TLCA.org
Go Back   IH8MUD.com > TLCAForum.com > Toyota Land Cruiser Association Forum > North American Clubhouses - West Region > OR/CA- Jefferson State Cruisers
Old 03-20-09, 05:36 PM   #1 (permalink)
Heron's Avatar
Location: On pleasant creek north of Rogue River Oregon.
TLCA# 18938
FJ40 Dizzy Testing
Any of you Buds know the procedure and specs. for testing the ignition exciter for a 1978 to 1987 Land Cruiser?
I have power to the coil and ignition module but no spark at the plugs.
Any suggestions?
Al
Heron is offline   Reply With Quote
Old 03-21-09, 09:41 PM   #2 (permalink)
Oh nevermind......
2ndGenToyotaFan's Avatar
TLCA# 13872
If you have my kind of luck... Check your timing gears.... Other than that, I can't help ya Al...
Aside from the ignition trouble, how's the big bad FI install coming?
Old 03-22-09, 10:03 AM   #3 (permalink)
Kief's Avatar
Hmmmmm. It's been a while. make sure your ground is grounded. I would recommend posting in the 60's section or 40 section.. If I remember right there are several wires there and its hard to tell which goes where! .
Kief is offline   Reply With Quote
Old 03-22-09, 01:17 PM   #4 (permalink)
Heron's Avatar
TLCA# 18938
Thanks for the input, I will re post in the 40's section.
Well for the most part the FI install is done, there are a few lose ends like finding a VSS and looming up the wiring harness, but at this point it should run, but no spark.
I have a few more things I can check but it is starting to look like a new ignition exciter is required.
I will keep you posted
Al
Old 03-23-09, 12:40 PM   #5 (permalink)
gnob's Avatar
TLCA# 15307
is this a new problem, or part of the swap.
i have found most times, at least on minis, the pickup in the dist goes south.
gnob is offline   Reply With Quote
Old 03-23-09, 10:59 PM   #6 (permalink)
Heron's Avatar
TLCA# 18938
Yes this is a new problem resulting from my installation of the TBI system.
I made some progress today, was unable to find a wire from the ignition switch that remained hot during cranking.
Installed a temporary fix to provide power to the ignition during cranking. There is now a potent blue spark at the plugs.
I do not quite understand the ignition / starting circuit but a little more research may sort it all out.
Is it possible that a jumper from the starter energising circuit powered the ignition during start up.
The good news is, the pickup is working for now at least.
Thanks for the input gnob.
Al
Old 03-24-09, 03:54 PM   #7 (permalink)
Heron's Avatar
TLCA# 18938
It's Alive!
Once provided with 12 volts when cranking It fired right up. Set the timing, Wow it never ran that smooth since I owned it, well I have not had it out of the driveway yet because of the later model booster and master cylinder installation. (have to bleed the system)
I expect there will be issues with the E Prom that will need some re programing.
Stay tuned for more trauma.
Al
Old 03-24-09, 04:13 PM   #8 (permalink)
Ebag333's Avatar
TLCA# 18864
Good news!
'97 LX450
'96 LX450
315 General Grabber AT2, OME Medium, 1" body lift, 30 mm spacers, Pro Comp ES9000 12.5"/14" travel shocks, belly skid plate, grey wire mod.
(A subsiderary of OR/CA TACO)
(Disclaimer: Anything said above is merely my world view. I am not a doctor/lawyer/mechanic/<insert profession here>, nor do I play one on TV. I did not stay at a Holiday Inn Express last night. I take the Hipocritic Oath very seriously.)
Ebag333 is offline   Reply With Quote
Old 03-24-09, 07:01 PM   #9 (permalink)
Kief's Avatar
Al, as thorough as you have been on your build I think you ought to put together a write up for Toyota Trails and if not published put it here on mud.
Old 03-24-09, 08:55 PM   #10 (permalink)
retrofive's Avatar
TLCA# 19315
Nice Work!!
'94 LC |OME 851+1"/860/N73/N74E/SD24|SLEE BLUES|SLEE SLIDERS|CDL/7PIN|285/75/16|YAK RACKS
JEFFERSON STATE CRUISERS
http://forum.ih8mud.com/ca-jefferson-state-cruisers/
retrofive is offline   Reply With Quote
Old 03-24-09, 11:19 PM   #11 (permalink)
Ebag333's Avatar
TLCA# 18864
x2
You've done so much work on your truck, it deserves a write up.
'97 LX450
'96 LX450
Old 03-25-09, 08:12 PM   #12 (permalink)
Oh nevermind......
TLCA# 13872
Now we just have to see if it will stay running while on it's roof.... Well done Al! Glad to hear it was simple!
Old 03-26-09, 11:02 PM   #13 (permalink)
#1 Super Guy
TOY350's Avatar
TLCA# 4939
Way to go Al, can't wait to see it.
GARETT
67 FJ40
- 350 - SM420 - SOA - ALL PRO HY-STEER - 4.88 - ARB F/R - 30 SPLINE LONGS - 35 MTR's - WARN XD9000
95 FZJ80 - 3 LOCK - LONGS - 4.88 - 315 KM2's - OME J & L - LT CC & MAF MOD - ARB/WARN XD9000 - HANNA SLIDERS - 4X4 LABS REAR - SLEE SKIDS & MORE - ECLIPSE NAV - RUBICON TESTED!
JSC FORUM
Originally Posted by cruiserdan View Post
That particular rock is a screaming bitch and if I had my way I would dynamite the sonofabitch and use the left-over pieces to fill up the hole.
TOY350 is offline   Reply With Quote
CONTACT US AT MEMBERSHIP@TLCA.ORG
