06-19-09, 09:53 PM
#31 (permalink)
Good luck  (in the positive type of comment  ).
07-07-09, 11:30 PM
#32 (permalink)
07-10-09, 04:33 PM
#33 (permalink)
Well I got the pan off, what a pain in the Ass. It took awhile to get the pan separated from the block. I had to take a box knife and cut into the gasket until I got one side done. After that I took my bottle jack and applied pressure to the bottom of the pan and pried the other side off. It was a very frustrating job, anytime I felt the need to start cussing and screaming I would just walk away for 10 to 15 minutes. Anyways it is off, time to start cleaning and removing the old gasket, it is coming off pretty easy. Getting closer to both Mcgrew and baby, well see how the rest of the weekend goes.
Josh
07-10-09, 04:44 PM
#34 (permalink)
well hey man if you need a hand with that stuff lemmy know I have personaly done 4 wheelers ive had, but that was on the interior and also under the truck... and that 3mm stuff works great as but then get another coat i cant remember the name and it is amazing!
07-11-09, 10:24 PM
#35 (permalink)
Well it all got put back together, well see if anything shows up in the next day or two. It went together pretty smooth. I really thought putting back together was going to be ruff. I read some pages in tech about seals not fitting right and what not. I guess I'll see if I got it right. Anyways I hope to get the rest finished before Mcgrew, if I don't I'll live.
07-21-09, 11:36 AM
#36 (permalink)
Finished both rear output shaft and pinon seal in about hours time. It went very smooth. Anyways just an update.
Josh
09-17-09, 09:45 PM
#37 (permalink)
I know it is after Mcgrew but I got permission from the wife to work on the rear bumper tomorrow. So I get to drill out frame rivets, not looking forward to it. I'm sure I'll walk away cussing and screaming a few times tomorrow.
Josh
09-18-09, 03:33 PM
#38 (permalink)
Josh
Good Luck! and remember that everything works better with beer!
ND
07 Titanium Metallic FJ 6SPD, 3in RevTek, BFG A/T KO 285's on Stock 17's, PIAA 520 smr's and PIAA Xtreme White Plus. TG Sliders, Kustom Exhaust w/ Magnaflow Muff... And as usual MORE TO COME as I restock the FJ fund!!!
TLCA # 19745
09-18-09, 10:57 PM
#39 (permalink)
no cussing or screaming. I drilled them all out and used my air chisel to finish the deal. Got the bumper mounted up, (about dropped it on my toes, not sure how it missed) I'm going to make some changes so its not up for good. I got to find some parts for the spindle. New bearings and races, I'm going to try Napa and see, I don't want to have to order a whole new spindle assembly just to replace some parts. Ordered a new latch tonight. Once this all gets fixed then off to get powder coated.
09-19-09, 12:24 AM
#40 (permalink)
You did something wrong then.
I am not a fan of powder coating, myself.
One tiny break in the powder coat, and rust will spread underneath it. You will never be able to tell until it starts flaking off.
Just my two cents.
