Blinker Added to Parking Light Mod
Durango
As you know when you remove the stock bumper, you remove the blinker. After getting my All-Pro Front Bumper, I came up with a way to add the turn signal/blinker light to the indicator light/parking light without any wiring and without buying any parts, except some epoxy.
Basically you cut the socket off the blinker, cut a hole in the parking light, and glue the socket on and Bob's your uncle.
Need:
Dremel with cut-off wheel
Drill
1-1/2" Hole Saw
JB Weld
There are plenty of ways to do this as you will find on this forum, but after researching, I felt this made the most sense to me. The bulb does sit very close to the lens, but it has not caused any melting in the couple of months that I've run it.
Nice.. How long did it actually take to do it? Thats on the list of things to do so I can ditch the stock bumper..
Thanks. It didn't take that long maybe an hour to drill, shape and glue. Then overnight to let the glue set. It all depends on the tools you have. If you dremel it out, it'll pry take longer than drilling.
