Making the switch
I would like to start running bio in my 1HZ powered truck. From the reading I have been doing, it appears that all that is needed to make the change from regular diesel to bio is filling the tank with bio.
Is this accurate?
I know that the bio can corrode rubber fuel lines, but is there anything else I need to think about? Do I need to drain the tank before filling up with bio, or can I just fill it? Can you just switch back and forth between diesel and bio if say you needed to fill up and did not have access to bio? Or, is it ok to switch between the different types of bio.
Sorry for all the ???s, but I want to make sure I know what I am doing before I make this change.
Thanks in advance for your help.
