10-27-09, 08:51 AM
need longer than stock 40 series shackles
After the spring over in front even after removing one leaf out of the front spring pack, I am a bit low in the rear due to the taller than normal axle spring plates because of the issues with mounting a 60 series axle under the 40.
So I need to raise my back end maybe an inch or so. Anyone have a pair of shackles collecting dust they want to sell?
10-27-09, 08:56 AM
If you need a inch you woll want to go with a 2 inch longer shacklke
10-27-09, 09:43 AM
yup. that is true. Got some?
10-28-09, 07:54 PM
Dan, Measure what you have and I will check a set I have.
Jerry
CA4WD #11056 www.4x4him.com
Central Valley Crawlers
10-28-09, 08:11 PM
Did you move them out board yet
The Hudyhue Crew...
'77 fj40...
( insert big changes here! ) not on "z"rated tires!
Mostly stock '80 full size j**p cherroke
sua front,soa rear,360 v8,automatic 4wd
open front and rear on Z rated tires...damn!!!!!
member, 4X4HIM & Central Valley Crawlers!
10-28-09, 09:54 PM
No. I need to outboard the front. THe longer shackles are for the rear. I need an 1"-1.50. So total length of shackles needs to be 6 to 7", I could go as much as 8" (stock is about 4).
10-28-09, 10:13 PM
Dan, I have Con Fer 5.25" center to center of holes.
Very heavy duty. Call me, to work out a deal if they will work.
10-28-09, 10:20 PM
OK. call you tomorrow evening if you get this before you log off tonight give me a call seven 07-7 one 9 two
