Hi Guys,
Just a little info about the Toyota kit vs. Basic kit.
The toyota kit has 3 items different from the basic kit, a cast water temp adapter, an inline hose adapter for coolant level, and an extension hose/adapter for the oil pressure switch kit.
Cast Toyota 1HZ Coolant Adapter
Inline coolant level adapter:
Extension Oil Hose
The coolant level adapter is likely useful for any motor, but the cast adapter only works on the 1HZ/1HD-T. So if you don't have that particular motor, you're much cheaper to get the basic kit, and add the coolant level adapter for $12. The extension oil hose is only required with oil pressure kits, and I also have these in stock separately if required for your setup.
The Toyota kit was developed by Madman aimed at popular Toyotas in the african market, which appears to differ from our over here a bit. I'm trying to put together a "local" kit, basically sourcing most of the senders from north American suppliers, and I think this may reduce the prices by about $50 per unit.
cheers, Dave
