Originally Posted by mac
I've used the Ether Bunny on a 3B myself and it is quite a racket coupled with copious amounts of white smoke. I was in a campground and wasn't able to plug in my Cruiser. With all of my plugs burned out, ether was my only option. My fellow campers were less than pleased... not quite the same as campfire smoke.
The real danger in using ether is if your glow plugs are in anyway functioning they will cause the ether to ignite when you don't want it to, i.e., at a point other than compression/ignition. A misplaced explosion of ether as a piston is coming to the top can do some serious damage- say, broken crank, etc..
I'm late to the party but wanted to add - even if you skip the "Glow", a 3B is wired to turn the plugs on with the starter anyway, so perhaps think twice before using ether on a 3B that has its glow plugs still connected.
It may be that its only a problem if they're burning hot from a long glow cycle, however I think the conservative position would be to say that its only "safe" to use ether when the plugs are all burnt out, or all disconnected.
