Go Back   IH8MUD™ Forums > General Tech Forums > Camping - Gear - Recovery
Old 11-02-07, 07:26 PM   #1
Home Made Roof Top Tent
Anybody out here made their own roof top tent? Got any pics?
I am in the process (bought the steel and have cut out the floor pieces) of building one. Basically think of the Maggiolina Columbus except that instead of a fiberglass shell, it has a steel frame, a trampoline floor and a "soft" top. For travel there will be a lower and upper travel cover that keep everything pretty clean. The upper one will double as the rain fly.
Size wise it will hold 2 adults. it measures about 8' by about 4'6" or so. It should come in a little over 100 pounds (I am using 14 guage 1"x2" rectangular steel tube for the base and 16 guage 3/4" square for the upper).
I will post some pics tomorrow so you can get an idea of the basic shape.
So far I am about $120 into it for the tube.
Later
Bakes
Bakes5 is offline   Reply With Quote
Old 11-02-07, 09:44 PM   #2
philos1's Avatar
sounds interesting, what are you using for "canvas?"
and of course, pics...
1987 fj60, stuff, and some other stuff. i call her "tootsie roll"- http://forum.ih8mud.com/showthread.p...t=tootsie+roll
defender of the good, mo-fessional drunk, total art-fag, and all around nice guy...
philos1 is online now   Reply With Quote
Old 11-03-07, 08:35 AM   #3
RHINO's Avatar
yeah man, i have put some ideas to paper but nothing is being built yet. my current and favorite idea is to make a top that lifts straight up about 3 ft, then simply attach a nice canvas all the way around it with windows and a door.
75 BDJ55 soy cruiser
01 TACO got salsa ?
Old 11-03-07, 08:51 AM   #4
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Not trying to bash you at all but why don't you buy a used second generation Mobassa. It seems monthly they pop up here for $300.00.
My Tow Rig = http://forum.ih8mud.com/hardcore-cor...g-tow-rig.html
D'Animal is online now   Reply With Quote
Old 11-03-07, 10:12 AM   #5
Not really a big fan of the Mombassa style tents. I want something that doubles as a roof top carrier for all things sleeping.
I Will be using differrent stuff for the "canvas." For the floor I may actually use standard trampoline fabric. For the inner tent portion I will probably use standard, lightweight ripstop tent material with a lot of netting (trying to avoid the coffin feeling). For the rainfly/travel covers I will use something a fairly heavy duty and waterproof of course. I am still looking
Anyways, here is the basic idea
Here is a shot of the "trampoline" frame. I am thinking about putting a bar right down the middle to reduce the sag a little
Now I just need to build the frame for the cover. It will open up clamshell style via gas struts.
Later
Bakes
Old 11-05-07, 05:43 PM   #6
philos1's Avatar
I'd suggest using a rigid floor to avoid sinking everyone to the middle. I'm sure it could be done without too much weight, also it would help add some more structure to the tent.
My .02
Old 11-05-07, 06:39 PM   #7
RHINO's Avatar
because some of us like to build stuff,,,,,,, its not always about money, spent or saved.
go for it bakes5,,,
01 TACO got salsa ?
Old 11-08-07, 08:29 AM   #8
schaney's Avatar
Doing a "columbus" style tent has been on my idea pile for a while. Here are a few thoughts.
The trampoline floor idea save a lot of weight, a Oasis II is half the weight of a Mombasa. Challenge is everyone will roll to the middle, in an Oasis II there is a center bar that makes it effectively two separate beds. I can take some pictures of one if you'd like.
My idea for pitching it would be a single bow, 4'-5' tall that pivots about 15 degrees past straight up and down, so it can be tensioned with a couple of straps.
Trianglar windows are also easier to make than rounded ones. If you have a flap over the top corner of them, you can also use them for tent peak ventilation.
Good luck with the project, look forward to pictures.
schaney is offline   Reply With Quote
Old 11-08-07, 09:11 AM   #9
You want to do what...?
e9999's Avatar
glad you are trying this out, good for you!
off the top of my head: the frame looks a bit thin to withstand the pull of a couple of people sleeping in there?
'97: 88K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!)
'03: 99K, the better half's...
DD and souped up DR650
Old 11-12-07, 03:54 PM   #10
Been out for a bit. Something about work and 4 kids.
I am going to put a bar right down the middle. That will keep everyone on their own side, eliminate the sag in the middle and add an additional bit of structure to keep it from flexing. It is made with 14 guage 1x2 steel. I've tried it with my weight (~225) on a single tube with a 5' span and there is basically no flex. There will be 1.5 tubes per person so I I think the tubes will be strong enough. I'll post some more pics in a bit
Later
Bakes
Old 11-13-07, 10:40 PM   #11
Wile E Coyote's Avatar
Very interested. I like DIY.
="Are you gonna sit there on that friggin computer all day or what?"
The desert dwellin, roadrunner chasin, soooper-genius!
'90 FJ 62, '08 Scion head unit, chopped quarters and rockers, bedlined exterior, and mostly stock. My soft wheeler and DD.
'85 Dodge Ramcharger a little built, and a little beat. My hard wheeler.
Wile E Coyote is offline   Reply With Quote
Old 01-08-08, 09:18 AM   #12
sseaman's Avatar
bakes, can you repost you pics they arent showing up
91 FJ80 318k, spare tire mod, custom roof rack----SOLD
98 4runner 136k
98 Avalon 138k
sseaman is offline   Reply With Quote
Old 04-16-08, 07:36 PM   #13
flozano's Avatar
What happen with this project?
I'm planning to build a tent like mombasa.
1985 TLC FJ60, 2F TBI
1984 TLC FJ40 TSL 16/38.5, 4.88, Full Floater Rear, Powertrax No-Slip, ARB Front.
flozano is offline   Reply With Quote
Old 04-16-08, 10:12 PM   #14
oh no you didn't
Skillet's Avatar
TLCA# 16078
Looks like Bakes got baked and lost interest...
1993 FZJ80
1973 FJ40
oh no you didn't
"...mud is a hotbed of leftist chat/activity." - swank
Skillet is online now   Reply With Quote
Personal Loans | Loans | Property in India | Modded Xbox | Xecuter 3 Mod Chip
