05-05-08, 08:44 PM
Lickalotapus Rex
Winch mount - done
So I have finally purchased a winch and started to build a winch mount. Some of you may remember that 3+ years ago when I built my front bumper, I planned on putting in a receiver style winch on my rig. That day has come and here's a few pics of the project in progress.
Never mind the bug spatter, I drove thru Florence on Saturday. Bugs everywhere! Check out the splat under the drivers head light.
05-05-08, 09:26 PM
Let me know when you plan to go out for "winching practice". I've got a new (to me) Warn that I'd like to play around with.
Rocky
74 FJ-40 - A work in progress....
05-06-08, 06:40 PM
Lickalotapus Rex
Great idea!
Hopefully I'll get this done this week. I still need to fab up the brackets for the fairlead, wire it up, and spool on the synth line I got for it.
05-06-08, 08:07 PM
Looking good Alvin.
This way if I ever get around to buying a winch, my mount will be perfect.
1994 FZJ80, OME850/864 w/ CSC 1.5" spacers, 285/75 r16 BFG AT/KO, 131K
"SUBDUCTION leads to OROGENY"
"Strip Mining Prevents Forest Fires!" "Stop Continental Drift!"
"Tuff Schist" "Reunite Gondwanaland"
WFC: 2020 5337 1783
05-07-08, 07:37 AM
What's next?
Cool, now I'll have someone to pull my junk out
Quite the bug splat, immagine catching that one in the face on a motorcycle
'69 fj40
CSC#103
A dry heat still cooks a turkey
05-07-08, 08:13 AM
Alvin, would it be worthwhile bracing the bottom between the receiver tube and the mount plate? I'm thinking of a situation where the pull is mainly on one side of the drum.
05-07-08, 09:13 AM
Lickalotapus Rex
Do you mean gusset from the plate to the tube? I did add one on each side at the rear of the plate and I'm thinking of adding another more toward the front of the plate.
05-07-08, 09:26 AM
Now that you mention it, I can see it in the back. I thought about a gusset going all the way to the outside edge of the plate.
05-07-08, 09:43 AM
Nice work...I'd gusset front and rear on the winch platform. Brian has this setup with his 90 4 Runner and likes it. Will it fit in the rear receiver so you could pull from the rear?
05-07-08, 10:01 AM
#10 (permalink)
Sponsored by...?
I recently got a receiver winch, and Tools pointed out that some people have bent the receiver tube with side pulls. I'm gonna shim both ends of the mount so that if the tube starts to bend, it will hit the bumper right away. I'm thinking of some threaded rod at each end, so it can be adjusted for use on the rear or on someone else's truck. Clear as mud? I'm also thinking of running a piece of 1/4" plate inside the tube top and bottom to reinforce it a bit. Solid would be better, and if I ever make my own mount (this one is a Ramsey) I'll start with a solid 2"x2". Drilling that should be fun...
-Spike
His 1994 TLC 'White Elephant' +6"/35" Locked and loaded.
Hers '95 TLC Bare bones.
"I don't understand this business of illegal aliens giving birth to American citizens. If your cat has kittens in the oven, would you call them biscuits?" -Unknown
05-07-08, 10:12 AM
#11 (permalink)
Lickalotapus Rex
With an extension it will fit in the rear bumper. I'll worry about that later. Front end first.
05-07-08, 10:14 AM
#12 (permalink)
Lickalotapus Rex
-Spike
Nice idea on the shims. My plate is within 1/4" of the bumper, I could easily add stops to it so it doesn't get side to side movement.
05-07-08, 10:35 AM
#13 (permalink)
Sponsored by...?
Glad you were able to understand that. Blame Kevin for the shim idea.
-Spike
05-10-08, 06:46 PM
#14 (permalink)
Lickalotapus Rex
Construction is finished. Now it just needs paint, wire it up and spool on the rope.
I added extra gussets underneath and some shims at the rear of the plate to limit side to side movement.
The fairlead brackets are welded at the bottom and bolt to the top of the winch at the top. They are shaped to fit the body of the winch.
The control box bracket is welded to the fairlead bracket.
I didn't mention before, but the main plate is 3/8" plate, the receiver tube is 1/4". The gussets and brackets are either 1/4" or 3/16" plate and L bracket.
Pics
05-10-08, 06:47 PM
#15 (permalink)
Lickalotapus Rex
some more
When the painting is done, I'll get some more pics of the finished project. Then the wiring and spooling on the rope and she's done.
05-11-08, 10:48 AM
#16 (permalink)
Sponsored by...?
Looking damn good.
-Spike
05-11-08, 04:21 PM
#17 (permalink)
Lickalotapus Rex
Here it is painted and mounted up. All thats left is wiring it and spooling on the rope.
Check out my reflection in the light cover. yes I washed the truck today, only the second time this year.
05-11-08, 07:43 PM
#18 (permalink)
Looking damn good.
-Spike
From what I heard about one of your latest adventures, I'd say ANY winch/winchmount is going to look good to you...
Alvin, careful where you're getting compliments from...
05-11-08, 09:57 PM
#19 (permalink)
Sponsored by...?
Dude, it's only May. How many times you gonna wash that thing this year? Careful, you'll get a reputation for primping if you keep this up. Next, you'll be posing with Shotts  (I haven't given him any crap for awhile, so this is a 2-fer post.)
-Spike
05-11-08, 10:06 PM
#20 (permalink)
You did it!! very nice, didn't mess with your clearance much @ all
05-12-08, 09:46 AM
#21 (permalink)
What's next?
What do you think it weighs with the winch and cable?
'69 fj40
CSC#103
05-12-08, 10:39 AM
#22 (permalink)
Nice job, tucked up nicely!
When designing any winch mount the rule is to have it mount centered between the frame rails, close and low as possible. The further it sticks out and/or above the rails, the higher the leverage stresses on the frame. The trick to making receiver style work is having little or if possible no gap between the receiver tang and the mount plate, also having additional contact points on the edges of the plate helps greatly to prevent bending on side pulls.
Copper State Cruisers #007
06-27-08, 02:31 PM
#23 (permalink)
Lickalotapus Rex
Finally finished it.
So I finally got around to wiring it up and spooling on the rope.
Now I have to figure out why I bought a winch in the first place...
06-27-08, 05:13 PM
#24 (permalink)
Pretty green color on the winch line...matches my nails...
Looks great...it's always good to have another winch on the tail.
06-27-08, 06:50 PM
#25 (permalink)
Please PM me if you decided to scrap your winch project
06-27-08, 09:47 PM
#26 (permalink)
Lickalotapus Rex
Green is my favorite color, and when I found out I could get rope in green...
06-27-08, 09:53 PM
#27 (permalink)
Lickalotapus Rex
I believe I'll be holding on to the winch, even though I haven't needed one.
Actually I did have one hooked up to my ass once when I tried to put the truck end-over.
06-27-08, 10:39 PM
#28 (permalink)
No problem. I am just looking for something for Ross to deliver to CM
06-27-08, 10:48 PM
#29 (permalink)
Sponsored by...?
Sounds like you're wheeling about as much as me. I've been 2wd for a month and a half- front DS toast and no motivation to get it fixed. In fact, I haven't wheeled since I got my winch, right after the 'Great White Elephant Rescue' of '08.
Looks good.
-Spike
06-28-08, 12:29 AM
#30 (permalink)
should n't you move the line guiding plate down so the line would not be touching it (hopefully) when pulling?
Wojtek
LC J70 KZJ 3.0 + MM12000 hydr winch with Saginaw P pump
looking for an HDj100
wojtekszala@o2.pl
