Go Back   IH8MUD™ Forums > General Tech Forums > Camping - Gear - Recovery
Old 01-24-04, 02:50 PM   #1
How to jack up a cruiser
Got a FJ55 and looking for a floor jack that will adequately lift the truck. I got a 6 ton bottle jack but even with the extensions all the way out it only lifted the truck up 1/2 inch. So I need a good floor jack but how big and how much money do I need to spend. Do I need at least a 3 ton to lift the 55? Where do I jack it up, I was thinking on the pumpkin and then using jack stands?
Any thought and your experiences are appreciated. Thanks for helping me out, someday I might stop asking questions and give a few answers. All I can offer now is free prostate exams for anyone over the age of 40 Any takers
NO JUNK! Tell your mama she doesn't have a prostate!
drohweder is offline   Reply With Quote
Old 01-24-04, 03:08 PM   #2
I use one similar to the attached. Jack up the 40 from either the pumpkin or the u-bolt skid plate and put jack stands under it.
73lndcrsr is offline   Reply With Quote
Old 01-24-04, 09:33 PM   #3
REZARF's Avatar
TLCA# 13041
drohweder-
I know you said a floor jack, but a high lift may help you get some lift under the truck so you could slide some jack stands under your rig. Cheap and fast, but it might not be what you are wanting.
Drew <><
Old 01-25-04, 02:59 AM   #4
IDave's Avatar
TLCA# 13705
I have a Sears 3 1/2 ton heavy duty floor jack. Invaluable. Don't forget the jack stands: they go on the axle between the pumpkin and the ubolts, and you need at least 2. Floor jack will slide, and you are too expensive to waste under your 55. My billing clerk's minister, a long-time amateur mechanic who should have known better, died that way this past summer.
IDave is online now   Reply With Quote
Old 01-25-04, 08:08 AM   #5
KI6MIE
Cruiserdrew's Avatar
TLCA# 11734
You need a floor jack. A nice big one with a good lift-18-24 inches. I have the 3.5 ton from Kragen that despite being made in China is decent. A previous one from Harbor Freight was junk. I just saw in the paper this morning that the Kragen one is for sale for $79. There are excellent ones US made around but they cost somewhere around $400. The Kragen 3.5 ton works great and for $79 you can throw it out when it stops working, but mine has been good for a couple of years. You also need big jack stands-get the 6 ton ones for working on the cruiser.
I don't reccomend using the high lift for shop work. One of my friends did this, jacking on the slider, it slipped and bashed in the passenger door on his 80.
A set of 4 wheel chocks is useful too.
Old 01-26-04, 07:29 AM   #6
alia176's Avatar
TLCA# 15941
Re:How to jack up a cruiser
If you're near a Costco, they happen to have a real nice one for less than $100. It's long and wide, providing good stablity when you're maxed out on the range of the jack. Also, it has a very low profile under the cradle, great for lifting cars made these days!
Ali
alia176 is offline   Reply With Quote
Old 01-27-04, 08:56 AM   #7
ParadiseCruiser's Avatar
I also have one of those Chinese made "PowerBuilt" 3.5-ton floor jacks that Kragen sells. The first one blew a seal on the first day, but they cheerfully took it back and gave me a new one.
The second one has performed flawlessly for nearly two years now lifting my 5500# Cruiser. I also use a pair of 6-ton stands, and a backup pair of 4-ton stands. No such thing as overkill here.
Cheers, R -
ParadiseCruiser is offline   Reply With Quote
Old 01-27-04, 11:03 AM   #8
On the Golf Course!
Brentbba's Avatar
TLCA# 13420
Ok, stupid question, flame suit on - what are you referring to with a 'pumpkin'? Legit question from someone just learning. Pics for stupid auditor types are helpful (comment for Cdan).
Brentbba is offline   Reply With Quote
Old 01-27-04, 11:55 AM   #9
fsusteve's Avatar
TLCA# 8714
[quote author=Brentbba link=board=14;threadid=10582;start=msg95996#msg959 96 date=1075226627]
[/quote]
Differential (think ring and pinion).
fsusteve is online now   Reply With Quote
Old 01-27-04, 05:23 PM   #10
IDave's Avatar
TLCA# 13705
That big Pumpkin-shaped growth in the middle of each axle. Don't worry, I have trouble with the techno-speak sometimes, too.
Old 01-28-04, 10:25 AM   #11
On the Golf Course!
Brentbba's Avatar
TLCA# 13420
Reason I asked is that on the front axle on my '94, the 'pumpkin' is NOT directly in the center. It's a little over towards the PS of the truck. Jacking up the DS and placing a jack stand is no problem on the axle itself. Jacking up the PS is a different story. If I put the jack on the flat portion of the axle, there is no room left to place the cradle of a jack stand. If I lift the PS from the differential housing as this thread initially asked about, then I've got room to place a jack stand.
I don't think the initial question regarding the saftey of putting the jack under the 'pumpkin' has really been answered. Is it safe?
Old 01-28-04, 11:45 AM   #12
KI6MIE
TLCA# 11734
Totally safe to jack up the axle under the pumpkin. If you jack just towards the DS from the differential, you can lift both sides more or less equally. I put the jack stands under the axle right at the base of the knuckle "ball" and have never had a problem. I usually lower the jack, cruiser on the stands, then shake the truck as hard as I can, then remove the wheels and tires. If I go under the truck on the stands, I put a second set under the frame and stack up wheels/tires under the truck as well. But then, I'm paranoid.
Old 01-28-04, 02:13 PM   #13
picked up a Craftsman 3 ton floor jack for $49! Works like a charm. I am using 6 ton jack stands uder the axels and then taking down the jack. Wife is scared to death so I am being extra careful . Perhaps I should get a couple of extra jacks stands and wear my titanium, steel reinforced exo-skeleton for the windy days when the garage door is open.
Seriously, is it ok to jack up the middle of the axel since the dif is off-set.
Old 01-28-04, 02:14 PM   #14
Old 01-28-04, 04:02 PM   #15
Oh...Durka Durka Durka.
Poser's Avatar
TLCA# 1856
You will be alright with jacking the truck up there.
Old 01-28-04, 04:04 PM   #16
Poser's Avatar
TLCA# 1856
Just had to! :P
-Steve
Old 01-28-04, 09:51 PM   #17
IDave's Avatar
TLCA# 13705
You can say that again.
Again.
I have always jacked each side independently, but as long as you have both the tires on, I think it makes sense to do it all at once.
Old 01-29-04, 02:13 PM   #18
On the Golf Course!
Brentbba's Avatar
TLCA# 13420
Thx Guys! Have a Craftsman 3 1/2 ton jack and a pair of 3 1/2 ton jack stands. Sounds like I'm paranoid as well. The 3 ton models at Sears and elsewhere just didn't look like they had enough beef to me.
Old 01-30-04, 11:13 PM   #19
cruiser_guy's Avatar
TLCA# 16387
I had the whole truck up on four 3 ton jack stands in the driveway when I put the lift on. One jackstand at full extension per corner under the frame. It worked fine. My main caution would be to make SURE that all legs of the jack stand are bearing. Sometimes it will tend to "walk" when jecking it up and you'll need to reposition the stands once the truck is in the air. That happens usually when you're using more than one jackstand.
Old 02-01-04, 07:18 PM   #20
Ramblin Wreck
CruisinGA's Avatar
I use 2 3 ton jacks and 2 sets of 4 ton stands-all borrowed (yes I'm a cheap bastard).
I also have a 10 foot 6x6 cut into 1 foot lengths- I stack them underneath framerails when doing a lot of work, or stack under jack stands when added height is needed.
CruisinGA is online now   Reply With Quote
Old 02-03-04, 01:55 PM   #21
Thanks for your help guys. Now tune in to the tech section as I tackle the bearings and brakes! Hope I win those on V-day Thanks again!
Old 02-03-04, 06:41 PM   #22
Poser's Avatar
TLCA# 1856
This works for me....
http://www.mindcrater.com/Gallery_30...1-30-03-11.htm
-Steve
Old 02-06-04, 07:22 PM   #23
Hey poser. YOU SUCK!!!
Envy is a bitch! Here I was happy to have a floor jack and you make me feel soooo little
Old 02-06-04, 07:27 PM   #24
Poser's Avatar
TLCA# 1856
[quote author=drohweder link=board=14;threadid=10582;start=msg100688#msg10 0688 date=1076120549]
[/quote]
Not the intent, just being cute...
Old 02-06-04, 07:48 PM   #25
Oh man, your a sensitive one! I was totally kinding myself. Guess I need for smiley faces to get across the sarcasm. Nice hoist.
Old 02-06-04, 09:58 PM   #26
Poser's Avatar
TLCA# 1856
No worries Dan, I understood what you were saying...
