD™ Forums > General Tech Forums > Camping - Gear - Recovery
LinkBack (6) Thread Tools Display Modes
Old 01-07-08, 06:39 AM   #31
flintknapper's Avatar
flintknapper is an unknown quantity at this point
Done!
All that is needed now…is to mount it on the vehicle and spool on the new cable.
Total parts: (New cable, Lower housing kit, Motor shaft bearing, Main shaft seal, paint) just under $75.00
I doubt I will be around to get another 24 years of service out of this winch, but someone will.
I paid about $460.00 for this winch….(bought new in 1983), I’ll bet it would fetch more than $600.00 today. Not a bad investment.
Flintknapper:
'97 Land Cruiser, Moonglow Pearl
Chocolate Lab (Kota), I miss you.
ΜOΛΩΝ ΛΑΒΕ (come and take them)
flintknapper is offline   Reply With Quote
Old 01-07-08, 07:11 AM   #32
Originally Posted by Blue77FJ40 View Post
WOW. Incredible job, both on the rebuild and the detailed article. Thanks!
Any thoughts on drilling the main-shaft end to accept a bolt? There have been tales of the brake assembly flying off along with the ball bearings when the split ring lets go. Gigglepin sells a kit for this, already machined.
I looked into that mod. and agree its a good safety measure for those who use this winch to extreme ends (in terms of braking and shock loading the cam gears).
I haven't babied mine any...and it has never come off in 24 yrs.
If ever a cir-clip has come off, it was because it was improperly installed at the factory or by someone else. If you look at it closely, it is slightly rounded on one side...but flat on the other. The flat side needs to face away from the brake unit. It's a pretty stout piece.
Drilling and tapping the main-shaft can be done, but be forewarned: That shaft is harder than the 5th grade was for Mike Tyson. So, have a few drill bits handy and a really good tap.
Seriously, if I were that concerned about the brake unit coming apart, I'd rig up a aux. "disc brake" on one end like the Brit's do with their competition 8274's.
I do like Gigglepin's improved friction material (larger size), so I might order those someday.
My next mod. will be the 6hp motor swap.
Flintknapper:
Old 01-07-08, 04:06 PM   #33
Back in service
Back on the Bronco.
Ready for some more abuse.
Flintknapper:
Old 01-07-08, 04:33 PM   #34
Deny's Avatar
TLCA# 11568
Deny is on a distinguished road
Nice Job!
I actually recently had my brake blow out the side, wrecking the needle bearing and the plate. I was thinking of rebuilding, but picked up a cheap winch that I could swap my good parts to (like my 24V motor). Anyway, any thoughts on what could cause that, like say no grease in the needle bearing? Also do you have any pics on the brake re-build? do you need speacial tools for that, or is it fairly strait forward?
Cheers,
Deny
Diesels Rule
81 BJ42
Check out my endless fix up progress at http://forum.ih8mud.com/showthread.php?t=152995
Deny is offline   Reply With Quote
Old 01-07-08, 06:32 PM   #35
Originally Posted by Deny View Post
Nice Job!
Cheers,
Deny
If you're talking about it blowing out the "motor" side....then yes....the needle bearing would have to of seized. I put a liberal amount of grease in mine and also put twice the recommended amount of oil in the case.
All parts depend upon "splash" lubrication and that can only happen after the lube has "climbed" the main gear.
As for the brake, no special tools are required. I used a pair of long nosed vice grips to compress the spring and hold the two halves together as one unit before installing it back on the shaft. But, it can be done a number of different ways.
I did not document the rebuild...as it has already been covered by another person. But I can walk you through it (very simple) if decide to do yours.
I have pics. of the upper end that I didn't post if anyone needs to see them. My main objective here was to "add" to the information already available, so others might benefit from it.
I went a little deeper into my winch disassembly than some folks do, I also added a few mods. (fill and drain plugs, zerk fittings on drum support, slotted solenoid cover) and wanted to share those as well.
Flintknapper:
Old 01-08-08, 12:46 PM   #36
SPM_Ltd
WARN 8274 rebuild
I have a WARN 8274 rebuild that I have started to rebuild, however, I am having difficulty getting the brake assembly disassembled.
Is there a trick to getting the brake assembly apart?
Did you remove the brake axle from the housing (i.e., replacing the shaft seal)?
Any guidance/suggestions would be appreciated.
Steve
SPM_Ltd is offline   Reply With Quote
Old 01-08-08, 04:55 PM   #37
Steve
The brake assembly should come apart pretty easily UNLESS you have a build up of rust on the shaft or around the two key-stocks.
Remove the cir-clip, use a piece of emery cloth to smooth and clean up the main-shaft. Spray the "key stocks" as best you can with penetrating oil.
DO NOT use anything to “pry” the brake assembly off (using the case as a support).
If necessary… a small 2 jaw puller behind the rear brake disc should make easy work of it. The brake system is spring loaded...so it’s already trying to come apart.
Warning: As the "outer" brake disc moves off the shaft you will have 21 (count 'em) steel balls fall out. Do not lose any of these.
As the brake assembly comes apart, note the relationship of the parts to one another (very simple and self explanatory).
I did remove the Brake/Main-shaft on my winch in order to get to the main-gear in the bottom of the case. But, as long the needle bearing is in good shape and your current main-shaft seal is not leaking (not likely it would be) then there is no reason to disassemble/remove the main-shaft. The brake system comes off independently, just so you’ll know.
This is the needle bearing that the end of the main-shaft fits into (motor side of case)
And…this is the bronze bushing and seal (brake side of case).
You can see it all reassembled (just as it would be when you take your brake off) if you go back to post #24 where I “bench tested”.
Let me know if you have other questions or need additional pics.
Flint
Flintknapper:
Old 01-09-08, 11:06 AM   #38
REZARF's Avatar
TLCA# 13041
REZARF is an unknown quantity at this point
Bravo!
Great write up man!
Drew
Drew F.
Rising Sun 4x4 Club
Old 01-09-08, 11:34 AM   #39
Originally Posted by REZARF View Post
Bravo!
Great write up man!
Drew
Happy to help.
Lord knows...the guys here have helped me out in the past.
Flintknapper:
Old 01-10-08, 12:44 PM   #40
SPM_Ltd
WARN 8274 rebuild
Thanks for your comments.
I have not been able to remove the brake system from the shaft (apparently it is really stuck).
I was considering removing the brake system/shaft as an assembly and them removing the brake system from the shaft away from the Aluminum housing.
Does this seem possible?
When I attempted to remove the brake system/shaft as an assembly, it seemed to be butting up some resistance - my guess it is the shaft seal that is pressed into the housing.
The internal gear does not appear to be mechanically attached to the shaft (only attached thru the splines).
Perhaps I have being to careful and just need to apply a bit more force.
Appreciate your comments.
Steve
Old 01-10-08, 02:34 PM   #41
Steve
Steve...have you tried using a puller yet. The brakes disc's should come off without too much trouble.
You can certainly remove the brake system and shaft as one unit. That way you could put it in a press if needed...but it really shouldn't require that much force.
To remove the shaft you'll need to split the case, pull up on the lock-plate and use a brass drift punch to drive out the shaft. The splined cam gear that fits on the brake-shaft is larger than the bronze bushing in the case. So, in essence you are driving the lip seal and bronze bushing out along with the shaft and cam.
The whole assembly will then come out.
I'll post some pics in a bit.
Flintknapper:
Old 01-10-08, 03:23 PM   #42
This shows the lower end with brake-shaft, intermediate gear and main-gear.
Both the drum AND brake-shaft are held in place by the lock-plate.
Lock-Plate in down (locked) position:
In order to remove the either the drum or brake-shaft, you must pull up on it as pictured.
Lock-Plate in up (unlocked) position:
If you intend to remove the brake-shaft, use a brass drift punch against this surface only:
You will be driving out the lip seal, the bronze bushing and the brake-shaft all at one time.
IMO, there needs to be compelling reason to do this.
Flintknapper:
Old 01-18-08, 09:27 AM   #43
mkaustin's Avatar
mkaustin has a little shameless behaviour in the past
Flintknapper,
Great writeup! Just what I was looking for.
I just picked up an 8274 that is either 1978 or 1988 (Date Code: BF8, S/N: 79xxx). I'm going to be tearing it down like you did yours and I know that I will need new cables from the solenoids to the motor. The wire in my cables look good (no corrosion), but the insulation has been weathered quite badly.
Are the cables that you mentioned in your parts list, the cables from the solenoids to the motor?
I'd be interested in some pictures of the upper half. On mine the clutch knob shaft is frozen in place. Will removing the four screws around the clutch plate allow me to remove the clutch shaft and assembly?
Did you try to check the bearings in your motor? Do you know if he motor is rebuildable? (bearings/bushngs)
Last question. What did you use to paint the drum? I'm probably going to use wire rope on it at first, and I'd like to use something that will help prevent the wire from starting new rust points.
Thanks for any info.
Michael R_
89 FJ62 - mostly stock w/ an H42 - ARB Bull Bar, OME shackles and Pins, OEM++ front springs, and a few dents
85 Mini-4x4 - stock - need to do rings
The opinions expressed here aren't even mine.
Don't take life too seriously son, you don't come out of it alive anyway. - Red Skelton
mkaustin is offline   Reply With Quote
Old 01-19-08, 08:01 AM   #44
No, the cable I mentioned was simply new wire rope for the spool, however.. the electrical cables are still avialable. There are three, you will need one of each.
5-1/2".....Part # 6007
6-1/2".....Part # 6008
7-1/2".....Part # 6009
The cover for the wire at the motor end is called a "nipple" and is Part # 2090.
Here is a source for parts. (These folks are not fast, so be patient.)
Warn Authorized Parts and Service Center: warnserviceparts.com
I'll see what pics I have available that I haven't already posted and place them here a little latter. Yes, removing the four screws will allow you to remove the clutch assembly. It has sealant around it, so you'll need to slowly pry it off. The shaft itself gets rusty... making it difficult to operate. Once cleaned and lubed...they work fine.
Be very careful not to drop the motor shaft gear into the bottom of the case (if you're not planning on splitting the case).
The bearing for the motor shaft is a 6203RS (double sealed), it's available anywhere, don't special order.
The bushing in the motor cap is replaceable, but most likely will be fine. Brushes are available, you'll just need to check yours for length. I wouldn't rebuild this motor if it needed anything other than brushes and bearings. You can buy a new motor off e-bay for about $100.00
Be advised, there are two types of motor shafts. One is splined and the other has a keyed shaft. If you buy a motor.. it will need to match your motor shaft gear (splined or keyed), OR...you can buy a splined motor shaft gear and mate it to a newer style motor. Also, there are other motors that will interchange (up to 6hp).
The black portion is Rustoleum Black Appliance Epoxy. I have used this for years on different items exposed to the weather. It is very tough. Wire rope and high tension loads...of course..will eventually take their toll, so nothing you use will be permanent.
Happy to help.
Flintknapper:
Old 01-19-08, 07:24 PM   #45
Clutch mechanism assembled:
Clutch in “engaged” position:
Clutch in “disengaged” position:
Flintknapper:
Old 01-21-08, 02:06 PM   #46
MrWwindow is on a distinguished road
Big Thanks!
I've been watching this thread with great anticipation.
I've got a used 8274 on it's way, it looks to be in great shape. But Flinknapper made it an easy decision even if it is'nt I'll know what to do to get back to new.
Thanks Flintknapper for the write up.
James
87 Fj60 196k and counting
Dobinson Lift, 33X10.5 BFG MT
ARB Front Bumper, Kaymar w/tire carrier
Sagebrush pinstripping
Waiting in the garage
Warn 8274
Conferr rack
Hf55
4:56's
Powertrax F/R
Axel and knuckle rebuild
MrWwindow is offline   Reply With Quote
Old 01-21-08, 04:35 PM   #47
James
I can assure you...there is nothing "scary" about refurbishing one of these.
If I can do it, anyone can.
Don't hesitate to ask questions, I am happy to help.
Flint.
Flintknapper:
Old 01-21-08, 05:52 PM   #48
KI6MIE
Cruiserdrew's Avatar
TLCA# 11734
Cruiserdrew is an unknown quantity at this point
Outstanding thread Flint. I wish you had done this before I redid mine 2 years ago. It would have saved me a ton of effort/frustration and calls to Poser and Warn. Congrats.
Andrew
1971 FJ-40 Rubicon tested
1976 FJ40 RIP
1997 FZJ-80 Factory sub-tank, and other tricks
Cruiserdrew is online now   Reply With Quote
Old 01-22-08, 08:28 AM   #49
4x4CPOSEADOG's Avatar
4x4CPOSEADOG is on a distinguished road
This is one of the great rebuilding thread. You did an awesome job! I admire your skills, talent, attention to detail, and your time.
Originally posted by flintknapper
All of this for aesthetics of course. It serves NO purpose in terms of function.
My friend, yes it does serves a purpose and this is to prevent or minimize the corrosion on the mechanical parts that you just sandblasted, primed and painted. So it is not just for aesthetics look but for corrosion control too
Noel
97 LX450 (lockers retro 50%), CDL, Pin 7, HIRs, Cup Holder, 100 pads, George's LEDs, OEM grab bar, sidemarkers, ARB winch bar, PIAA 520, 295/75R16 NTG, Kaymar Deluxe with tire carrier, Slee speedo gear, ARB fridge, Xantrex 1750 inverter. Awaiting installation: OEM subtank, OME850J/863, slee SS brake lines, 3* blue bushings/caster plates, BIC 95300B dual batts, silicone PHH/FHH, ....
94 4Runner, OEM 4.88 gear, V6 3VZE
04 Taco Ext Cab SR5 V6 TRD RR DIFF LOCK, groucho sliders
4x4CPOSEADOG is offline   Reply With Quote
Old 01-22-08, 10:51 AM   #50
Exploded Diagrams and part #'s
http://www.pirate4x4.com/tech/billav...4_and_down.pdf
http://www.pirate4x4.com/tech/billav...816_and_up.pdf
Flintknapper:
Old 01-23-08, 11:11 AM   #51
mkaustin's Avatar
Flintknapper,
One last question.
Where did you get the stickers/decals to put back on the winch?
Those make it look like a brand new winch.
Michael R_
Old 01-23-08, 02:01 PM   #52
Originally Posted by mkaustin View Post
Flintknapper,
One last question.
Call or email “Stephanie” at Warn customer service and request a decal packet for an older model 8274. Warn Industries - Contact Us
The red “W” for the front of the solenoid cover is no longer available, but you can put the one from the packet on top of the cover as I did.
This is what you should receive after contacting her several more times to remind her (but be nice):
Flintknapper:
Old 01-23-08, 08:03 PM   #53
4xJunkie
Originally Posted by flintknappe
