Go Back   IH8MUD™ Forums > General Tech Forums > Camping - Gear - Recovery
Old 01-03-08, 10:17 AM   #1
Rocky_LC's Avatar
TLCA# 14977
Recovery Component Failures (Pix?)
Can people please describe (illustrate with pictures) recovery equipment failures they have observed?
I realize winching is a hazardous business, and I am interested in trying to get a look at the most common failure points to ensure I avoid any obvious "weak points".
For example, there's posts here about $15 Ebay 20,000 lb snatch blocks. Are these prone to failure? Misaligned Clevises (Remeber the thread about the washers?)? Bumpers Pulled Off? Or are the tow straps / cables / cable splices the common failure points.
By the way, is a winch cable with a locking hook better than one without? Is there a reason most of the winch hooks I see don't have a lock tab on them?
Thanks -
Rocky
PS. I just got a Warn 8274, and am checking it out / getting my gear together. I don't want to waste money on poor equipment that would need to be replaced.
74 FJ-40 - A work in progress....
Rocky_LC is offline   Reply With Quote
Old 01-03-08, 03:53 PM   #2
miked's Avatar
I'm trying to find that picture of a hole blown through a head rest by a winch hook...
miked is offline   Reply With Quote
Old 01-03-08, 08:36 PM   #3
jonheld's Avatar
TLCA# 5980
Rocky,
Statements like that should be applauded. Too many folks take this stuff lightly IMO. The one thing I can really recommend is to purchase quality products from reliable sources. I like recoverygear.com. They are not the cheapest but they do sell top quality webbing and other items. Also, don't cut corners on this stuff. All my webbing is 3". I would never consider going with 2". Recovery situations can get ugly in the blink of an eye. There's no such thing as too much and total overkill is just about right. I like the Amsteel synthetic winch line. I also have a MasterPull "super yanker" in 1"x20'. That's great for giving others a gentle tug as it eliminates shock load.
Jon Held
1991 FJ80 "Lumbering White Rhino"
Times Square, New York, USA
TLCA# 5980
http://gclcny.com/jh/
Buy your FJ80 FSM here:
http://gclcny.com/jh/fsm.html
jonheld is offline   Reply With Quote
Old 01-04-08, 09:42 AM   #4
Jon's comments are right on. Buy the right gear - spend the money.
I believe the weak points in winching (and off-roading) are mainly between the ears as people just don't look for the hazards and don't think about the what-ifs.
Here is a nice write-up on recovery techniques and safe winching.
Winch Tech - The Basic Guide to Winching Techniques by Warn
lcruzrlvr is offline   Reply With Quote
Old 01-08-08, 05:20 PM   #5
BHMCruiser's Avatar
Good advice all. Don't screw with a winch unless you know what you are doing and you take all the proper precautions, and then you are even a little more careful than that.
BHMCruiser is offline   Reply With Quote
Old 01-11-08, 05:46 PM   #6
When using hooks without retainers, I use either a cable zip tie, or a bit of fencing wire to hold the recovery gear in position on the hook.
I don't always have an option as to what I'm using (as a lot of the time I'm in work vehicles), but when I'm buying/installing gear I always choose hooks with the retainer, or my preference is for (rated) rings to attache shackles etc to.
Sean
BiG BoB is offline   Reply With Quote
Old 01-13-08, 09:42 PM   #7
impervious to subtlety
RockDoc's Avatar
TLCA# 18148
Nothing really to add. I'm in the same boat, new 8274, want to make sure I am using proper equipment and techniques. Picked up an ARB pulley block, should check my tree savers for rating. Have some rated D-rings. I've been keeping a list of ratings - working or failure load - in my glove box so I can verify things BEFORE tempting fate in the field, probably a good idea...
Thread subscribed.
[ ][ ]=TOYOTA=[ ][ ]
4 eyes > 2 eyes
Want better headlights?
Semi-professional David Cross impersonator
RockDoc is offline   Reply With Quote
Old 01-14-08, 06:05 PM   #8
High Desert's Avatar
Not a failure, but a problem, used my 8274 to pull a huge Juniper off a fence, rigged the snatch block and pulled off several layers of cable before winching, In that It was a short pull I did not leave the engine running, pulled up the emergency brake left it in neutral, dragged the tree off no big deal, (that thing is a pulling SOB!) however, as the resistance increased when the tree branches dug in the last few feet, the rig started dragging toward the load...Kinda wondering what people do on snow when no anchor is handy and your pulling another rig out?
I would think wrapping the chains (not putting them on, using them as a chock and use my "logging" chain as a chock too) around the base of the tires would help or anchoring to another rig if there is a third rig? what else?
1984 FJ60, 102k miles, OME med/heavy,
BFG/MT 33X9.50 on Stock Wheels, ARB Bullbar W/Warn 8274, Tuffy Console.
High Desert is offline   Reply With Quote
Old 01-15-08, 06:30 AM   #9
flintknapper's Avatar
Anchoring to another rig would of course be the easiest solution, sans that...here is what I use:
http://forum.ih8mud.com/camping-gear...follow-up.html
Flintknapper:
'97 Land Cruiser, Moonglow Pearl
Chocolate Lab (Kota), I miss you.
ΜOΛΩΝ ΛΑΒΕ (come and take them)
flintknapper is offline   Reply With Quote
Old 01-15-08, 09:50 AM   #10
FlintKnapper,
Good tool I saw that post when it was running..course i forgotaboutit when I asked my question..
I could bury it in the 6 foot snow banks that the two lane roads are sandwhiched between...yeah that't the ticket..Hell I could carry a old steel wheel and bury that...chain up to it and maybe hold the rig long enough to winch away...
Being a desert rat, I need to build one of those deals anyway..thanks HD
Old 01-15-08, 10:45 AM   #11
missipboy's Avatar
i think one of the most overlooked safety issues of winching is the recoil associated with a broken cable. draping some weight over the cable to absorb the energy is a must. the synthetic line negates this, but many of us still use the cable. if the line is pinched during a recovery, it could leave a weak point in the line and you may not know it until the next time you pull someone out and it pops and comes flying back towards your highdollar windshield.
missipboy is offline   Reply With Quote
Old 01-16-08, 06:42 PM   #12
jts560's Avatar
Or your highdollar face.
1988 FJ62
jts560 is online now   Reply With Quote
Old 01-25-08, 11:37 AM   #13
Hello,
While not a failure, I have a copy of a military manual, Vehicle Recovery and Field Expedients. There is a seller that makes copies and sells them:
Portrayal Press - Military Vehicle Manual Listings
Scroll down to the misc section. The book has more than just recovery, lots of field fixes to get you going.
Hola
eric
Otterav is offline   Reply With Quote
Old 01-25-08, 01:22 PM   #14
Atoyot1031's Avatar
TLCA# 18402
Thanks -
Rocky
I saw those too, and based on the fact that a decent snatch block is at least $60 anywhere else, I gotta believe it's garbage, and definitely not worth risking your life over!
Atoyot1031 is offline   Reply With Quote
Car Insurance | Secured Loans | Homeowner Loans | Online Advertising | Loans
