TLCA HOME : BOARD & BYLAWS : EVENTS: MERCHANDISE : BUSINESSES : PHOTO GALLERY : CLASSIFIEDS
HISTORY : TOYOTA TRAILS : MEMBERSHIP : CLUBS : MISSING VEHICLES : LAND USE : CHAT : LINKS
Go Back   IH8MUD™ Forums > TLCAForum.com > Toyota Land Cruiser Association Forum > Clubhouse Corner > CA- Central Valley Crawlers
Old 06-26-08, 07:47 PM   #1
JimmieT's Avatar
Mounting my winch - curious
Just curious. I've searched the FAQ's and a bunch of threads and can't find a suitable answer. Maybe one of you guys knows.
I've seen winches mounted "feet down", that is, bolted underneath the mounting plate ... and also "feet vertical" where the winch is mounted to the vertical plate or the vertical plane of the bumper.
It seems to me ... ... that "feet vertical" would be the strongest mount. Because the housings, are cast metal, the winching load would be against the winch mounting plate, not the winch housing. In the "feet down" scenario, the winching load is trying to pull the winch housing free of the mounting bolts.
WHAT IS YOUR OPINION?
Big Jim's Dirty Kidz 1970 FJ40 ... mostly stock ... not too fast ... with a little bit of rust ... please send money!
"Things are more like they are now ... then they ever were before!" Dwight D. Eisenhower
JimmieT is offline   Reply With Quote
Old 06-26-08, 11:31 PM   #2
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
I have all of mine in the feet vetical position. They are bolted to heavey rigs and when a heavy rig gets stuck you want the winch bolted properly.
I also have never seen a caasting break in the feet vertical position. I have only seen 4 or 5 in the feet down position brake the casting.
D'Animal is offline   Reply With Quote
Old 06-27-08, 05:02 PM   #3
Hottrod81's Avatar
TLCA# 18127
I have mine in the feet down position and have never had a problem. I winched a lifted quad cab 2007 Chevy in the snow last winter and held up fine.
www.centralvalleycrawlers.org
My 4Runner Build
Originally Posted by Toyrunner87 View Post
I treated that hood like Ike treated Tina and it still won't budge.
Hottrod81 is offline   Reply With Quote
Old 06-27-08, 09:48 PM   #4
JimmieT's Avatar
Looks we have a tie! Anybody care to be the tie-breaker?
Actually, I had a "brainstorm" at work and decided to call Warn. The Warn guy recommends mounting the M12000 in the "feet vertical" position. He said the casting would "probably" hold at max load if "feet down", but said the unit was designed for "feet vertical", he also said that a "shock load" in the "feet down" position puts HUGE stresses on the casting. Again, we were talking about the M12000. I don't know if that is true for other Warn models, or not.
Thanks for the responses!
Old 06-28-08, 02:57 PM   #5
megolfer's Avatar
mine is bolt down
www.tlca.org
President-Central Valley Crawlers
www.marlincrawler.com
megolfer is offline   Reply With Quote
Old 06-28-08, 09:47 PM   #6
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Dragging someone though snow is a whole lot different than pulling someone out of mud when it is over thier axles.
Old 06-29-08, 11:01 AM   #7
JimmieT's Avatar
I made some "Winch Load" cards for everyone, that I'm gonna pass out at Tuesday's meeting. The "quick reference" cards give you idea of what kind of of weight (load) you are attempting to winch, in different circumstances.
Old 07-01-08, 03:27 PM   #8
JimmieT's Avatar
New bumper for winch
Ok, so I've gone round and round and decided to also build a new bumper to get this winch mounted. I may also attempt the air storage/bumper idea. I "borrowed" some ideas from various posts here on Mud.
The bumper will be ST 2"x5"x1/4" w/ 1/4"thk end plates.
The Shackle mounts will be FB 2"x2"x1-1/4"thk.
The tube bar will be 1-1/4".
The push bars will FB 1-1/4"thk. I can bolt the winch to this flatbar, in the "feet vertical" position.
Here's a sketch:
Old 07-01-08, 04:10 PM   #9
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Nice!
Are you going to sue the bumper that came with it or do you still maybe want to sell it?
Old 07-01-08, 04:15 PM   #10
JimmieT's Avatar
Sell! If you want it, I'll throw it in the truck and take it to the meeting tonight. Call me if so. 661-203-4998
Old 07-20-08, 07:34 PM   #11
JimmieT's Avatar
Finally! My Bumper is completed.
The final product is a little different than the original design ... but fully functional!
Sorry I didn't get any pics of the actual fab process.
Old 07-20-08, 11:25 PM   #12
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Looks Great!
Old 07-21-08, 10:45 AM   #13
Talon84x4's Avatar
TLCA# 18074
Nice job
'84 PU low & slow
Talon84x4 is offline   Reply With Quote
Old 07-21-08, 12:44 PM   #14
JimmieT's Avatar
Thanks guys, glad it meets your approval.
The bumper is ST (square tube) 2x5 x 1/4.
The upper winch mounts are ST2x2 x 1/4.
The recovery points are FB (flatbar) 1-1/4 x 2.
The plate is 3/'16thk (on the ends of the bumper ... around the cable opening ... and at the upper winch mounts.
All the bolt holes, thru the bumper, have a 3/8" thru-pipe welded in ... so the bumper is air-tight ... it can be used as an air tank.
The bumper mounting bolts are Grade 8, cad plated, and the winch mounting bolts are Gr5 (I couldn't find the correct length, so I settled ... just to get the winch mounted).
After fab was completed, I sand-blasted it ($99 tank from Harbor Freight) ... rattle canned grey primer, and then 5 coats of rattle can hammered black, sanded between coats. I s**k at painting, but it came out OK.
Everything was MIG'd except the recovery points, which were TIG'd.
Old 07-21-08, 03:43 PM   #15
H2OBOSS's Avatar
TLCA# 15597
That's purrty nice job.
H2OBOSS is offline   Reply With Quote
Old 07-21-08, 06:30 PM   #16
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Is TIG stronger then MIG?
Old 07-21-08, 07:35 PM   #17
megolfer's Avatar
I believe that tig is stronger. I know race cages and most comp buggies are tig
www.tlca.org
Old 07-21-08, 10:57 PM   #18
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
But they are generally made out of Chrome Molly. From what I understand, you kinda have to Tig Chrome molley.
Old 07-22-08, 12:13 AM   #19
Toyrunner87's Avatar
TLCA# 17575
Very clean looking front end there Jimmy.
Forget Iraq, Lets bomb ExxonMobile!!!
Toyrunner87 is offline   Reply With Quote
Old 07-22-08, 07:39 AM   #20
greenhorn311's Avatar
TLCA# 18096
Tig is much stronger.... Well it's only as strong as the welders skills
greenhorn311 is offline   Reply With Quote
Old 07-22-08, 07:41 AM   #21
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Coming from a Welder, you aught to know.
Old 07-22-08, 04:35 PM   #22
JimmieT's Avatar
Acronym Education
Yeh, TIG is stronger!
TIG stands for :"TOUGH" INERT GAS welding
MIG stands for: "MILD" INERT GAS welding
JUST KIDDING !!!!! I better not not any serious responses on this!
Actually,
TIG stands for: "The inspector General", and we all know how tough he is! And MIG stands for : "MIND IN GUTTER" .... or is it "Made In Germany"?
Old 07-22-08, 10:39 PM   #23
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Well Crap
Now we are gonna start seeing things MIC welded.
MIC = Made in China
Actually,
Old 08-14-08, 11:04 PM   #24
hudyhue's Avatar
looking good jimmie
The Hudyhue Crew...mostly stock '66 fj40....but someday just maybe.......
member, 4X4HIM ....Central Valley Crawlers!
hudyhue is online now   Reply With Quote
Old 08-15-08, 11:52 AM   #25
H2OBOSS's Avatar
TLCA# 15597
HUDY IS ALIVE haven't heard from you in a while.
Old 08-16-08, 02:49 AM   #26
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
X - 2
Old 08-16-08, 10:31 AM   #27
JimmieT's Avatar
Hudy WHO?
Ohhhhhh ... hudyhue!
Been so long ... I can't hardly remember when ...
Old 08-19-08, 08:19 PM   #28
hudyhue's Avatar
yea yea i 've had a tough patch of life with well damn just everything but i am and will be o'tay!!!!
