TLCA.org
Go Back   IH8MUD.com > TLCAForum.com > Toyota Land Cruiser Association Forum > North American Clubhouses - West Region > AZ- Arizona Land Cruiser Association
View Poll Results: So, how do you plan on building your 100-series:
Extreme, for the running of difficult trails 4 3.88%
Aggressive, for trail running and longer distance touring 42 40.78%
Moderate, for better overall performance on and off-road 48 46.60%
For appearance...we can be honest....right? 9 8.74%
Voters: 103. You may not vote on this poll
LinkBack (12) Thread Tools Display Modes
Old 03-10-08, 10:20 PM   #31 (permalink)
Great write up, and beautiful work. It's my first read through and it looks like we each invented some of the same wheels, so to speak. I learned a lot though. Guess I am changing shocks soon. Thanks for all the insight.
Cheers,
Paul May
Equipt Expedition Outfitters
Equipt is offline   Reply With Quote
Old 03-11-08, 09:27 AM   #32 (permalink)
ShottsUZJ100's Avatar
Cheers,
Glad you liked it Paul.
ShottsUZJ100 is offline   Reply With Quote
Old 03-13-08, 11:52 AM   #33 (permalink)
OrangePips's Avatar
Hi John and all LandCruiser owners on this forum.
This is a great work that has been described on this thread. For me it was the confirmation that I should start modifying my 100 LandCruiser.
Suspensionwise I fully swaped stock suspension to OME, which gave me arnd 2 inches of lift in the back and 1 inch in the front which I know can be adjusted by torsion bars.
However I have one problem. I have custom made forged 18" wheels with 7,25 (ET 55) of backspacing and the width of 9". Current tire size is 285-60-18 which is about 31,5 inches. I know that you had stock 16" wheels with ET 60 and width of 8". I noticed you installed 315 wide rubber on your wheels and had a minor tire to vehicle contact on the lower arm. My worries are that now with my tire size as mentioned I have around 1 santimiter of space between the tire and the upper A arm. I am planning on installing 305 wide tires namely 305-60-18, which is 33 " in diameter. The increase in width will give me 10 millimitres increase on each side of the tire which equals the amount of space left. I am confused a little bit, how is it possible that you used 315 tires without not having trouble with upper A arm without adding wheel spacers. I really hesitate on buying the spacers and also I don't know what to do with 305 tires. Haven't bought them yet. May be I made my measurements wrong.
Do you have any photos of underneath the front fender when the wheel is fully turned to one side with 315 tires. I just wanted to visually compare my situation to yours.
I am grateful for any help. Thanks. Askar.
OrangePips is offline   Reply With Quote
Old 03-13-08, 12:02 PM   #34 (permalink)
OrangePips's Avatar
Independantly from previous post I just wanted to thank John for the work he has done. This work inspired me a lot. Before I considered on lifting my LC, I had made only the following modifications. I had TRD compressor installed with Unichip, Greddy Performance exhaust, Greddy plugs, Boze alloys forged wheels, trd sway bars. Here is a photo of my car before I made changes to suspension.
Together with a suspension change described in the previous message I also installed ARB rear locker.
I hope to post more further details on the work done with my car if I have a chance.
Old 03-13-08, 12:10 PM   #35 (permalink)
Congrats on your mods. While I'm not sure about your rim/tire/backspacing combo I can tell you that fitting 315's with only a 1" T-bar increase will leave you with more problems. And yes, hitting your fender when turned and stuffed, or turning and hitting a bump will happen. I took 2.75" up for me to eliminate that. The only pic I can think of I've shown below.
Wheel spacers for ME are not an option on a 4-wheeler. I will not add the stress to the components. Other take the risk and that's OK. It's their truck.
If you want to run the bigger tires you'll need to add the trim packs to the rear and trim the front more.
Also note the tire model makes a difference. The BFG AT's and MT's fit fine. I've heard some with real wide lugs rub even more.
Old 03-13-08, 12:29 PM   #36 (permalink)
OrangePips's Avatar
Thank you so much for the reply. I understand that I have to adjust my torsion bars a little bit more, however I am more concearned with tire to upper A arm contact in the front! I am also reluctunt to use the spacers, but don't know what else to do. These wheels cost me a lot, so I have no way back. I am planning on BFG MT KM2s by the way. So I guess I ll just have to order the tires and see how they fit. If anything I will use the spacers. Thanks again.
I also found it interesting when you discribed the adjustment of the front end to maintain the maximum lift while preserving the droop. Did you do it by feelings, or by precise measurements. I am asking because I read in the OME torsion bars user guide that the amount of droop should be between 50 to 70 millimeters. I was wondering, when you raised you front as you mentioned 2,75", how much exactly is the droop? I had my torsion bars adjusted and we measured a droop of 55 millimeters, and I was thinking if I raise the front a little more and have the droop decreased to 40 millimeters, will that be ok. What do you think?
Old 03-13-08, 12:39 PM   #37 (permalink)
When I went up to 315's we settled on the lift height after several road tests. At first I had such little droop that I'd lift a tire while hard cornering. Not good.
At the current height the on-road ride is good and safe. I have to do something wild to lift a tire. Off road I could use more droop though like everything there are trade-offs. All I know is that I am up 2.75". And like any maker (OME), they will recommend specs that cover themselves safety-wise. More droop is good. More droop on my truck is not needed IMO. It's been good for 80K now with 35's.
Old 02-18-09, 03:01 PM   #38 (permalink)
Rookie
thank you for sharing
I am new to the site and I am actively seeking a 100 series LC. Thank you for the great write-up. Beautiful pics, descriptions, advise, and experience. All of this gives me a better understanding of what I can do when doings mods. Thanks!!!!!!!!!!
toyotanorthny is offline   Reply With Quote
Old 02-18-09, 03:03 PM   #39 (permalink)
Thanks very much and I hope you find one soon!
Old 03-06-09, 10:05 AM   #40 (permalink)
Rookie
What a great write up. I like the ARB Sahara bumper the best. I also plan on doing the OME lift but hate to see the car sit outside because it will be too tall for the garage.
2000 Land Cruiser
ARB Sahara, 8000 Warn, Dual Battery, Removed Side Steps, Sirius Radio, Weather Tech Floor Liners, PIAA Lights
fuzzyco3 is offline   Reply With Quote
Old 03-06-09, 12:18 PM   #41 (permalink)
Thanks much!
Enjoy your ride. And yes to the garage thing! I'd have a roof rack on mine if it'd fit!
Old 08-04-09, 02:48 PM   #42 (permalink)
Rookie
Great piece of work! ...appreciate all the info and pictures, so much so that I hate to ask for anything else .
I noticed the poll at the top of your thread, and thought how great it would be to create a parts list for each of the following levels of modification;
Extreme - you covered that very well already
Aggressive -
Moderate -
I noticed most folks fall in the aggressive/ moderate level, as I do. My interest is to be able to handle moderate off road conditions, but still be able to get out of trouble... also, I tow a boat regularily, and an improved rear suspension would be very desirable!
I have an 02 LC100 and I'm thinking a 2" lift, 33" BFG tires and new springs & shocks, but you submitted alot of info to sift through and I don't know what the ideal parts list would look like for this set-up.
When you have time, your help would be much appreciated!
Rick
RickF is offline   Reply With Quote
Old 08-04-09, 03:59 PM   #43 (permalink)
Aggressive -
Moderate -
Rick
Thanks for your post Rick. I think the typical OME Lift (2") along with the Slee Diff Drop and 285-size tires would be perfect for you. Info on Slee's site.
Slee - Toyota 100 Series Land Cruiser Suspension
ARB1032 will do the trick.
Then, for towing, you might want to add airbags. Search the MUD sight for info on this. I'm an airbag dummy.
Old 08-04-09, 04:49 PM   #44 (permalink)
Rookie
That was easy... thanks!
Old 11-06-09, 05:01 PM   #45 (permalink)
Rookie
interior
first of all gorgeous truck Shotts, you have all of the exterior mods taken care of but i was wondering what if anything you have going on on the inside?
suunto is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/az-arizona-land-cruiser-association/150735-100-series-modification-differences-evaluations-john-shotts.html
Posted By For Type Date
Norsk Land Cruiser Klubb • Se emne - tips til ombygging av 100 serien This thread Refback 11-03-09 10:15 AM
Just curious whats better landcruiser or fj cruiser? - Toyota FJ Cruiser Forum This thread Pingback 08-09-09 03:26 PM
Форум сети Toyota4X4.RU > срочный вопрос по блокировкам на 100ВХ праворульк This thread Refback 07-06-09 12:43 PM
Форум сети Toyota4X4.RU -> срочный вопрос по блокировкам на 100ВХ праворульк This thread Refback 07-01-09 02:50 PM
Dodge 383 Magnum Optimum Carburator, Dodge 3500 Rear Fenders, Dodge 5Th Wheel Reese - 190D This thread Refback 03-08-09 09:08 AM
Repairing Town And Country Spare Tire Holder, Repairing Scratches On A Chrome Bumper, Repairing Window Riser 1956 Chevy Bel Air - Demonone This thread Refback 03-08-09 07:21 AM
cliffhall's Bookmarks on Delicious This thread Refback 09-05-08 08:40 AM
Women - Equation of Time This thread Refback 05-26-08 02:09 PM
Women - Equation of Time This thread Refback 05-26-08 11:26 AM
Women - Page 2 - Equation of Time This thread Refback 05-24-08 04:42 PM
Women - Equation of Time This thread Refback 05-24-08 12:51 PM
Norsk Land Cruiser Klubb :: Vis Temaet - tips til ombygging av 100 serien This thread Refback 12-17-07 04:23 PM
CONTACT US AT MEMBERSHIP@TLCA.ORG
