Go Back   IH8MUD.com > General Tech Forums > Bicycling
Old 07-25-09, 09:45 AM   #1 (permalink)
Any suggestions for loosening a seat post? Alum inside Steel
I've been rehabing an older Widsor roadbike for a commuter. I ride my MTB 3 days a week to work. It's ~10 miles round trip, and all on pavement so I figured it's time for a commuter, plus I got the bike for free. It's been sitting for a while though. Anyway after new bearings, tires, tubes, and a thorough cleaning it rides pretty decent. I just need a new seat, and to adjust the seat height. The damn thing is stuck pretty bad. It's aluminum post inside a steel frame. I've tried rubber mallet, soaking in PB blaster and had no luck. I can't get any budge at all. I've also put a pipe wrench on it with a 3' cheater bar and I was concerned about twisting the frame. I'm not sure how to get the thing to loosen up.
I don't think I dare try heat. I've applied a little, maybe up to 200F, but I fear that I'll end up ruining the frame as it's brazed together.
Edit: After some quick research I realized how bad of an idea heat really is. Aluminum expands more than steel, so it would more than likely make it tighter.
I thought maybe cutting the seat post and trying to drill out the inside, but it's like 10" down in the frame so I don't see how I could really do a decent job of drilling it out.
Any ideas? I can't figure out anything that won't destroy the frame, which kinda defeats the purpose.
My other thought was to put the road bike wheels on my old mountain bike frame and make something more similar to modern commuters. The front tire fits fine and I think it'd be easy enough to set up the front brakes. The rear frame is too wide by about a full cm maybe more. Also the rear brakes should be easy enough. It's a steel frame so it could be modified if need be. My question there is what to do about the width of the frame drop outs. Should I lace up a wheel with a MTB hub or what?
Any advice is welcome.
Thanks,
Jetboy
jetboy,
75-40
Jetboy is offline   Reply With Quote
Old 07-26-09, 09:06 AM   #2 (permalink)
2mbb's Avatar
TLCA# 6404
Garage
There are some ideas in this article. The ones I like are:
hold the seat post in a vice (bike upside down) and use the bike frame as the lever arm to twist it free
-or-
use ammonia (not penetrating oil) to dissolve the aluminum oxide corrosion.
-or-
cut the seat post off about 1/2" above frame. carefully using a hacksaw blade, make a kerf cuts on the inside of the tube, cutting through the aluminum, but not into the steel. You can then use vice grips to roll the seat tube inside itself to a small diameter.
15 Ways to Unstick a Seatpost
mbb
1985 FJ-60
2mbb is online now   Reply With Quote
Old 07-27-09, 07:58 AM   #3 (permalink)
I think I might end up cutting it out. I've been putting amonia on it for a couple days and had no success. I guess a seat post is cheaper than a frame.
jetboy,
75-40
Old 07-27-09, 09:23 AM   #4 (permalink)
wxm
wxm's Avatar
The amonia does work, it just that you really have to soak the post in for days. Here is what I did to successfully to release an aluminum post from an 20+ year old Miyata road bike.
(1) Remove the saddle, and block the center hole of the seat post. (I used the wine bottle cork.)
(2) Remove the cranks and bottom bracket
(3) Flip the bike up-side-down, and from the bottom bracket, fill up the seat tube with amonia. (You might want to put a catch pan down under to prevent over fill spill.) You want to fill enough amonia so that the join between seat post and seat tube will soak in.
(4) Let it sit for about 5 days to a week. (I only needed for 4 days).
(5) With catch pan in place and bike in up-side-down position, use a pipe wrench to see whether you can loose(twist) the seat post. Note the pipe wrench will likely making permanent mark on the seat post, you might want try something else if you want to save the post. With frame in one hand and pipe wrench in the other, it does give you a great leverage.
(6) If you still can't move the post, leave it and try again in a couple of days.
It worked for me, and hopefully will do for you too.
Good luck.
07 Toyota Sienna XLE
96 LX450 Factory Locked, PHH & FHH, LED cabin lights
95 Nissan Maxima - daily drive
87 Bianchi Strada LX, Fixie Conversion, Miche wheelset - daily ride
07 Felt TK2, 05 Kona Sutra, 04 Bianchi Pista, 03 KHS Flite 800 and...
wxm is offline   Reply With Quote
Old 07-30-09, 11:59 PM   #5 (permalink)
IdahoDoug's Avatar
Don't count out a bike shop. They may charge you $10 but a pro can do wonders with the right tools, etc. Call around and some will demur, others will rise to the challenge. Cash talks if you bring it in to a small shop and simply ask if they can get it for 10 bucks or similar.
DougM
IdahoDoug is offline   Reply With Quote
Old 07-31-09, 09:10 AM   #6 (permalink)
wxm
wxm's Avatar
DougM
I did. Asking my local bike guys was the first thing I tried. (They were usually pretty good), and in my case they took my $10 (or $20 I don't remember exactly) and told me they were unsuccessful a week later. If you want anything done right, you have to do it yourself. - just kidding. But seriously, I don't think they had enough patience to have it setup and soaked in ammonia for a week.
Old 07-31-09, 10:23 AM   #7 (permalink)
I'm leaving on Tuesday for a month so my plan is to hang the frame upside down from an a-frame ladder on the back patio and fill it up with ammonia. Then I'm going to hang something like 50lbs of weights on it a couple inches above the ground and hope it's loose when I get back. The biggest issue for me is where to get Ammonia. I couldn't find any at walmart. Do they still sell it at local grocers?
jetboy,
75-40
Old 08-01-09, 06:07 AM   #8 (permalink)
wxm
wxm's Avatar
Hmmm... I did not think about that. I assume you will find it in grocery stores. I stole it from the under the kitchen sink. PM me if you could not find it I will ask her.
Not sure you want to leave the ammonia in there for a month. It is not neutual, I am not sure it will do any harm to the metal for that long period.
[Edited] PS: Don't forget the pipe wrench.
Old 08-01-09, 06:33 PM   #9 (permalink)
I found some at big lots. It was cheap too. A 2 liter bottle for $1.
jetboy,
75-40
Old 08-02-09, 12:51 AM   #10 (permalink)
KayakPanic's Avatar
another possibility might be to drill a hole through the seatpost (assuming that it will be junked or not needed) and then insert a heavy-duty screw driver into the hole and try to get it to twist one way or another (like how to unscrew a stuck oil filter w/o a filter wrench)
This would also give you a surface to hammer against and get the thing to budge...use something like a framing or a rock hammer, though, that rubber mallet is eating a bunch of your hammering power!
*'80 2WD,murdered by gaper.Rust Into Pieces,'00
*'80 4WD,RIP'02 *'84 4WD,RIP'06
*'84 Tercel4WD.Stolen by City of Durango,and scrapped.Rust Into Pieces,'07
*'77 FJ40,"Panama Red," drove 2 of the tires off of the rims during test drive!RIP'09 *'84 FJ60,"Blue Steel."
KayakPanic is offline   Reply With Quote
Old 08-02-09, 03:47 AM   #11 (permalink)
Butt Ugly Chuck's Avatar
TLCA# use'ta
Don't know if this will work but it's worth a shot....
Get yourself some dry ice and leather gloves. Heat the steel seat tube up with a hair dryer. When it's good and warm apply dry ice (handle with gloves!) to the aluminum seat post. The thermal conductivity of aluminum is so much higher than steel, the post will get VERY cold even inside the warm seat tube (which will cool much more slowly). Simultaneous temperature expansion of the seat tube and contraction of the post might be just enough to pop it out.
Butt
Arcata, CA
7/85 FJ60 277K
For sale - 2f carb
Butt Ugly Chuck is offline   Reply With Quote
Old 08-02-09, 12:12 PM   #12 (permalink)
I can actually get a pretty good twist on it with a pipe wrench. The problem is that the frame is going to tweak if I twist too hard. I did try a 2.5lb sledge as much as I though I could without damaging the bike and didn't get a budge at all. After soaking I might try to hook up a slide hammer and try to hammer it out.
jetboy,
75-40
Old 08-02-09, 12:14 PM   #13 (permalink)
The dry ice might be a good option. Especially because aluminum expands and contracts more than steel. If nothing else it might open up enough gap to let the Ammonia get in there and do it's thing.
jetboy,
75-40
Old 08-02-09, 04:41 PM   #14 (permalink)
KayakPanic's Avatar
"I can actually get a pretty good twist on it with a pipe wrench. The problem is that the frame is going to tweak if I twist too hard. I did try a 2.5lb sledge as much as I though I could without damaging the bike and didn't get a budge at all. After soaking I might try to hook up a slide hammer and try to hammer it out. "
more explanation needed...did you have the pipe wrence attached to the seatpost?
what are you afraid of "tweeking" on the frame?
what were you hitting with the baby sledge? the seat?
i still think that drilling a hole through the seatpost would apply the ammount of force to the right places to get it to budge...it would literally twist right out, assuming that you dont need the seatpost anymore.
yanking on a pipe wrench is a static force. having the screwdriver through the seatpost will apply relatively equal forces to both sides of the seatpost, most likely releasing whatever rust is down there, plus you can go one way and then try the other.
how much do you bench press? (just kidding)
Old 08-02-09, 07:18 PM   #15 (permalink)
I put a pipe wrench on the seat post. It's aluminum so the teeth bite into it pretty easily. I used a 3 foot or so cheater bar. It's a fairly thin steel tube frame. It's Tange tubing if that means anything. Anyway I could put enough force to twist the frame in half if I wanted. It's just not that strong. The tube wouldn't budge. It's very strongly rusted in there. I think if the frame was strong enough the post would be the next failure point.
As for the hammering. I started hitting the old seat till it broke off. Then I hammered right on the head of the tube.
From what I've read Ammonia seems to work best.
I've also got a backup frame if I have to I'll swap over the components.
jetboy,
75-40
Old 08-07-09, 03:09 PM   #16 (permalink)
VanGo's Avatar
TLCA# 18273
Garage
Try what WXM prescribed again method in #4, but use coke as alternative to ammonia. I worked as a tech for several years with custom bikes and this trick never ceased to amaze me. Hang in there.
Van
KB3RWR
1997 FZJ80, 40th, Locked, Slee'd, 285/75/16 BFG AT, 15# Powertank, 100K HG'd, OME 2.5", TaskLEDs, ARB'd, Warn M8000, Master Pull XD, Slee Sliders, Slee Skid Plate, IPF 900XSD, Safari Snorkel, LT MAF, Kenwood DNX5140 GPS/NAV...
"We have the wolf by the ears, and we can neither hold him, nor safely let him go. Justice is in one scale, and self-preservation in the other."
-Thomas Jefferson
2008 Sienna
2006 Trek Fuel EX 7
1989 Trek 1100
1967 M416
VanGo is offline   Reply With Quote
Old 08-14-09, 08:59 AM   #17 (permalink)
BRKLYN1's Avatar
time to bite the bulit annd do it the hard way, that allways works
things you need
1 six pack or a spliff your choice or both
2 Hack saw
cut the seat post off an inch above the top of the seat tube on the frame.
then remove the blade (large tooth 10 tpi. works best) from the hack saw and cut the seat post length wise.
it is a slow process but it works if you have access to a welder and a 3/8 or 1/2 piece of bar you can weld the blade to the bar and make a handle.
breath slow, I have saved many a frame this way
96 LC w OE lockers 111K,295/75/16 BFG AT's, custom bumpers, CDL, PIA's(front and rear),IPO skid plate, XD9000i w Amsteel blue. OME 3" Js & Ls, Slee diy panards,custom rear controle arms, lots of trail scratches. 7 pin mode, painted OEM rims. Metaltech rock sliders, rear sub woofer + amp
BRKLYN1 is offline   Reply With Quote
Old 08-21-09, 09:50 PM   #18 (permalink)
Radd Cruisers's Avatar
I went through this quite a few years ago.
What worked for me was cutting the seat off at the top of the seat or just take off the seat, heating the seat post very hot then spraying some lubricant at the top of the seat tube kinda like souldering a pipe and it sucked into the tube.
Next day I sprayed mor on the tube base where the seat post goes in with some selifane wrapped around it with an rubber band holding it on to make a little catch and let it sit for another day.
Lastly I put the frame on a solid surface and hit the post with a dead blow hammer or lead hammer.
Then used vise grips and worked it out.
Goood luck.
Rob
Come and visit us in Duncan, Vancouver Island, BC
www.raddcruisers.ca
Monday - Friday 08:00 - 17:00
Old 09-04-09, 08:25 AM   #19 (permalink)
wxm
wxm's Avatar
Any progress?
Old 09-05-09, 11:11 AM   #20 (permalink)
patpend2000's Avatar
Pull the bottom bracket, turn the frame upside down and fill the seattube with coke through the bottom bracket. This usually will remove any stuck post
Kelly M
Menlo Park, CA
1991 FJ80 - 225K 3FE power going strong but slowly, diesel conversion in the future?
patpend2000 is offline   Reply With Quote
Old 09-30-09, 08:21 PM   #21 (permalink)
Originally Posted by wxm View Post
Any progress?
Not so far. It's hanging upside down right now in the garage under an a-frame ladder. I took the bottom bracket out and filled it up with ammonia. Then I hung a 5 gallon bucket from the seat post and filled it with water about an inch off the floor. I figured if the post fell it would catch the ammonia in the bucket. It's been there for about 3 weeks.
I think I'm going to give up on the Ammonia. It's not working. I guess I can give coke a try next. Is coke better than pepsi or is there another pop that is better? I'm getting pretty close to just cutting it. I guess I'll give the coke a try for a while and see where it gets me. Then I might buy a little dry ice, and cool it way down, then try some heat on the steel and see if I can get it to break free. Ofter that I guess I'm going to give the hack saw a try.
jetboy,
75-40
Old 09-30-09, 10:05 PM   #22 (permalink)
TLCA# use'ta
Give it a go, but in reverse order. Heat the steel first. The aluminum will cool so much faster. Get the steel hot, then put dry ice on the post. Aluminum conducts heat MUCH faster than steel. The post will get COLD and contract well before the steel has a chance to cool and contract.
Butt
Arcata, CA
7/85 FJ60 277K
For sale - 2f carb
Old 10-01-09, 11:25 AM   #23 (permalink)
You want to do what...?
e9999's Avatar
did you try to hammer the thing IN? should not damage the frame I would think and may be enough to loosen things up. Use a fitting cap.
: '97: 90K, 3xlock, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!). Custom HD roo bar for sale!
: '03: 115K
DDs: Accord, Prius
: souped-up DR650
Old 10-02-09, 07:33 PM   #24 (permalink)
Yeah, I've beat on it pretty hard with a 2lb sledge. Enough to leave a deformation mark on the end of the post.
jetboy,
75-40
Old 10-04-09, 01:34 AM   #25 (permalink)
e9999's Avatar
let us know how the coke worked, please.
turns out I have to deal with the same exact issue....
: '03: 115K
DDs: Accord, Prius
: souped-up DR650
Old 10-04-09, 01:15 PM   #26 (permalink)
Today I took it down and drained the Ammonia. It's been sitting for about three weeks. I didn't realize how fast it evaporated. There wasn't a whole lot left in it. Probably about a cup or so, so most of it evaporated out. After taking it off the stand I hammered it against the concrete; holding the frame hitting the seat post on the ground. I got a little movement. I marked it with a sharpie when I started and the post definitely moved about 2 mm. I hammered and hammered trying to move it out, but had no success. In only. I decided to try coke now and it's sitting with coke. I did notice that coke is slowly dripping through now. Never saw any ammonia come through so it's a promising sign. unfortunately I also have coke coming around the top of the steering tube. I guess those bearings are next on the list.
I'll check again in a couple hours.
jetboy,
75-40
Old 10-05-09, 07:28 AM   #27 (permalink)
wxm
wxm's Avatar
That's a progress! As long as there is movement, you have successfully unstucked the post. Now I would not hammer the post down any further, imagine how rusted the bottom of the seat tube is! You can put the frame on its side (put some cardboards underneath as a paint protection ), use a pipe wrench (the biggest you can find) to move the seatpost - assuming at this point you are willing to sacrifice the seatpost. You might need to put one foot against the head tube for leverage. You only need move it slightly, and then try the other direction. Going back and forth until you can move it completely. (PB blast may be used as lubricant at this point.)
Old 10-10-09, 04:04 PM   #28 (permalink)
e9999's Avatar
well, I did let my post soak in Liquid Wrench for a couple of days.
Put the seat post in a vise and twisted the frame hard. The seat mount let loose. That part was press fitted in the seat post. Post still firmly stuck. Dang...
Hacksawing the post while inside the tube is hopeless I think. There is 13" of post stuck in there.
So either I continue with chemical warfare (I read that caustic soda works too) or I turn an adapter on the lathe that I can fit inside the stuck post. Latter sounds like more fun.
Coke results?
: '03: 115K
DDs: Accord, Prius
: souped-up DR650
Old 10-11-09, 06:36 AM   #29 (permalink)
wxm
wxm's Avatar
Coke results?
Eric, The liquid wrench is useless for aluminum oxide. Try soak it in household ammonia. I've never tried coke, but was able to twist mine after soaking the post in ammonia for less than a week.
Old 10-11-09, 07:36 AM   #30 (permalink)
TLCA# use'ta
Jetboy, you've been fighting your stuck post for more than two months, and now e9999 is joining the fray with his own battle. How many weeks are you guys going to let your frames soak in how many solutions of caustic crap before you attempt my brilliantly simple (and quick) approach? Am I going to have to find my own bike with a stuck post to prove my genius?
Butt
Arcata, CA
7/85 FJ60 277K
For sale - 2f carb
