FS - Isspro Turbocator EGT/Boost Gauge!
Hi guys, thought I'd post this up here first...
New old stock mechanical Isspro Turbocator EGT/Boost gauge. Looks different than the newer ones, 0-40 PSI and 300-1500 Farenheit/150-800 celcius. EGT is on the left of the gauge and boost on the right. Comes with the pyro, bulb and wiring and some fittings for the boost tubing. You will need the lead wire between the gauge and pyro ($30), some tubing for the boost gauge (cheap!) and I believe a weld on bung for the pyro ($6). Everything is available through Isspro in Oregon or Farmtronics in Sask. For the 24v rigs, like mine, the 12v bulb just needs to be swapped for a 24v one.
A new Turbocator is $240 and the probe is $70 so I think this is a pretty sweet deal! I'm going with the Madman set up so I won't be needing this now.
I need $120 for it. It has never been installed!
I can take a pic if someone is interested.
Tokyo Tank  '89 HJ61, 5 speed, Lockers, OME Dakar suspension, 3" straight pipe exhaust off turbo, Madman EMS1, Garmin GPS, currently boosting 14.5psi, winchless ARB bumper
