SVO with no mods?
Summer is coming here in the Bay Area, and now that diesel is $4+ and VO is <$3 at costco, I'm toying with trying SVO out.
I thought that, if the outside temp. was warm, you could use SVO without any mods. Is this a true statement? I have a stock 3B... __________________ 1982 BJ42 "Krull" |
Hell yeah, you try it and get back to us with the results..
depends on the temperature. I would go conservatively and start with a 20% blend, then move to 50% and see what happens.
__________________ Treasurer of Austin Lone Star Land Cruisers TLCA # 15006 Looking for a Cruiser..... Relics: 1991 BTJ80, 1985 BJ70, 1997 FZJ80, 1981 FJ40, 1978 FJ40 |
I run a 20% mix of canola VO in a 13B-T, no mods other than 115v preheating that gets the engine to 20°C/68°F or warmer before start-up.
__________________ Quando Omni Flunkus Moritati |
Well itll be 20C or warmer here for 6 months now so I'm OK on that front. What do you find is the maximum % you can run?
I recommend 25% VO max others use more. Start with 10% or 15% then 20% of clear clean bulk oil from the store. If the exhaust is smoky on start-up then the unburned fuel is forming engine deposits.
Increase the percent of oil till the exhaust smokes then back off a bit. __________________ Quando Omni Flunkus Moritati |
Try this link
The Best Blend for Diesel Fuel - Topic Powered by eve community It was started by John Galt (I assume you are the same?) It has some good information and there are alot of other threads on that site that will help as well. I am about to do the same but am planning on using 50-75% clean, dry WVO. I have added some inline fuel heaters to help thin the blend even further. The heaters I am using are electric and coolant heated, once the engine is up to temperature the electric heat is switched off and the coolant heats the fuel. I have tested various blends and have found that 25% gas mixed in with WVO is very close to the viscosity of very cold diesel. Assuming most IP's a built to handle cold diesel I should be ok. Good luck Rusty __________________ 94 FZJ80 6.2 diesel 78 FJ40 Restoration beginning |
The issue isn't with what percent VO a hot engine will run on, but rather about the damaging engine deposits which form when VO-ULSD blends greater than 25% are used to cold start a cold engine. As well as the problem with unburned VO depositing on injectors, piston tops and rings, there is unburned VO diluting the engine oil. VO in engine oil can increase polymerization of the oil, reduce oil flow and damage bearings.
This is why most people recommend using a two tank SVO system for high percent blends, with the possible exception of older indirect injection engines like MBenz and B & H series non-turbo Toyotas, which are more tolerant of higher percent VO blends. __________________ Quando Omni Flunkus Moritati |
why non turbo??
__________________ BJ62, 3b, H55F 5spd, turbo, A/C, P/S, winch, badass bumpers, defender rack. Facing the music... above 100% rust free diesel expedition cruiser may be up for grabs in 4-6 months time. Shown/delivered anywhere in North, South, Central America. www.wanderinglost.com group for mudders in latin america |
#10 |
The non-turbo Toyota engines are indirect injection and like MBenz they're more tolerant of a wide quality of VO.
#11 | |
#12 | |
EDIT: oops, I lied, soy oil is $5.75 at costco, while diesel is $4.99. Mother earth will have to wait... __________________ 1982 BJ42 "Krull" Last edited by amaurer; 07-01-08 at 07:20 PM. |
#13 |
canola
I was gonna say and then I read the last post;
I just bought some bulk canola for testing and it works out to over 1.80 cdn per litre. Seemingly the only way to get ahead is to clean up some waste VO. |
#14 |
Amaurer
I tried looking up the cheapest veggie oil prices online, what a waste of time that was... Couldn't tell if rapeseed oil (canola) or palm oil was cheaper than Costco soybean oil.. but maybe, Costco does have good prices...., |
#15 |
wholesale
I asked the guy that is giving me his waste oil if he'd order me some new canola for testing until I set up my home filtering. So it worked out to about 1.80 cdn and this is the price Mr. Chong gets to run his asian resturant fryers! Similarily, a farmer who was in the office recently told me corn has doubled in price per bushel since a year ago.
and the vice gets a little tighter...................... |
Refinance | Loans | Cell Phones | Flights | Online Advertising |
